Run an internal iLogic Rule from VB.net
BromanSillito
BromanSillito
I'm trying to get my VB.net program to run internal iLogic rules. I've done a lot of searching on the web & in these forums but still can't seem to make my program work. Here's the current module that I'm trying to get working:
Imports Inventor
Imports System.IO
Module modiLogic
Private iLogicAuto As Object
Private invApp As Inventor.Application
Public Sub RuniLogicRule(ByVal RuleName As String)
On Error Resume Next
iLogicAuto = GetiLogicAddin(invApp)
If iLogicAuto Is Nothing Then Exit Sub
Dim oDoc As Inventor.Document = invApp.ActiveDocument
iLogicAuto.RunRule(oDoc, RuleName)
oDoc = Nothing
On Error GoTo 0
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
' Get addin collection & addin variables
GetiLogicAddin = Nothing
Dim addIns As ApplicationAddIns = oApplication.ApplicationAddIns
Dim addIn As ApplicationAddIn
Dim customAddIn As ApplicationAddIn = Nothing
For Each addIn In addIns
If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
customAddIn = addIn
Exit For
Next
If (customAddIn Is Nothing) Then
Exit Function
Else
customAddIn.Activate()
Return customAddIn.Automation
End Function
End Module
Here is an internal iLogic rule I am trying to run from VB.net:
If FlgType = "RF Weld-Neck Flange" Then
FlgStBk = Parameter("SHELL_FLG", "Y") + Parameter("SHELL_FLG", "RF") + WeldGap
ElseIf FlgType = "RJ Weld-Neck Flange" Then
ElseIf FlgType = "RF Slip-On Flange" Then
inc = .0625 ' rounding increment ( .125, .25, .5, etc)
FlgStBk = Ceil(Round(Parameter("SHELL_PIPE", "t") + .0625,4) / inc) * inc
ElseIf FlgType = "RJ Slip-On Flange" Then
InventorVb.DocumentUpdate()
Here is how I'm calling out the sub:
Private Sub btnTestiLogic_Click(sender As Object, e As EventArgs) Handles btnTestiLogic.Click
CheckInventor()
RuniLogicRule("ShellPipeSize")
End Sub
When I press the "btnTestiLogic" button, nothing happens.
Could somebody please give me some advice to help fix this?
Owner2229
HI, here below is the VB.Net code I'm ussing:
Imports Inventor
Imports System.Runtime.InteropServices
Public Class RunRule
Private InventorApplication As Inventor.Application
Public Sub iLogic(rule As String)
Try
InventorApplication = Marshal.GetActiveObject("Inventor.Application")
Catch
Exit Sub
End Try
Dim iLogicAuto As Object Dim oDoc As Inventor.Document oDoc = InventorApplication.ActiveDocument If oDoc Is Nothing Then MsgBox ("Missing Inventor Document") Exit Sub End If iLogicAuto = GetiLogicAddin() If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunExternalRule(oDoc, rule) End Sub Private Function GetiLogicAddin() As Object Dim addIn As Inventor.ApplicationAddIn Try addIn = InventorApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") addIn.Activate GetiLogicAddin = addIn.Automation Catch GetiLogicAddin = Nothing End Try End Function
End Class
You can the use it like this:
Dim Run As New RunRule
Run.iLogic("ShellPipeSize")
Run = Nothing
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
BromanSillito
Thanks Owner2229. I copied the code over to it's own class but it isn't working - nothing happens when I run it. Here's how I'm calling it out:
CheckInventor()
Run.iLogic("Testing")
Run = Nothing
End Sub
I'm using a button in a form (btnTestiLogic) that I press to run the code. When I try to debug, it looks to me like it is hitting the "If (iLogicAuto Is Nothing)" statement and ilogicAuto is returning Nothing so it is exiting the sub before it can run the rule. Any ideas why iLogicAuto is not working?
Owner2229
Hi, I can't see why it wouldn't work :S
Do you have added the references for both "Autodesk.Inventor.Interops" and "System" ?
Maybe you can try this, as you actualy sayd you want to run an internal rule:
iLogicAuto.RunRule(oDoc, rule)
instead of this:
Anyway, what stops you from rewriting the iLogic rule to your VB.Net program?
This is how you can acces the parameters from VB.Net. E.g. if I want to set the parameter "size" to be 25:
Imports Inventor
Sub Main()
Try
Catch
Exit Sub
End Try
oParameter(oDoc, "size").Expression = 25
End Sub
Private Function oParameter(oDoc As Inventor.PartDocument, oPara As String) As Inventor.Parameter Dim oParams As Inventor.Parameters oParams = oDoc.ComponentDefinition.Parameters oParameter = oParams.Item(oPara) End Function
Mike
JBEDsol
When I get into creating classes that's straight over my head.  How/where do I enter the class code?
