im looking for an ilogic Rule,
thats starts the exisiting Inventor command "update properties" (in the Vault-Tab) with an ilogic Rule.
Ideally with automatic "OK" when window appears.
Can someone help
Thanks in advance,
Markus
Solved by chandra.shekar.g. Go to Solution.
Please try the below iLogic rule to update properties and activate "Ok" button automatically.
Dim updateCmd As ControlDefinition updateCmd = ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack") updateCmd.Execute Dim oKCmd As ControlDefinition oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd") oKCmd.Execute
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
