Launch rules and forms from Ribbon
I know I can make a button on the ribbon for running a specific macro. But, is this possible for iLogic rules? I would love to be able to run rules and launch forms from the ribbon!?
Great blog post, thanks. But if I have a form or ilogic rule I want to launch, do I have to change them to macros to be able to add them to the ribbon?
I am not good at iLogics, so you just only consider my opinion.
1. If you can find how to open a iLogic from a subroutine in VBA. Then you can create a button as upper link.
2. If impossible to do 1. and the code is simple, you can try to rewrite it again in VBA
3. How can you create a form in iLogic? Or you import this form from somewhere else? Maybe you can write a code to use this form iLogic.
i would also like to fire up a form from the ribbon, can it be done yet?
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Stephen,
I assume you have known how to create an addin with ribbon interface.
From addin you can access iLogic. Firstly add the reference <Inventor>\Bin\Autodesk.iLogic.Automation.dll. The following is a C# code how to call a rule. Of course, if the rule calls a ilogic form, it can also work.
       void test()
            string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}";
            Inventor.ApplicationAddIn addin =
            m_inventorApplication.ApplicationAddIns.get_ItemById(iLogicAddinGuid);
            if (addin.Activated == false)
                addin.Activate();
            Autodesk.iLogic.Automation.iLogicAutomation _iLogicAutomation = addin.Automation;
            // assume "MyRule" will pop out the form of iLogic
            _iLogicAutomation.RunRule(m_inventorApplication.ActiveDocument, "MyRule");
