Supress Link with base component ilogic
Can you help me use this option in ilogic ?
I have configurator based on derived part. The base part is an ipart. After changing the row i'd like to supress or break all links to the "mother" ipart.
Have i found right object ?
DerivedAssemblyComponentProxy.LinkedToFile() As Boolean
How to use it.
Sub Main()
Dim assm As AssemblyDocument
assm = ThisApplication.ActiveDocument
Dim occ As ComponentOccurrence
Dim derpart As DerivedPartComponent
Dim partdoc As PartDocument
'it f you want to use all components'
Dim doc as AssemblyDocument = ThisDoc.Document
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
Try
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Master").Activate(True)
Catch
Dim nLOD As LevelOfDetailRepresentation
nLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("Master")
oLOD = nLOD
Finally
End Try
For Each occ In assm.ComponentDefinition.Occurrences
    If occ.DefinitionDocumentType = kPartDocumentObject Then
    For Each derpart In occ.Definition.ReferenceComponents.DerivedPartComponents
        derpart.SuppressLinkToFile = True
        iLogicVb.UpdateWhenDone = True
    Next
'    ElseIf occ.DefinitionDocumentType = kAssemblyDocumentObject Then
'    'Call processAllSubOcc(occ) ' subassembly
Next
End Sub
'' This function is called for processing sub assembly. It is called recursively
'' to iterate through the entire assembly tree.
'Sub processAllSubOcc(ByRef occ As ComponentOccurrence)
'Dim derpart As DerivedPartComponent
'Dim oSubCompOcc As ComponentOccurrence
'    For Each oSubCompOcc In occ.SubOccurrences
'    ' Check if it's child occurrence (leaf node)
'        If oSubCompOcc.DefinitionDocumentType = kPartDocumentObject Then
'        For Each derpart In occ.Definition.ReferenceComponents.DerivedPartComponents
'        'My Code
'            If derpart.SuppressLinkToFile = True Then
'            derpart.SuppressLinkToFile= False
'            Else derpart.SuppressLinkToFile = True
'            End If
'        derpart.SuppressLinkToFile = True
'        iLogicVb.UpdateWhenDone = True
'        Next
'        Call processAllSubOcc(occ) ' subassembly
'        End If
'    Next
'End Sub
adam.nagy
Autodesk Support
Autodesk Support
So it looks like you've found the solution.
Could you please set your update as "Accepted Solution" then? 🙂
Cheers,
Adam Nagy
Autodesk Platform Services
NCostelloe
Hi guys,
Is it possible to do this with Break Link?
Nathan Costelloe
Inventor Professional 2024
For sure 😉  i am are waiting for you to change the code.
NCostelloe
Figured it out...
Replace the line
with
     derpart.BreakLinkToFile
It was the True/False that was stuffing me up! 😉
By the way if you want to Unsurppress the Link then
     derpart.SuppressLinkToFile = False
Nathan Costelloe
hi, I just read this thread.
It seems, you solved the problem, but this code does not work in my assm.
I am working with autodesk inventor 2013
It appers the failure:
expect "end of" command in lines 18, 21, 24 and 29
I don`t know what do with it.
Could you give me a hint, please.
P.S. sorry for my bad english
