Stitch a composite surface via API
After I load a STEP file containing a single surface, it appears in Inventor as a part with a single Work Surface coming from a "Composite Feature".
I want to stitch it via the API as the first step in an automation process, so I do:
// Get last added document
PartDocument doc = app.Documents[1] as PartDocument;
PartComponentDefinition compDef = doc.ComponentDefinition;
// Stitch all faces in the surface
ObjectCollection args = app.TransientObjects.CreateObjectCollection();
foreach (Face face in compDef.WorkSurfaces[1].SurfaceBodies[1].Faces)
    args.Add(face.SurfaceBody);
compDef.Features.KnitFeatures.Add(args);
However, the call to
KnitFeatures.Add
 just throws an exception and I don't know what's wrong. Via the UI, it's as easy as clicking on the composite surface to select the composite.
I've tried passing the WorkSurface directly instead of all the faces, but still the same result. Any ideas?
Thanks!
YuhanZhang
Can you attach a sample data to reproduce the problem? Don't upload confidential data.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
