Ilogic save as dialog box does not overwrite file
02:21 AM
I am using the code below (from the blog From the trenches with Autodesk Inventor) to prompt the user to save the file. If they want to keep the same file name I get the dialog box "confirm save as" "Do you want to replace it" if I click "yes" it doesn't work.
Can you help?
'define the active document oDoc = ThisDoc.Document 'create a file dialog box Dim oFileDlg As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) 'check file type and set dialog filter If oDoc.DocumentType = kPartDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt" Else If oDoc.DocumentType = kAssemblyDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" Else If oDoc.DocumentType = kDrawingDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw" End If 'set the directory to open the dialog at oFileDlg.InitialDirectory = ThisDoc.WorkspacePath() 'set the file name string to use in the input box oFileDlg.FileName = ThisDoc.FileName(False) 'without extension 'work with an error created by the user backing out of the save oFileDlg.CancelError = True On Error Resume Next 'specify the file dialog as a save dialog (rather than a open dialog) oFileDlg.ShowSave() 'catch an empty string in the imput If Err.Number <> 0 Then MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled") ElseIf oFileDlg.FileName <> "" Then MyFile = oFileDlg.FileName 'save the file oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As End If
