Ilogic save part location and orientation
Message 1 of 1
how to save te position of a part in to excel to restore later on in a new assy. To do that I want to save the xyz origin and the x,y,z angle.
 I think somone with matrix exprerience and good knowledge of mathematics can solve this.
#Region get x, y, z
'this works
Private Sub GetOccOrigin(oOcc As ComponentOccurrence, ByRef CoordinateX As String, ByRef CoordinateY As String, ByRef CoordinateZ As String)', ByRef ptX As Double,ByRef ptY As Double,ByRef ptZ As Double)
	'Dim oUOM As UnitsOfMeasure = ThisApplication.ActiveDocument.UnitsOfMeasure
	' Get the current transformation matrix from the occurrence.
	Dim oTransform As Matrix
	oTransform = oOcc.Transformation
	Dim oOriginLocation As Vector
	oOriginLocation = oTransform.Translation
	Dim uom As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
	Dim convFactor As Double = uom.ConvertUnits(1.0, uom.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
	'ptX = oUOM.ConvertUnits(oOriginLocation.X, "cm", "in")
	ptX = oOriginLocation.X/convFactor'oUOM.ConvertUnits(oOriginLocation.X, "mm", "mm")
	ptY = oOriginLocation.Y/convFactor'oUOM.ConvertUnits(oOriginLocation.Y, "mm", "mm")
	ptZ = oOriginLocation.Z/convFactor'oUOM.ConvertUnits(oOriginLocation.Z, "mm", "mm")
	CoordinateX=CStr(Round(ptX,2))
	CoordinateY=CStr(Round(ptY,2))'Coordinates & " ; " & CStr(Round(ptY,2))
	CoordinateZ=CStr(Round(ptZ,2))'Coordinates  & " ; " &  CStr(Round(ptZ,2))
End Sub
#End Region
#Region "get angel"
something is wrong in the mathematics or the refered  me the right value
 'finally the function that retrieves the rotations:
Public Sub GetAngleOfOccurence(ByVal itemlist As ArrayList,ByRef ArrayXRotation As ArrayList, ByRef ArrayYRotation As ArrayList, ByRef ArrayZRotation As ArrayList)
    Dim oDoc As Inventor.Document= ThisApplication.ActiveDocument
	Dim oOcc As ComponentOccurrence
	Dim attSet As AttributeSet
    Select Case oDoc.DocumentType
        Case kAssemblyDocumentObject
			If itemlist.count <> 0 Then
				For i=0 To itemlist.count-1
					oOcc = Component.InventorComponent(itemlist(i))
					Dim oMatrix As Matrix= oOcc.Transformation
					Call oMatrix.GetMatrixData(trans)
					PI = 3.14159265358979
					RadToDeg = 180 / PI
					'Vector X - X-waarde
					'Vector Y - waarde X
					'Vector Z - waarde X
					'Origin - waarde X
					'Vector X - Y-waarde
					'Vector Y - Y-waarde
					'Vector Z - Y-waarde
					'Oorsprong - y
					'Vector X - waarde Z
					'Vector Y - Z-waarde
					'Vector Z - Z-waarde
					'Origin - waarde Z
					'leeg
					'leeg
					'leeg
					Call EulerAngles(AngelX,  AngelY,  AngelZ)
					ArrayXRotation.add(CStr(Round(AngelX,2)))
					ArrayYRotation.add(CStr(Round(AngelY,2)))
					ArrayZRotation.add(CStr(Round(AngelZ,2)))
				Next i
    End Select
Public Function Atan2custom(ByVal y As Double,ByVal x As Double)
' returned value is in radians
    If x > 0 Then
        'Atan2 = VBA.Atn(y / x)
		Atan2custom = System.Math.Atan(y / x)
    ElseIf (x < 0 And y >= 0) Then
		'Atan2 = VBA.Atn(y / x) + PI
        Atan2custom = System.Math.Atan(y / x) + PI
    ElseIf (x < 0 And y < 0) Then
        'Atan2 = VBA.Atn(y / x) - PI
		Atan2custom = System.Math.Atan(y / x) - PI
    ElseIf (x = 0 And y > 0) Then
        Atan2custom = PI / 2
    ElseIf (x = 0 And y < 0) Then
        Atan2custom = -PI / 2
    ElseIf (x = 0 And y = 0) Then
        Atan2custom = 0
End Function
Public Function ArcSin(x As Double) As Double
	ArcSin = System.Math.Atan(x / System.Math.Sqrt(-x * x + 1))
End Function
Public Function ArcCos(x As Double) As Double
	ArcCos = System.Math.Atan(-x / System.Math.Sqrt(-x * x + 1)) + 2 * Math.Atan(1)
End Function
Public Function Eulerz'(ByVal trans() As Double)
    If (trans(8) <> 1 And trans(8) <> -1) Then
        Eulerz= Atan2custom(trans(4) / System.Math.Cos(ArcSin(trans(8))), trans(0) / System.Math.Cos(ArcSin(trans(8))))
	Else
        Eulerz= 0
End Function
Public Function Eulery
        Eulery= -ArcSin(trans(8))
    ElseIf (trans(8) = -1) Then
        Eulery= PI / 2
    Else
        Eulery= -PI / 2
End Function
Public Function Eulerx
        Eulerx= Atan2custom(trans(9) / Cos(ArcSin(trans(8))), trans(10) / Cos(ArcSin(trans(8))))
        Eulerx= Atan2custom(trans(1), trans(2))
    Else
        Eulerx= Atan2custom(-trans(1), -trans(2))
End Function
Private Function EulerAngles(ByRef AngelX As Double, ByRef AngelY As Double, ByRef AngelZ As Double )
    'convert from radian to degree
    	AngelX = Eulerx* RadToDeg
	AngelY = Eulery * RadToDeg
    	AngelZ = Eulerz() * RadToDeg
End Function
End Sub
#End Region
'than place component
' this works
Private Sub PlaceComponent (ByVal X As Double,ByVal Y As Double,ByVal Z As Double,ByVal oPath As String, ByRef NewItemName As String)
	If System.IO.File.Exists(oPath) Then
		Dim oAsmCompDef As AssemblyComponentDefinition
		Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
		Dim oMatrix As Matrix = oTG.CreateMatrix
		Dim oOccurrence As ComponentOccurrence
		'get user input
'		X = InputBox("Enter X", "Title", X)
'		Y = InputBox("Enter Y", "Title", Y)
'		Z = InputBox("Enter Z", "Title", Z)
		oMatrix.SetTranslation(oTG.CreateVector(X*convFactor, Y*convFactor, Z*convFactor))
		oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
		oOccurrence = oAsmCompDef.Occurrences.Add(oPath, oMatrix)
		ThisApplication.ActiveView.Fit
	Else
		MsgBox("File does not exist =  " & oPath)
End Sub
'than rotate
Sub RotateAroundAxis(ByVal NewItemName As String , ByRef ArrayRotationX As ArrayList , ByRef ArrayRotationY As ArrayList, ByRef ArrayRotationZ As ArrayList)
Replies (0)
