Not finding a edge loop that IsOuterEdgeLoop using vb.net, Inventor 2015
awatt
awatt
I have a sub (vb.net) that caluclates the area of the outer edge loop, and ignores any interior cutouts, holes, slots, etc.  It works fairly well, most of the time.
Every now and then I run into a part it just can't handle, with no explanation why.  It's bailing out at the 'failure finding outer edge loop' (Error code "Susan".)
I'm attaching a file that seems to give it problems.  (Inventor 2015).
Here's the code:
Dim oInvApp As Inventor.Application
Dim oDoc As Inventor.PartDocument
Private WithEvents AreaButton As ButtonDefinition
Sub FlatPatternSF() Handles AreaButton.OnExecute
Dim oEdgeLoops As EdgeLoops
Dim oEdgeLoop As EdgeLoop
Dim oEdges As Edges
Dim oProfile As Profile
Dim dArea As Double
Dim oFlatPattern As FlatPattern
Dim oTransaction As Transaction
Dim oSketch As PlanarSketch
Dim oParameter As UserParameter
Dim ComponentDef As SheetMetalComponentDefinition
oInvApp = Marshal.GetActiveObject("Inventor.Application")
oDoc = oInvApp.ActiveDocument
ComponentDef = oDoc.ComponentDefinition
If ComponentDef.HasFlatPattern = False Then
System.Windows.Forms.MessageBox.Show("Area not calculated. Please create flat pattern first.",
"Error",
Windows.Forms.MessageBoxButtons.OK,
Windows.Forms.MessageBoxIcon.Error)
Exit Sub
oFlatPattern = ComponentDef.FlatPattern
oTransaction = oInvApp.TransactionManager.StartTransaction(oDoc, "Find Area")
Try
oSketch = oFlatPattern.Sketches.Add(oFlatPattern.TopFace)
Catch ex As Exception
System.Windows.Forms.MessageBox.Show("Area not calculated. Failure creating sketch in flat pattern. Please report error code ""Jessica"" to the Cad Admin.",
"Error",
oTransaction.Abort()
Exit Sub
End Try
Try
oEdgeLoops = oFlatPattern.TopFace.EdgeLoops
System.Windows.Forms.MessageBox.Show("Area not calculated. Failure getting edge loops from top face. Please report error code ""Hilda"" to the Cad Admin.",
"Error",
Exit Sub
End Try
' Find outer loop.
For Each oEdgeLoop In oEdgeLoops
If oEdgeLoop.IsOuterEdgeLoop Then
Exit For
System.Windows.Forms.MessageBox.Show("Area not calculated. Failure finding outer edge loop. Please report error code ""Susan"" to the Cad Admin.",
"Error",
Exit Sub
Next
' Add outer loop to sketch.
oEdges = oEdgeLoop.Edges
For Each oEdge In oEdges
oSketch.AddByProjectingEntity(oEdge)
Next
Try
oProfile = oSketch.Profiles.AddForSolid
System.Windows.Forms.MessageBox.Show("Area not calculated. Failure creating perimeter Profile. Please report error code ""Agatha"" to the Cad Admin.",
"Error",
Exit Sub
End Try
dArea = oProfile.RegionProperties.Area
' Blow away sketch.
' Set minimum area to 0.05 square feet (46.45 square cm).
If dArea < 46.45125 Then
dArea = 46.45125
' Convert because user units are kinda wierd. Needed for legacy compatibility.
dArea = dArea * 2.54
Try
oParameter = oDoc.ComponentDefinition.Parameters.Item("Area_cm")
Catch ' Assuming that the parameter "Area_cm" does not exist.
oParameter = oDoc.ComponentDefinition.Parameters.AddByValue("Area_cm", "", UnitsTypeEnum.kInchLengthUnits)
End Try
oParameter.Value = dArea
oDoc.Update()
System.Windows.Forms.MessageBox.Show("Area calculated.",
"Success!",
Windows.Forms.MessageBoxButtons.OK)
End Sub
awatt
I found the logic error.  Re-testng now.
awatt
Yep.  Logic error.
The for-each was exiting on the first iteration.
As long as the first edge loop happened to be the outer edge loop, (small parts), the program worked fine.  This lead me to blame the part, not the code.
Sorry to bother everyone.
rob_bolter
Sorry to drag up an old post, but did you not know about the following? Function Area() As Double Dim Doc As Inventor.Document = InvApp.ActiveDocument If Doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then If Doc.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then 'Is sheet metal Dim pDoc As PartDocument = Doc Dim SMDef As SheetMetalComponentDefinition = pDoc.ComponentDefinition If SMDef.HasFlatPattern Then Return SMDef.FlatPattern.Length * SMDef.FlatPattern.Width Else Return Nothing End If Else MsgBox("Not a sheet metal part.") Return Nothing End If Else MsgBox("Not a part document!") Return Nothing End If End Function
Intel Xeon 3.5GHz (8 Cores)
Dual nVidia Quadro K2200 (4GB) - Dual Screen
32GB RAM
