Ilogic error member not found when access userparameters
I need some help on an error situation in Ilogic. I will explain how to reproduce the error. Any thoughts how to solve?
I defined an external Ilogic Rule only containing this code:
Dim doc as Document
Dim oMyParameter as UserParameters
doc = ThisApplication.ActiveDocument
oMyParameter = doc.ComponentDefinition.Parameters.UserParameters
When running the Rule after creating a new ipt all runs fine
Then creating new iam, Run Rule, immidiately  This error pops up:
Error in rule: MyPropertymanager, in document: ED150091.ipt
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Erorr is raised on the last line,
Thanks for any advise
best regards, martijn
LukeDavenport
Hi Martijn,
I think you need to treat assemblydocument and partdocument a little differently as shown below - that works fine for me.
Does that work?
Luke
 Dim oDoc As Document = ThisApplication.ActiveEditDocument
 Dim oPartDoc As PartDocument
 Dim oAsmDoc As AssemblyDocument
If oDoc.DocumentType = kPartDocumentObject Then
    MsgBox("Its a part",,"")
    oPartDoc = ThisApplication.ActiveEditDocument
    oMyParameter = oPartDoc.ComponentDefinition.Parameters.UserParameters
Else If oDoc.DocumentType = kAssemblyDocumentObject
    MsgBox("Its an assembly",,"")
    oAsmDoc = ThisApplication.ActiveEditDocument
    oMyParameter = oAsmDoc.ComponentDefinition.Parameters.UserParameters
MsgBox("User parameter count is " & oMyParameter.Count,,"")
Hi Luke,
Thank you very much for your quick response. This is the solution that works fine.
regards martijn
LukeDavenport
You're welcome Martijn.
DRoam
Hi @LukeDavenport, I was hoping you could shed some light on why treating parts and assemblies differently is necessary? I have some code that's doing the exact same thing for a mix of parts and assemblies, and I don't want to have to double up my code just to handle parts and assemblies individually.
If you could take a look at the new thread I opened up here and answer there, I would appreciate it.
LukeDavenport
Hi DRoam,
Its not necessary to treat parts and assemblies differently in this case, just my inexperience. I wish I could go back to my coding self 4 years ago and tell him that, but alas 🙂
Posted a suggestion on your thread.
Luke
