Rename Positional Representations
Brett.G
Brett.G
Is it possible to rename positional representations through the API?  I've tried setting the name as PosRep.name = "Test" but the method fails.
Owner2229
Something like this? Remember, you can't rename the "Main" representation.
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oPR As PositionalRepresentation = oCD.RepresentationsManager.PositionalRepresentations("OldName")
oPR.Name = "NewName"
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Brett.G
Mike,
    Thanks for the reply, what you wrote out is essentially what I was doing in my code.  My issue was that I was trying to rename a positional representation with a name that was already in use. Oops!
