<stuartmp> wrote in messageHi
href="news:6050597@discussion.autodesk.com">news:6050597@discussion.autodesk.com...
All I was just wondering if it is possible to get the current sheet number
through VBA? Thanks
through VBA? Thanks
yes...
Public Sub x()
'The sheet number is appended to the sheet name in _
the browser. You can get this name using the Name _
property of the Sheet object and then extract the number from the name. *Brian Ekins
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim NoOfSheets As Integer
Dim CurrentSheet As Integer
NoOfSheets = oDoc.Sheets.Count
Dim strSheetName As String
strSheetName = oDoc.ActiveSheet.Name
If InStr(strSheetName, ":") Then
' Extract the sheet number from the name.
GetSheetNumber = CInt(Right$(strSheetName, Len(strSheetName) - InStrRev(strSheetName, ":")))
Else
'This sheet is not numbered so returnzero.
GetSheetNumber = 0
CurrentSheet = GetSheetNumber
Debug.Print CurrentSheet
Debug.Print NoOfSheets
End Sub
Isn't the sheet number the same as the document.sheets index value? If so;
dim sheetNo as integer = 0
For index as Integer = 1 to document.sheets.count
if documents.sheets(index).name = activesheet.name then
'sheet number found it is index.
sheetNo = index
exit for
end if
next
i am not quiet sure about that...but the solution posted by Brian Ekins seems to work fine...
