iLogic - obtain solid body name using selected feature
I'm writing a simple feature-rename script.
However i just can't figure out how to derive the solid body name from the selected feature.
example:
	For Each oExtrude In oDef.Features.ExtrudeFeatures
	oBody = oDef.SurfaceBodies.Item(1) 'obviously only gives the first solid as name
		oExtrude.Name = oBody.Name & " - Ext. " & extCount.ToString("00")
		extCount = extCount + 1
 	Next
I want to rename all extruded features to: SolidName - " Ext." followed by an increment.
Curtis_Waguespack
Hi @Anonymous
Welcome to the forum. Here is one method to do this.
I hope this helps.
Curtis
oDoc = ThisApplication.ActiveDocument
oBodies = oDoc.ComponentDefinition.SurfaceBodies
'look at the bodies
For Each oBody In oBodies
	i = 1
	'look at all the features that make up the body
	For Each oFeature In oBody.AffectedByFeatures
		'look at only extrude features
		If oFeature.Type = ObjectTypeEnum.kExtrudeFeatureObject Then
			'rename feature using solid name
			'and pad the number with zero if under 10
			oFeature.Name = oBody.Name _
			& " - Ext. " &  If(i < 10, "0" + CStr(i), CStr(i))
			i = i + 1
	Next
Next
ldellaversano
This function work only at first time, if i add a new feature and rerun the rule this doasn't work.
How can i resolve?
Curtis_Waguespack
Hi @ldellaversano
See this update.
I hope this helps.
Curtis
'look at the bodies
	For k = 1 To 2
		i = 1
				If k = 1 Then
					oFeature.Name = "Temp_" & i
				Else
					& " - Ext. " & If (i < 10, "0" + CStr(i), CStr(i))
				i = i + 1
		Next
	Next
Next
