Has anyone used RubberDuck with Inventor's VBA? I am using it for 2017 and Excel but it does not seem to like Inventor 2020.
Hello arrakisman,
I didn't known RubberDuck! I installed it and it works for Excel, but not for Inventor 2020 as you said...
Have you already reported it to the team developing RubberDuck?
I think nothing can be done on the Inventor side.
# I downloaded the source code of it. It was mainly written in C# and huge to hack for me ...
Freeradical
Hideo Yamada
I have also found that RubberDuck fails with Inventor 2020 with the "Resolver Error".
I tested with Inventor 2017 and also fails the same.
(I tested with Inv2017 because it was the last to fully support 32bit OS and calling apps. -- just in case the issue RD was having was affected by that .. it seems not to be related since both fail.)
Hello all Rubberduck lovers,
I have located the reason why Rubberduck is not working properly with Inventor VBA.
See details:
https://github.com/rubberduck-
The patch may have side effects, but seems to be working well at this point.
