Prevent rule running in assembly
L.R20
L.R20
Hi everyone,
I'm quite new to iLogic.
I'm trying to run a rule with event triggers (Part Geometry Change, Before Save Document). This rule may only run if the part is a sheetmetal document with a flatpattern view in it.
The rule detects bendlines in a flatpattern and places holes on the start and end points of the bendlines. (Sub bendmarker code borrowed from @danmorick, and sub main code borrowed from @Owner2229 edited a little)
The problem I have with this rule is, the rule also runs in an assembly (If I edit a sheetmetal part and update the assembly), but the main sub must prevent it from running in a document other than a sheetmetal. Inventor somehow runs this in the background in the sheetmetal parts? (even when the sheetmetal parts are not opened.
SyntaxEditor Code Snippet
Sub Main()
    'Check if open document is sheetmetal
    Dim oDoc             As PartDocument = ThisApplication.ActiveDocument
    'Dim oDoc             As PartDocument = ThisDoc.Document
        'Controle of document een sheetmetal document is.
    If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        Exit Sub
    'Check if open sheetmetal document has flatpattern view
    Dim oSMD             As ComponentDefinition = oDoc.ComponentDefinition
    If oDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
        ElseIf oSMD.FlatPattern Is Nothing Then
        Exit Sub
    'Check if feature "BendMarkerHoles" exists
    Dim FeatureName As String = "BendMarkerHoles"
    If Not oSMD.HasFlatPattern Then
        Exit Sub
    Dim oFTS As FlatPatternFeatures = oSMD.FlatPattern.Features
    If oFTS.Count = 0 Then
        BendMarker
        Exit Sub
    Dim MyFT As PartFeature = Nothing
    For Each oFT As PartFeature In oFTS
        If oFT.Name = FeatureName Then
            MyFT = oFT
            Exit For
    Next
    If Not MyFT Is Nothing Then
        Try
        oFTS("BendMarkerHoles").delete
        Catch
        End Try
        BendMarker
        Exit Sub
    Else
        BendMarker
End Sub
Sub BendMarker()
    Dim oEdge             As Edge
    Dim oEdges             As Edges
    Dim oEnt            As SketchEntity
    Dim oTransGeom      As TransientGeometry = ThisApplication.TransientGeometry
    Dim oHoleCenters     As Object = ThisApplication.TransientObjects.CreateObjectCollection
    Dim CordXS             As Double
    Dim CordYS             As Double
    Dim CordXE             As Double
    Dim CordYE             As Double
    Dim oSketch         As PlanarSketch
    Dim oFlat             As FlatPattern = oSMD.FlatPattern
    Dim oSP                As SketchPoint
    Dim oEP                As SketchPoint
    'Flatpattern sketch -------------------------------------------------------------------------
    oSketch = oFlat.Sketches.Add(oFlat.TopFace, False)
    oSketch.Edit
    'Detect bend down ---------------------------------------------------------------------------
    oEdges = oFlat.GetEdgesOfType(64005, True)
    For Each oEdge In oEdges
        oEnt = oSketch.AddByProjectingEntity(oEdge)
        CordXS = oEnt.StartSketchPoint.Geometry.X
        CordYS = oEnt.StartSketchPoint.Geometry.Y
        X = CordXS
        Y = CordYS
        oSP = oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(X,Y), True)
        oHoleCenters.Add (oSP)
        CordYE = oEnt.EndSketchPoint.Geometry.Y
        X = CordXE
        Y = CordYE
        oEP = oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(X,Y), True)
        oHoleCenters.Add (oEP)
    Next
    'Detect bend up ------------------------------------------------------------------------------
    oEdges = oFlat.GetEdgesOfType(64004, True)
        X = CordXS
        Y = CordYS
        CordXE = oEnt.EndSketchPoint.Geometry.X
        X = CordXE
        Y = CordYE
    Next
    Call oSMD.FlatPattern.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleCenters, 0.1, kPositiveExtentDirection)
    Try
        Dim oHoleFeat As HoleFeature
        oHoleFeat = oSMD.FlatPattern.Features.HoleFeatures.Item(1)
        oHoleFeat.Name = "BendMarkerHoles"
        Catch
    End Try
    oSketch.ExitEdit
    oSketch.Name = "MarkedBends"
End Sub
Kind regards,
machiel.veldkamp
Relevant
https://forums.autodesk.com/t5/inventor-ideas/sheet-metal-bendline-details/idc-p/6795343#M16036
___________________________
Owner2229
Hey, how about this? Orange is the only "real" change, the rest is just simplification.
Sub Main()
    Dim oDoc As Document = ThisApplication.ActiveDocument
    If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Exit Sub
    If Not oSMD.HasFlatPattern Then Exit Sub
    Dim oFTS As FlatPatternFeatures = oFlat.Features
    If oFTS.Count > 0 Then
            If oFT.Name <> FeatureName Then Continue For
            Try
                oFT.Delete()
            Catch
            End Try
            Exit For
        Next
    BendMarker(oFlat)
End Sub
Sub BendMarker(oFlat As FlatPattern)
    Dim oEdges As Edges
    Dim oSketch As PlanarSketch = oFlat.Sketches.Add(oFlat.TopFace, False)
    oSketch.Edit()
    WorkEdges(oHoleCenters, oSketch, oEdges)
    Call oFlat.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleCenters, 0.1, kPositiveExtentDirection)
    Try
        Dim oHoleFeat As HoleFeature = oFlat.Features.HoleFeatures.Item(1)
    Catch
    End Try
    oSketch.ExitEdit()
End Sub
Sub WorkEdges(ByRef oHoleCenters As Object, ByRef oSketch As PlanarSketch, oEdges As Edges)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry For Each oEdge As Edge In oEdges Dim oEnt As SketchEntity = oSketch.AddByProjectingEntity(oEdge) Dim P As Point2d = oEnt.StartSketchPoint.Geometry Dim oSP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True) oHoleCenters.Add (oSP) P = oEnt.EndSketchPoint.Geometry Dim oEP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True) oHoleCenters.Add (oEP) Next End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
L.R20
It is working correctly! Thanks for the solution.
L.R20
I have another question.
The rule also detect bend lines from a lofted flange. The problem is, a lofted flange has a lot of bend lines close to each other. The blue circle in the picture indicates where the bendmarkerpoints are too close to each other.
Is there a way to concentrate the points close to each other to a single point, or maybe another solution?
