Run Rule for all Subbassebly Files in Inventor
vkulikajevas
vkulikajevas
Hello, I am trying to make a BoundingBox Rule for all subassembly files. It takes extentions and places them in order of Length, Width and Thickness. But I want to run this rule for all subassembly files (Assemblies and Parts). I added rules for that, but so far, they still only work for current Assembly or part. Can you help me make this rule work?
The main rule starts at "Sub BoundingBox". I tried messing up later with different rules, but so far no success.
Maybe the code should open part and run the BoundingBox rule from within to work? and then close it and repeat for other parts?
Sub Main
	If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule is designed to only work in assembly documents.", "Wrong Document Type") : Exit Sub
	Dim parentDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Do anything unique to main assembly
	Call AssemblyRunner(parentDoc)
End Sub
Sub AssemblyRunner(aDoc As AssemblyDocument)
	'Do things to the assembly file if any
	'MessageBox.Show(aDoc.DisplayName, "Assembly:")
        'Start Looping
	For Each oOcc As ComponentOccurrence In aDoc.ComponentDefinition.Occurrences
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject
			Call AssemblyRunner(oOcc.Definition.Document)
			Call BoundingBox
		Else If oOcc.DefinitionDocumentType = kPartDocumentObject
			Call PartRunner(oOcc.Definition.Document, aDoc)
	Next
End Sub
Sub PartRunner(pDoc As PartDocument, parent As AssemblyDocument)
	'Do Part things
	'MessageBox.Show(pDoc.DisplayName & vbCrLf & vbCrLf & _
	'				"Found in Assembly: " & parent.DisplayName, "Part:")
	Call BoundingBox
End Sub
Sub BoundingBox
'Get Component bounding box measurements
Model_X=Round(Measure.ExtentsLength) 'X-axis BB length
Model_Y=Round(Measure.ExtentsWidth)  'Y-axis BB length
Model_Z=Round(Measure.ExtentsHeight) 'Z-axis BB length'Add / Update Bounding Box measurements to model's Custom Properties
If Model_X >= Model_Y And Model_Y >= Model_Z Then
iProperties.Value("Custom", "DIM") = Model_X & "x" & Model_Y & "x" & Model_Z
iProperties.Value("Custom", "Ilgis")=Model_X
iProperties.Value("Custom", "Plotis")=Model_Y
iProperties.Value("Custom", "Storis")=Model_Z
ElseIf Model_X >= Model_Z And Model_Z >= Model_Y Then
iProperties.Value("Custom", "DIM") = Model_X & "x" & Model_Z & "x" & Model_Y
iProperties.Value("Custom", "Plotis")=Model_Z
iProperties.Value("Custom", "Storis")=Model_Y
ElseIf Model_Y >= Model_X And Model_X >= Model_Z Then
iProperties.Value("Custom", "DIM") = Model_Y & "x" & Model_X & "x" & Model_Z
iProperties.Value("Custom", "Ilgis")=Model_Y
iProperties.Value("Custom", "Plotis")=Model_X
ElseIf Model_Y >= Model_Z And Model_Z >= Model_X Then
iProperties.Value("Custom", "DIM") = Model_Y & "x" & Model_Z & "x" & Model_X
iProperties.Value("Custom", "Storis")=Model_X
ElseIf Model_Z >= Model_X And Model_X >= Model_Y Then
iProperties.Value("Custom", "DIM") = Model_Z & "x" & Model_X & "x" & Model_Y
iProperties.Value("Custom", "Ilgis")=Model_Z
ElseIf Model_Z >= Model_Y And Model_Y >= Model_X Then
iProperties.Value("Custom", "DIM") = Model_Z & "x" & Model_Y & "x" & Model_X
'ThisDoc.Save
'ThisDoc.Document.Close(True)
End Sub
Hello @vkulikajevas . Try this code, just update your "if" statements.
Please let me know if it works for you.
Regards.
Sub Main ()
Dim oCompDef As AssemblyComponentDefinition
For Each oDoc As Document In ThisApplication.ActiveDocument.ReferencedDocuments
	Dim oFileName As String = oDoc.FullFileName
	oRefDoc = ThisApplication.Documents.Open(oFileName,True)
	Call BoundingBox()
	oRefDoc.Close
Next
iLogicVb.UpdateWhenDone = True
MsgBox("Done!")
End Sub
Sub BoundingBox()
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
'[ ADD CUSTOM PROPERTIES
customPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
Try
      pDIM = customPropertySet.Item("DIM")
Catch
      ' Assume error means not found
      customPropertySet.Add("", "DIM")
End Try
Try
      pIlgis = customPropertySet.Item("Ilgis")
Catch
      customPropertySet.Add("", "Ilgis")
End Try
Try
      pPlotis = customPropertySet.Item("Plotis")
Catch
      customPropertySet.Add("", "Plotis")
End Try
Try
      pStoris = customPropertySet.Item("Storis")
Catch
      customPropertySet.Add("", "Storis")
End Try
Dim minPoint As Point = oCompDef.RangeBox.MinPoint
Dim maxPoint As Point = oCompDef.RangeBox.MaxPoint
Dim uom As UnitsOfMeasure = oDoc.UnitsOfMeasure
Dim Units As String = uom.GetStringFromType(uom.LengthUnits)
Dim X As Double = uom.ConvertUnits ((maxPoint.X - minPoint.X), "cm", uom.LengthUnits)
Dim Y As Double = uom.ConvertUnits ((maxPoint.Y - minPoint.Y), "cm", uom.LengthUnits)
Dim Z As Double = uom.ConvertUnits ((maxPoint.Z - minPoint.Z), "cm", uom.LengthUnits)
Length = Round(MaxOfMany (X,Y,Z),2)
Width = Round( X + Y + Z - MaxOfMany (X,Y,Z) - MinOfMany(X,Y,Z),2)
Thickness = Round(MinOfMany (X,Y,Z),2)
'Please double check if these equevalents are correct. Model_X = Length 'Round(Measure.ExtentsLength) 'X-axis BB length Model_Y= Width 'Round(Measure.ExtentsWidth) 'Y-axis BB length Model_Z = Thickness 'Round(Measure.ExtentsHeight) 'Z-axis BB length'Add / Update Bounding Box measurements to model's Custom Properties If Model_X >= Model_Y And Model_Y >= Model_Z Then customPropertySet.Item("DIM").Value = Model_X & "x" & Model_Y & "x" & Model_Z customPropertySet.Item("Ilgis").Value = Model_X customPropertySet.Item("Plotis").Value = Model_Y customPropertySet.Item("Storis").Value = Model_Z 'ElseIf Model_X >= Model_Z And Model_Z >= Model_Y Then 'iProperties.Value("Custom", "DIM") = Model_X & "x" & Model_Z & "x" & Model_Y 'iProperties.Value("Custom", "Ilgis")=Model_X 'iProperties.Value("Custom", "Plotis")=Model_Z 'iProperties.Value("Custom", "Storis")=Model_Y 'ElseIf Model_Y >= Model_X And Model_X >= Model_Z Then 'iProperties.Value("Custom", "DIM") = Model_Y & "x" & Model_X & "x" & Model_Z 'iProperties.Value("Custom", "Ilgis")=Model_Y 'iProperties.Value("Custom", "Plotis")=Model_X 'iProperties.Value("Custom", "Storis")=Model_Z 'ElseIf Model_Y >= Model_Z And Model_Z >= Model_X Then 'iProperties.Value("Custom", "DIM") = Model_Y & "x" & Model_Z & "x" & Model_X 'iProperties.Value("Custom", "Ilgis")=Model_Y 'iProperties.Value("Custom", "Plotis")=Model_Z 'iProperties.Value("Custom", "Storis")=Model_X 'ElseIf Model_Z >= Model_X And Model_X >= Model_Y Then 'iProperties.Value("Custom", "DIM") = Model_Z & "x" & Model_X & "x" & Model_Y 'iProperties.Value("Custom", "Ilgis")=Model_Z 'iProperties.Value("Custom", "Plotis")=Model_X 'iProperties.Value("Custom", "Storis")=Model_Y 'ElseIf Model_Z >= Model_Y And Model_Y >= Model_X Then 'iProperties.Value("Custom", "DIM") = Model_Z & "x" & Model_Y & "x" & Model_X 'iProperties.Value("Custom", "Ilgis")=Model_Z 'iProperties.Value("Custom", "Plotis")=Model_Y 'iProperties.Value("Custom", "Storis")=Model_X End If End Sub
vkulikajevas
Thank you, it works.
