The Goal is to add a sheet (with the DWG AP Template)and insert the Top View of the Part into the sheet. I can add the sheet but am unable to use the template I want. It comes in as a C Size Sheet. Doesn't help I have a Nasty Cold. Any Help would be appreciated. Thanks.
Regardless of whether you want them filled in programatically or not, the AddSheet, AddTitleBlock, AddSketchedSymbol methods all EXPECT an array witha field for each prompted entry in said drawing entity.
So if your sheet is being added with a template that has prompted entry strings, you still need to feed the argument into the function to make it add without erring.
ie;
Dim sPromptStrings(0 To 1) As String sPromptStrings(0) = "" 'blank to "ignore it" sPromptStrings(1) = ""
oSheet.SketchedSymbols.Add(oSketchedSymbolDef,oInsertionPoint, 0, 1, sPromptStrings)
