Hello together,
is it possible to change the hole feature dialog for Inventor 2017 like in this post:
http://beinginventive.typepad.com/being-inventive/2011/06/inventor-2012-hole-feature-dialog.html
Georg
Solved by wayne.brill. Go to Solution.
Hi Georg,
I was able to get the My_hole_defaults() macro from that post you mentioned to work on my 64 bit install of Inventor 2017.
I had to add PtrSafe to the Windows API function definitions. I also had to use LongPtr for one of the parameters of the EnumChildWindows function. I attached the ivb file. (rename to .ivb) To try it you can load it in Inventor's VBA.
I am not an expert on using the Windows API from VBA so please test thoroughly. Also I hope this is an answer to the question.
Wayne
