Rivet - Assembly
Rivet - Assembly
martinhoos
Message 1 of 29
Rivet - Assembly
martinhoos
Hi Forum, at first, i am a noob about ilogic, i always stick together differnet code and hope that it works.
I put day by day many rivets in parts (that is boring), my idea is: i call a code, that code ask me about a part (rivet that is place in) and about a area. After that the code checks the area and find all the holes that are equal with the hole where the rivet is stored in. The code place at all the same holes other rivets. That will save me a lot of time.
Is there anybody who has similar code for that?  Btw i work with Inventor 2015.
Thanks a lot and i appreciate any help.
Regards Martin
Replies (28)
Message 21 of 29
dg2405
You should use the new iLogic-Version, there is only one promt. Just past the code in an new external rule and run it.
Message 22 of 29
Andrew.M.Brodsky
@dg2405 When I run the iLogic Rule that you just recently posted I get an error.  Here are my steps that I am following; 1. Select the rule to run in iLogic. 2. Select a circle on the mating face of the part I want to duplicate. 3. Select a circle on the mating part face hole pattern. At this point the error comes up and nothing happens.
Message 23 of 29
dg2405
Which Inventor Version do you use?
Please show the Tab "More Info" in the Error window.
Message 24 of 29
Andrew.M.Brodsky
The folder listed on the first line of the error does not exist on my system.  We do not use Vault.
Message 25 of 29
dg2405
Sorry, attached Symboles have to be in that Folder
Message 26 of 29
Andrew.M.Brodsky
@dg2405  It works great now! Thank you for sharing this!
Message 27 of 29
kbacon-TATMAN
Has anyone converted dg2405's code to English?
Message 28 of 29
maxim.teleguz
how can i get this to work with inches?
Message 29 of 29
maxim.teleguz
updated code that is faster now in large assemblies, use as ilogic code.
Imports System.Windows.Forms
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System
AddReference "System.Drawing.dll"
Class Teile_platzieren
Dim oAllOccsCollection As ObjectCollection
Dim oAllCOnstraintsCollection As ObjectCollection
Private ExitSub     As Boolean = False
Private IsMateConst As Boolean = True
Dim oCurrentTopOcc As ComponentOccurrence
Sub Main()
	SendKeys.SendWait("{ESC}")
AppActivate(ThisApplication.Caption)
    'oVault = ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
    'Auf Bg zugreifen
    Dim oApp As Inventor.Application = ThisApplication
    Dim oAsmDoc As AssemblyDocument = oApp.ActiveDocument
    Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
    Dim oMasterAsmCompDef As AssemblyComponentDefinition = oAsmCompDef
	 'Kreis von Normteil/Fläche greifen
    Dim oNormteilKreisProxy As EdgeProxy = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Select Circle From Part")
    If oNormteilKreisProxy Is Nothing Then Exit Sub
    'If oNormteilKreisProxy.GeometryType <> CurveTypeEnum.kCircleCurve Or Then Exit Sub
    Dim oFlaechenKreisProxy As EdgeProxy = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Pick Circle where you are placing part")
    If oFlaechenKreisProxy Is Nothing Then Exit Sub
    'If oFlaechenKreisProxy.GeometryType <> CurveTypeEnum.kCircleCurve Then Exit Sub
    oApp.AssemblyOptions.EnableAssemblyExpress = True
    oApp.ScreenUpdating = True
    Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsmDoc, "PlaceParts")
    'oUnit = UnitsTypeEnum.kMillimeterLengthUnits
    'Wenn unterbaugruppe in Bearbeitung ist, dann Fokus auf aktive Occurrence legen
    If Not oAsmCompDef.ActiveOccurrence Is Nothing Then
        oAsmCompDef = oAsmCompDef.ActiveOccurrence.Definition
        oAsmDoc = oAsmCompDef.Document
    'Dim cmdMgr     As CommandManager
    'cmdMgr = ThisApplication.CommandManager
    'Dim copyDef    As ControlDefinition
    'copyDef = cmdMgr.ControlDefinitions.Item("AppCopyCmd")
    'Dim pasteDef   As ControlDefinition
    'pasteDef = cmdMgr.ControlDefinitions.Item("AppPasteCmd")
	 'sets master representation
    If oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Master=False Then oAsmCompDef.RepresentationsManager.PositionalRepresentations(1).Activate
    'Form einblenden
    CreateForm("Place Parts (Cancel With Esc)")
    MyForm.ShowDialog()
    If ExitSub = True Then Exit Sub
    'Dim Msg        As Integer = MsgBox("Flächennormale identisch?", vbYesNoCancel, "Einfügerichtung")
    'If Msg = vbCancel Then Exit Sub
    'Dim Offset     As String = InputBox("Distanz", "Eingabe", 0)
    Dim Winkel      As String
    Try        'Wenn Fehleingaben gemacht wurden
    Offset = TextBox(0).Text
    Offset = StrToDbl(Offset)        'Konvertieren, damit mm u. co egal ist
    Winkel = TextBox(1).Text
    Winkel = StrToDbl(Winkel)        'Konvertieren, damit mm u. co egal ist
    Catch
    Exit Sub
End Try
'Occurrences bestimmen
Dim oNormteilOcc    As ComponentOccurrence = oNormteilKreisProxy.ContainingOccurrence
Dim oFlächenOcc     As ComponentOccurrence = oFlaechenKreisProxy.ContainingOccurrence
'Rausspringen wenn gleiche Occ angewählt wurde
If oNormteilOcc Is oLanglochOcc Then Exit Sub
'Suchen ob oNormteilOcc auf aktuellem Bauteillevel liegt
SearchForTopOccFinal(oNormteilOcc, oMasterAsmCompDef)
Dim oTopNormteilOcc As ComponentOccurrence = oCurrentTopOcc
oCurrentTopOcc = Nothing
Dim NormOccIstInBG  As Boolean = False
If Not oTopNormteilOcc Is oNormteilOcc Then NormOccIstInBG = True
'Nach Itemnumber In Leafoccurrences schauen, wichtig für die Identifizierung der NewNormteilOcc nach dem Kopieren
Dim TopNormteilOccItem As Integer
Dim oOccProxy       As ComponentOccurrenceProxy
If TypeOf oTopNormteilOcc.Definition.Document Is AssemblyDocument Then
    For TopNormteilOccItem = 1 To oTopNormteilOcc.Definition.Occurrences.AllLeafOccurrences.Count
        oTopNormteilOcc.CreateGeometryProxy(oTopNormteilOcc.Definition.Occurrences.AllLeafOccurrences.Item(TopNormteilOccItem), oOccProxy)
        If oOccProxy Is oNormteilOcc Then Exit For
    Next
'Prüfen ob einzufügendes Teil ein Normteil ist, dann ist LockRot ist True außer es ist eine Außnahme definiert
Dim LockRot         As Boolean = False
If TypeOf oNormteilOcc.Definition.Document Is PartDocument Then
    If oNormteilOcc.Definition.IsContentMember = True _
       Or InStr(UCase(oNormteilOcc.Definition.Document.PropertySets("Design Tracking Properties")("Description").value), "LINSEN-FLANSCH") Then
    LockRot = True
    If CheckBox(0).Checked = True Then LockRot = False
If CheckBox(1).Checked = False Then LockRot = True
'Senkrechte Ebenen zu NormteilKreis ermitteln
'RichungunsVektor
Dim oNormteilKreisNormal As UnitVector = oNormteilKreisProxy.Geometry.Normal
'Proxies
Dim oNormteilPerpendWorkPlaneProxy As WorkPlaneProxy
Dim oNormteilPerpendWorkAxisProxy As WorkAxisProxy
'WorkplaneProxies
Dim oWorkPlaneProxy1 As WorkPlaneProxy
Dim oWorkPlaneProxy2 As WorkPlaneProxy
Dim oWorkPlaneProxy3 As WorkPlaneProxy
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkPlanes(1), oWorkPlaneProxy1)
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkPlanes(2), oWorkPlaneProxy2)
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkPlanes(3), oWorkPlaneProxy3)
'WorkaxisProxies
Dim oWorkAxisProxy1 As WorkAxisProxy
Dim oWorkAxisProxy2 As WorkAxisProxy
Dim oWorkAxisProxy3 As WorkAxisProxy
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkAxes(1), oWorkAxisProxy1)
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkAxes(2), oWorkAxisProxy2)
oNormteilOcc.CreateGeometryProxy(oNormteilOcc.Definition.WorkAxes(3), oWorkAxisProxy3)
'über parallele Einheitsvektoren die Ebenen bestimmen
If oNormteilKreisNormal.IsParallelTo(oWorkPlaneProxy1.Plane.Normal, 0.00001) Then
    oNormteilPerpendWorkPlaneProxy = oWorkPlaneProxy2
    oNormteilPerpendWorkAxisProxy = oWorkAxisProxy1
If oNormteilKreisNormal.IsParallelTo(oWorkPlaneProxy2.Plane.Normal, 0.00001) Then
    oNormteilPerpendWorkPlaneProxy = oWorkPlaneProxy3
    oNormteilPerpendWorkAxisProxy = oWorkAxisProxy2
If oNormteilKreisNormal.IsParallelTo(oWorkPlaneProxy3.Plane.Normal, 0.00001) Then
    oNormteilPerpendWorkPlaneProxy = oWorkPlaneProxy1
    oNormteilPerpendWorkAxisProxy = oWorkAxisProxy3
'Wenn Bohrung schräg liegt nochmals über die Ebenen versuchen
If oNormteilPerpendWorkPlaneProxy Is Nothing Then
    If oNormteilKreisNormal.IsPerpendicularTo(oWorkPlaneProxy1.Plane.Normal, 0.00001) Then
    If oNormteilKreisNormal.IsPerpendicularTo(oWorkPlaneProxy2.Plane.Normal, 0.00001) Then
    If oNormteilKreisNormal.IsPerpendicularTo(oWorkPlaneProxy3.Plane.Normal, 0.00001) Then
    LockRot = True
'Senkrecht Ebenen zu FlächenKreis ermitteln
Dim oFlächenPerpendWorkPlaneProxy As WorkPlaneProxy
Dim oFlächenKreisNormal As UnitVector = oFlaechenKreisProxy.Geometry.Normal
'Bohrungsdurchmesser von Kreis
Dim Bohrungsdurchmesser As Double = Round(oFlaechenKreisProxy.Geometry.Radius * 20, 3)
oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkPlanes.Item(1), oWorkPlaneProxy1)
oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkPlanes.Item(2), oWorkPlaneProxy2)
oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkPlanes.Item(3), oWorkPlaneProxy3)
If oWorkPlaneProxy1.Plane.Normal.IsParallelTo(oFlächenKreisNormal, 0.00001) Then oFlächenPerpendWorkPlaneProxy = oWorkPlaneProxy2
If oWorkPlaneProxy2.Plane.Normal.IsParallelTo(oFlächenKreisNormal, 0.00001) And oFlächenPerpendWorkPlaneProxy Is Nothing Then oFlächenPerpendWorkPlaneProxy = oWorkPlaneProxy3
If oWorkPlaneProxy3.Plane.Normal.IsParallelTo(oFlächenKreisNormal, 0.00001) And oFlächenPerpendWorkPlaneProxy Is Nothing Then oFlächenPerpendWorkPlaneProxy = oWorkPlaneProxy1
'ErsatzAchsen:
Dim oFlächenPerpendWorkAxisProxy As WorkAxisProxy
Dim FlächenKreisNormalAngle As Double = 0
If oFlächenPerpendWorkPlaneProxy Is Nothing Then
    oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkAxes.Item(1), oWorkAxisProxy1)
    oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkAxes.Item(2), oWorkAxisProxy2)
    oFlächenOcc.CreateGeometryProxy(oFlächenOcc.Definition.WorkAxes.Item(3), oWorkAxisProxy3)
    If oWorkAxisProxy1.Line.Direction.IsPerpendicularTo(oFlächenKreisNormal, 0.00001) Then oFlächenPerpendWorkAxisProxy = oWorkAxisProxy1
    If oWorkAxisProxy2.Line.Direction.IsPerpendicularTo(oFlächenKreisNormal, 0.00001) And oFlächenPerpendWorkAxisProxy Is Nothing Then oFlächenPerpendWorkAxisProxy = oWorkAxisProxy2
    If oWorkAxisProxy3.Line.Direction.IsPerpendicularTo(oFlächenKreisNormal, 0.00001) And oFlächenPerpendWorkAxisProxy Is Nothing Then oFlächenPerpendWorkAxisProxy = oWorkAxisProxy3
    If oFlächenPerpendWorkAxisProxy Is Nothing Then oFlächenPerpendWorkAxisProxy = oWorkAxisProxy1
'Identische Kreise suchen und in Collection schreiben
Dim oCircleCollection As ObjectCollection = oApp.TransientObjects.CreateObjectCollection
oCircleCollection.Add(oFlaechenKreisProxy)
Dim oFlaechenFacePlane As Plane = oApp.TransientGeometry.CreatePlane(oFlaechenKreisProxy.Geometry.Center, oFlächenKreisNormal.AsVector)
Dim oCircCenterPoint As Point
Dim IsAlreadyCenter As Boolean = False
For Each oBodyproxy As SurfaceBodyProxy In oFlächenOcc.SurfaceBodies
    For Each oCircleProxy As EdgeProxy In oBodyproxy.Edges
        If oCircleProxy.GeometryType = CurveTypeEnum.kCircleCurve _
           Or oFlaechenKreisProxy.GeometryType = CurveTypeEnum.kCircularArcCurve _
           And oCircleProxy.GeometryType = CurveTypeEnum.kCircularArcCurve Then
        If Round(oCircleProxy.Geometry.Radius * 20, 3) = Bohrungsdurchmesser _
           And Round(oFlaechenFacePlane.DistanceTo(oCircleProxy.Geometry.Center), 5) = 0 _
           And Round(oFlaechenFacePlane.DistanceTo(oCircleProxy.PointOnEdge), 5) = 0 Then
        For Each oCircleProxy2 As EdgeProxy In oCircleCollection
            oCircCenterPoint = oCircleProxy2.Geometry.Center
            If oCircCenterPoint.IsEqualTo(oCircleProxy.Geometry.Center, 0.00001) Then
                IsAlreadyCenter = True
                Exit For
        Next
        If IsAlreadyCenter = False Then
            oCircleCollection.Add(oCircleProxy)
            Continue For
Next
Next
'Weitere Kreise hinzufügen fall Kreis von Schweißteil ist und nicht auf gleicher Fläche
SearchForTopOccFinal(oFlächenOcc, oAsmCompDef)        'Wenn oOcc in Unterbaugruppe ist, dann Rekursiv hochgehen bis Baugruppe gefunden ist
Dim oTopFlächenOcc  As ComponentOccurrence = oCurrentTopOcc
If TypeOf oTopFlächenOcc.Definition.Document Is AssemblyDocument Then
    Dim oTopFlächenDoc As AssemblyDocument = oTopFlächenOcc.Definition.Document
    If oTopFlächenDoc.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then
        For Each oOcc As ComponentOccurrence In oTopFlächenOcc.SubOccurrences
            For Each oBodyproxy As SurfaceBodyProxy In oOcc.SurfaceBodies
                            Exit For
                    Next
                        Continue For
        Next
    Next
Next
'Bereits abhängige Kreise aus Collection entfernen
Dim oConstraint     As Object
If oCircleCollection.Count>1 Then
    For Each oConstraint In oTopFlächenOcc.Constraints
        If oConstraint.Suppressed = False And oConstraint.HealthStatus = HealthStatusEnum.kUpToDateHealth Then
            If oConstraint.Type <> ObjectTypeEnum.kInsertConstraintObject Then Continue For
            Try
            If oConstraint.EntityOne Is Nothing Or oConstraint.EntityTwo Is Nothing Then Continue For        'War nötig weil in Baugruppe 82720.020.51.00.iam fehler kommt. Bei Einfügen:18 Fehlt die Entity, warum unbekannt!
            For Each oCircleProxy As EdgeProxy In oCircleCollection
                oCircCenterPoint = oCircleProxy.Geometry.Center
                If Round(oCircCenterPoint.DistanceTo(oConstraint.EntityOne.Geometry.Center), 5) = 0 _
                   Or Round(oCircCenterPoint.DistanceTo(oConstraint.EntityTwo.Geometry.Center), 5) = 0 Then
                If Round(oCircCenterPoint.DistanceTo(oFlaechenKreisProxy.Geometry.Center), 5) = 0 Then Continue For        'Außnahme dass immer auf den ersten Kreis eine Abhängigkeit platziert wird
                oCircleCollection.RemoveByObject(oCircleProxy)
        Next
        Catch
    End Try
Next
'Alle Zusammenhägenden Occs in Collection
oAllCOnstraintsCollection = oApp.TransientObjects.CreateObjectCollection
oAllOccsCollection = oApp.TransientObjects.CreateObjectCollection
oAllOccsCollection.Add(oTopNormteilOcc)
SearchAllOccsInOcc(oTopNormteilOcc)
'Bildschirmaktualisierung aus 'Bringt starke Zeitersparnis
oApp.AssemblyOptions.DeferUpdate = True
'oApp.ScreenUpdating = False
'oVault.Deactivate
'Auf allen Kreisen ein Teil/Teileverbund platzieren
For Each oCircleOnFaceProxy As EdgeProxy In oCircleCollection
    'Occurrence count originally
    Dim occCount    As Integer = oAsmCompDef.Occurrences.Count
    Dim oNewNormteilOcc As ComponentOccurrence
    'New originOcc ermitteln
    If Not oCircleOnFaceProxy Is oCircleCollection(1) Then
        oApp.ActiveDocument.SelectSet.SelectMultiple(oAllOccsCollection)
        'AppActivate(ThisApplication.Caption)
        oApp.CommandManager.ControlDefinitions.Item("AppCopyCmd").Execute2(True)
        'Call copyDef.Execute
        'Call WinAPISetFocus(ThisApplication.ActiveView.hwnd)
        oApp.CommandManager.ControlDefinitions.Item("AppPasteCmd").Execute2(True)
        'Call pasteDef.Execute
        'Clipboard.Clear
        'GC.Collect(generation, GCCollectionMode.Forced)
        'iLogic.FreeILogicMemory
        'iLogic.ClearCodeClipboard
        For i = occCount + 1 To oAsmCompDef.Occurrences.Count
            If oAsmCompDef.Occurrences(i).Definition.Document Is oTopNormteilOcc.Definition.Document Then
                oNewNormteilOcc = oAsmCompDef.Occurrences(i)
                Exit For
        Next
        If NormOccIstInBG = True Then
            Dim oNewNormteilOccProxy As ComponentOccurrenceProxy
            oNewNormteilOcc.CreateGeometryProxy(oNewNormteilOcc.Definition.Occurrences.AllLeafOccurrences.Item(TopNormteilOccItem), oNewNormteilOccProxy)
            oNewNormteilOcc = oNewNormteilOccProxy
    Else
        oNewNormteilOcc = oNormteilOcc
    'Neue Proxies definieren
    Dim oNewNormteilPerpendWorkPlaneProxy1 As WorkPlaneProxy
    Dim oNewNormteilPerpendWorkAxisProxy1 As WorkAxisProxy
    If Not oNormteilPerpendWorkPlaneProxy Is Nothing        'Wenn Bohrung im Raum liegt
    oNewNormteilOcc.CreateGeometryProxy(oNormteilPerpendWorkPlaneProxy.NativeObject, oNewNormteilPerpendWorkPlaneProxy1)
    oNewNormteilOcc.CreateGeometryProxy(oNormteilPerpendWorkAxisProxy.NativeObject, oNewNormteilPerpendWorkAxisProxy1)
Dim oNewNormteilKreisProxy As EdgeProxy
oNewNormteilOcc.CreateGeometryProxy(oNormteilKreisProxy.NativeObject, oNewNormteilKreisProxy)
'Insert Abhaengigkeit vergeben
Dim Insert_Param_Expression As String
If IsMateConst = True Then
    'If Insert_Param_Expression = "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, True, Offset / 10,LockRot)
    If Insert_Param_Expression = "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, True, Offset,LockRot)
    If Insert_Param_Expression <> "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, True, Insert_Param_Expression,LockRot)
Else
    'If Insert_Param_Expression = "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, False, Offset / 10,LockRot)
    If Insert_Param_Expression = "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, False, Offset,LockRot)
    If Insert_Param_Expression <> "" Then oConstraint = oAsmCompDef.Constraints.AddInsertConstraint2(oNewNormteilKreisProxy, oCircleOnFaceProxy, False, Insert_Param_Expression,LockRot)
Dim X               As Integer
Dim Z               As Integer
    Insert_Param_Expression = oConstraint.Distance.Name
    For X = 1 To 10000
        Try
        oConstraint.Name = "Constraint:" & X & "-0-Master"
        Exit For
        Catch
    End Try
Next
Else
    For Z = 1 To 10000
        Try
        oConstraint.Name = "Constraint:" & X & "-" & Z
        Exit For
        Catch
    End Try
Next
If LockRot = True Then Continue For
'Angle Abhaengigkeit vergeben
Dim oAngleConstraint As AngleConstraint
Dim Angle_Param_Expression As String
    If Angle_Param_Expression = "" Then oAngleConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oNewNormteilPerpendWorkPlaneProxy1, oFlächenPerpendWorkAxisProxy, Winkel, kReferenceVectorSolution, oNewNormteilPerpendWorkAxisProxy1)
    If Angle_Param_Expression <> "" Then oAsmCompDef.Constraints.AddAngleConstraint(oNewNormteilPerpendWorkPlaneProxy1, oFlächenPerpendWorkAxisProxy, Angle_Param_Expression, kReferenceVectorSolution, oNewNormteilPerpendWorkAxisProxy1)
Else
    If Angle_Param_Expression = "" Then oAngleConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oNewNormteilPerpendWorkPlaneProxy1, oFlächenPerpendWorkPlaneProxy, Winkel, kReferenceVectorSolution, oNewNormteilPerpendWorkAxisProxy1)
    If Angle_Param_Expression <> "" Then oAngleConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oNewNormteilPerpendWorkPlaneProxy1, oFlächenPerpendWorkPlaneProxy, Angle_Param_Expression, kReferenceVectorSolution, oNewNormteilPerpendWorkAxisProxy1)
    Angle_Param_Expression = oAngleConstraint.Angle.Name
    For X = 1 To 10000
        Try
        oAngleConstraint.Name = "Angle:" & X & "-0-Master"
        Exit For
        Catch
    End Try
Next
Else
    For Z = 1 To 10000
        Try
        oAngleConstraint.Name = "Angle:" & X & "-" & Z
        Exit For
        Catch
    End Try
Next
Next
'oApp.UserInterfaceManager.UserInteractionDisabled = False
'Bildschirmaktualisierung ein + update
'oVault.Activate
'oVault.Select
oApp.AssemblyOptions.DeferUpdate = False
'oApp.CommandManager.ControlDefinitions.Item("AppRefineAppearanceCmd").Execute2(True)
'oApp.CommandManager.ControlDefinitions.Item("iLogic.FreeILogicMemory").Execute2(True)
'oApp.CommandManager.ControlDefinitions.Item("iLogic.ClearCodeClipboard").Execute2(True)
oMasterAsmCompDef.Document.Update
'oUnit = UnitsTypeEnum.kInchLengthUnits
oTrans.End
End Sub
Function SearchAllOccsInOcc(oOcc As ComponentOccurrence)
    For Each oConstraint As AssemblyConstraint In oOcc.Constraints
        Dim ConstraintVorhanden As Boolean = False
        For Each oConstInCol As Object In oAllCOnstraintsCollection
            If Not oConstraint Is oConstInCol Then Continue For
            ConstraintVorhanden = True
            Exit For
        Next
        oAllCOnstraintsCollection.Add(oConstraint)
        oAllOccsCollection.Add(oConstraint.AffectedOccurrenceOne)
        If ConstraintVorhanden = False Then SearchAllOccsInOcc(oConstraint.AffectedOccurrenceOne)
        On Error Resume Next
        oAllOccsCollection.Add(oConstraint.AffectedOccurrenceTwo)
        If ConstraintVorhanden = False Then SearchAllOccsInOcc(oConstraint.AffectedOccurrenceTwo)
    Next
    For Each oJoint As AssemblyJoint In oOcc.Joints
        Dim JointVorhanden As Boolean = False
        For Each oJointInCol As Object In oAllCOnstraintsCollection
            If Not oJoint Is oJointInCol Then Continue For
            JointVorhanden = True
            Exit For
        Next
        oAllCOnstraintsCollection.Add(oJoint)
        oAllOccsCollection.Add(oJoint.AffectedOccurrenceOne)
        If JointVorhanden = False Then SearchAllOccsInOcc(oJoint.AffectedOccurrenceOne)
        oAllOccsCollection.Add(oJoint.AffectedOccurrenceTwo)
        If JointVorhanden = False Then SearchAllOccsInOcc(oJoint.AffectedOccurrenceTwo)
    Next
End Function
Function SearchForTopOccFinal(oOcc As ComponentOccurrence, oMasterAsmCompDef As AssemblyComponentDefinition) As ComponentOccurrence
    If oCurrentTopOcc Is Nothing Then oCurrentTopOcc = oOcc
    If Not oOcc.ParentOccurrence Is oMasterAsmCompDef.ActiveOccurrence Then
        oCurrentTopOcc = oOcc.ParentOccurrence
        SearchForTopOccFinal(oOcc.ParentOccurrence, oMasterAsmCompDef)
        Return oCurrentTopOcc
End Function
Function StrToDbl(str As String) As Double
    'For i = 1 To Len(str)
    'Dim CurrentCharacter As String = Mid(str, i, 1)
    'If i=1 And CurrentCharacter="-" Then Continue For
    'If IsNumeric(CurrentCharacter) = False _
    'And CurrentCharacter <> "," _
    'And CurrentCharacter <> "." Then
    'str = Replace(str, CurrentCharacter, "")
    'End If
    'If CurrentCharacter = "." Then str = Replace(str, CurrentCharacter, ",")
    'Next
    StrToDbl = str
End Function
Private WithEvents MyForm As System.Windows.Forms.Form
Private Button0     As System.Windows.Forms.Button
Private Button1     As System.Windows.Forms.Button
Private ComboBox(0) As System.Windows.Forms.ComboBox
Private Label(0)    As System.Windows.Forms.Label
Private PicBox(0)   As System.Windows.Forms.PictureBox
Private TextBox(0)  As System.Windows.Forms.TextBox
Private CheckBox(0) As System.Windows.Forms.CheckBox
Private RadioButton(0) As System.Windows.Forms.RadioButton
Private GroupBox    As System.Windows.Forms.GroupBox
Private Label0      As System.Windows.Forms.Label
Private Label1      As System.Windows.Forms.Label
Private RadioButton0 As System.Windows.Forms.RadioButton
Private RadioButton1 As System.Windows.Forms.RadioButton
Private Sub CreateForm(Optional Name As String = vbNullString)
    MyForm = New System.Windows.Forms.Form
    MyForm.Text = Name
    MyForm.AutoScaleMode = AutoScaleMode.Dpi
    MyForm.Size = New Drawing.Size(375*2, 150*2)        'Width, Heigth
    MyForm.MinimumSize = MyForm.Size
    MyForm.MaximumSize = MyForm.Size
    MyForm.Font = New Drawing.Font(MyForm.Font.FontFamily, 10)
    MyForm.MaximizeBox = False
    MyForm.MinimizeBox = False
    MyForm.ShowIcon = False
    MyForm.SizeGripStyle = SizeGripStyle.Hide
    MyForm.StartPosition = FormStartPosition.CenterScreen
    MyForm.KeyPreview = True
    AddLabel(5*2, (128+20-140)*2, "Offset")
    AddTextBox(55*2, (125+20-140)*2, "0", 100*2)
    AddLabel(155*2, (128+20-140)*2, "in")
    AddLabel(5*2, (153+20-140)*2, "Deg")
    AddTextBox(55*2, (150+20-140)*2, "0", 100*2)
    AddLabel(155*2, (153+20-140)*2, "°")
    AddLabel(5*2, (195+20-140)*2, "Create angle constraint On standard parts?")
    AddLabel(5*2, (220+20-140)*2, "Create Angle constraint On non-standard parts?")
    AddCheckBox(335*2, 75*2, False)
    AddCheckBox(335*2, 100*2, False)
    AddMateButton()
    AddFlushButton()
    TextBox(0).TabIndex = 0
    TextBox(1).TabIndex = 1
    Button0.TabIndex = 2
    Button1.TabIndex = 3
    MyForm.AutoScaleDimensions = New System.Drawing.SizeF(184F, 184F)
    'MyForm.Font = New System.Drawing.Font("Tahoma", 10F)
    MyForm.AcceptButton = Button0
    MyForm.PerformAutoScale()
End Sub
'Private Sub MyForm_FormClosing(ByVal sender As Object, ByVal E As System.Windows.Forms.FormClosedEventArgs) Handles MyForm.FormClosed
'	If sender.Name = "CloseButton" Then
'		MessageBox.Show(sender.Name)
'	End If
'End Sub
Private Sub MyForm_KeyDown(ByVal sender As System.Object, ByVal E As System.Windows.Forms.KeyEventArgs) Handles MyForm.KeyDown
    If E.KeyCode = Keys.Escape Then
        MyForm.Close
        ExitSub = True
        'Exit sub
End Sub
'Private Sub Button_Click(ByVal sender As System.Object, ByVal E As System.Windows.Forms.FormClosingEventArgs) Handles Button.FormClosing
'	MessageBox.Show(sender.ToString, "Title")
'	MyForm.Close
'	ExitSub = True
'End Sub
Private Function AddLabel(PosX As Integer, PosY As Integer, Optional Caption As String = vbNullString, Optional Width As Integer = 100) As System.Windows.Forms.Label
    Dim LC          As Integer = Label.Length - 1
    If Not Label(LC) Is Nothing Then
        LC = LC + 1
        ReDim Preserve Label(LC)
    Label(LC) = New System.Windows.Forms.Label
    Label(LC).Name = "L" & LC
    Label(LC).Location = New Drawing.Point(PosX, PosY)
    Label(LC).Text = Caption
    Label(LC).AutoSize = True
    Label(LC).Width = Width
    MyForm.Controls.Add(Label(LC))
    Return Label(LC)
End Function
Private Function AddCheckBox(PosX As Integer, PosY As Integer, Checked As Boolean,Optional Caption As String = vbNullString, Optional Width As Integer = 100) As System.Windows.Forms.CheckBox
    Dim LC          As Integer = CheckBox.Length - 1
    If Not CheckBox(LC) Is Nothing Then
        LC = LC + 1
        ReDim Preserve CheckBox(LC)
    CheckBox(LC) = New System.Windows.Forms.CheckBox
    CheckBox(LC).Location = New Drawing.Point(PosX, PosY)
    CheckBox(LC).Name = "CheckBox" & LC
    CheckBox(LC).Text = Caption
    CheckBox(LC).Width = Width
    CheckBox(LC).Checked = Checked
    CheckBox(LC).TabStop = False
    MyForm.Controls.Add(CheckBox(LC))
    Return CheckBox(LC)
End Function
Private Function AddTextBox(PosX As Integer, PosY As Integer, Optional Caption As String = vbNullString, Optional Width As Integer = 100) As System.Windows.Forms.TextBox
    Dim LC          As Integer = TextBox.Length - 1
    If Not TextBox(LC) Is Nothing Then
        LC = LC + 1
        ReDim Preserve TextBox(LC)
    TextBox(LC) = New System.Windows.Forms.TextBox
    TextBox(LC).Location = New Drawing.Point(PosX, PosY)
    TextBox(LC).Name = "TextBox" & LC
    TextBox(LC).Text = Caption
    TextBox(LC).Width = Width
    MyForm.Controls.Add(TextBox(LC))
    Return TextBox(LC)
End Function
Private Function AddMateButton() As System.Windows.Forms.Button
    Button0 = New System.Windows.Forms.Button
    Button0.Name = "Button0"
    Button0.Image = Drawing.Image.FromFile("I:\inventor\iLogic rules\Mate.png")
    Button0.Location = New Drawing.Point(190*2, 5*2)
    Button0.Text = ""
    Button0.Width = Button0.Image.Width*2
    Button0.Height = Button0.Image.Height*2
    MyForm.Controls.Add(Button0)
    AddHandler Button0.Click, AddressOf OnMateClick
    Return Button0
End Function
Private Function AddFlushButton() As System.Windows.Forms.Button
    Button1 = New System.Windows.Forms.Button
    Button1.Name = "Button1"
    Button1.Image = Drawing.Image.FromFile("I:\inventor\iLogic rules\Flush.png")
    Button1.Location = New Drawing.Point(275*2, 5*2)
    Button1.Text = ""
    Button1.Width = Button1.Image.Width*2
    Button1.Height = Button1.Image.Height*2
    MyForm.Controls.Add(Button1)
    AddHandler Button1.Click, AddressOf OnFlushClick
    Return Button1
End Function
Private Sub OnMateClick()
    MyForm.Close
    IsMateConst = True
End Sub
Private Sub OnFlushClick()
    MyForm.Close
    IsMateConst = False
End Sub
End Class
