I have thousands of files to process. Without knowing the name of the iLogic rule is it possible to suppress all Ilogic error messages when running a macro?
Should silentoperation achieve this?
Solved by CadUser46. Go to Solution.
Have you tried:
SyntaxEditor Code Snippet
On Error Resume Next
or
Try Catch End Try
Hello CadUser,
If the SilentOperation property on the Application is set to True and this argument is specified to be False, the defaults in the resulting dialogs are accepted and the dialogs are suppressed.
what kind of error messages are you talking about?
You should prevent error messages from happening with the code Nick wrote
HermJan. The piece of iLogic is triggered on save and I already had the update and save methods wrapped inside the silentoperation method.
There is a workaround of just disabling the iLogic addin which is fine for this project.
