Running Ilogic Assembly Level step file generator code I found, how do I stop it from saving factory and member parts?
I'm experimenting with the code from this website, http://blog.ads-sol.com/2016/01/batch-assembly-export.html
Is there a way to make it only spit out the member files, not member and factory? Any insight is appreciated. I do have some VB.net and ilogic exposure. My Internet searches have yielded nada. I've found other adaptions of this code but not addressing the saving of factory and member files.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a STEP file for all components." _
& vbLf & " " _
& vbLf & "Are you sure you want to create STEP Drawings for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output STEPs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
oPath = ThisDoc.Path
'get STEP target folder path
oFolder = oPath & "\" & oAsmName & " STEP Files"
'get the document revision to use in the new filename
oRevNumAsm = iProperties.Value("Project", "Revision Number")
'Check for the step folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Assembly - - - - - - - - - - - -
ThisDoc.Document.SaveAs(oFolder & "\" & oAsmName & "_Rev" & oRevNumAsm &(".stp") , True)
'- - - - - - - - - - - - -Components - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
Dim oCurFile As Document
oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
oCurFileName = oCurFile.FullFileName
'defines backslash As the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(oCurFileName, "\", -1)
'get the file name with the file extension
Name = Right(oCurFileName, Len(oCurFileName) - FNamePos)
'get the file name (without extension)
ShortName = Left(Name, Len(Name) - 4)
oRevDoc = iProperties.Value(Name, "Project", "Revision Number")
Try
oCurFile.SaveAs(oFolder & "\" & ShortName & "_Rev" & oRevDoc & (".stp") , True)
Catch
MessageBox.Show("Error processing " & oCurFileName, "ilogic")
End Try
oCurFile.Close
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new files are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
