iLogic Custom iProperties & Virtual Components
Hello
I have been trying to get standard Virtual parts working with all of the Custom iProperties we require for our Sage uploader.
I just have the last bit to get it all working nicely.
I need a "Short Description" preferably from the virtual parts description using Left("",20).
Can anyone help?
Here is the code so far:-
SubMain()
DimMyArrayListAsNewArrayList
MyArrayList = GoExcel.CellValues("\\MW-FS01\Inventor\Virtual Components.xlsx", "Adhesive", "A2", "A1000")
DimsVirtPartAsString
'get user input from list
sVirtPart = InputListBox("Select a virtual part to add.", _
MyArrayList, MyArrayList.Item(0), "iLogic", "Standard Virtual Parts")
'check for empty input in the case where the user cancels out of the input box
IfsVirtPart = ""Then
Return'end rule
Else
EndIf
'get iProperties from the XLS file
ForMyRow = 2 To 1000 'index row 2 through 1000
               'find the cell in column A that matches the user selection
                 IfsVirtPart = (GoExcel.CellValue("A"&MyRow))Then
           'get the iProperty from the XLS file for each coluGoExcel.CellValue("filename.xls", "Sheet1", "A2")mn
               oProp1 = GoExcel.CellValue("A"&MyRow )
           oProp2 = GoExcel.CellValue("C"&MyRow )
           oProp4 = GoExcel.CellValue("D"&MyRow)
           oProp5 = GoExcel.CellValue("E"&MyRow)
          ExitFor
           EndIf
Next
'get quantity from user
iQTY = InputBox("Enter the TOTAL number of:"_
& vbLf &"       ''"&sVirtPart&"''"_
& vbLf &"to place in the assembly."_
& vbLf & vbLf &"Note: Enter 0 to delete all existing instances.", "iLogic", "1")
IfiQTY = ""Then
Return'end rule
Else
EndIf
'define assembly
DimasmDocAsAssemblyDocument
asmDoc = ThisApplication.ActiveDocument
'define assembly Component Definition
DimoAsmCompDefAsAssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences in the assembly
DimasmOccAsComponentOccurrence
ForEachasmOccInoAsmCompDef.Occurrences
               'get name of occurence only (sees only everything left of the colon)
               DimoOccAsObject
           oOcc = asmOcc.Name.Split(":")(0)
           'look at only virtual components
               IfTypeOfasmOcc.DefinitionIsVirtualComponentDefinitionThen
                       'compare name selected from list to the
                               'existing virtual parts
                                IfoOcc = sVirtPartThen
                       'delete existing virtual parts if name matches
                               asmOcc.delete
                               Else
                       EndIf
           Else
           EndIf
Next
DimoccsAsComponentOccurrences
occs = asmDoc.ComponentDefinition.Occurrences
DimidentityAsMatrix
identity = ThisApplication.TransientGeometry.CreateMatrix
'create first instance of the virtual part
DimvirtOccAsComponentOccurrence
IfiQTY >= 1 Then
virtOcc = occs.AddVirtual(sVirtPart, identity)
           Try
           iProperties.Value(sVirtPart&":1", "Project", "Description") = oProp1
               Catch'catch error when oProp1 = nothing
               EndTry
           Try
         iProperties.Value(sVirtPart&":1", "Project", "Part Number") = oProp2
               Catch'catch error when oProp2 = nothing
               EndTry
           Try
           iProperties.Value(sVirtPart&":1", "Project", "Revision Number") = oProp3
               Catch'catch error when oProp3 = nothing
               EndTry
           Try
           iProperties.Value(sVirtPart&":1", "Project", "Vendor") = oProp4
               Catch'catch error when oProp4 = nothing
               EndTry
           Try
           iProperties.Value(sVirtPart&":1", "Summary", "Comments") = oProp5
               Catch'catch error when oProp5 = nothing
               EndTry
Else
Return
EndIf
'add next instance starting at instance2 (if applicable)
DimindexAsInteger
index = 2
DoWhileindex <= iQTY
occs.AddByComponentDefinition(virtOcc.Definition, identity)
index+= 1
Loop
CreateCustomIprop(virtOcc,"Made or Bought","B")
CreateCustomIprop(virtOcc,"Material Type","RM")
CreateCustomIprop(virtOcc,"Product Type","M101")
CreateCustomIprop(virtOcc,"Base Unit","KG")
CreateCustomIprop(virtOcc,"Short Description",(iProperties.Value("Project", "Description")))
End Sub
PrivateSubCreateCustomIprop(propertyOcc, propertyName, propertyValue)
customPropertySet = propertyOcc.definition.PropertySets.Item("Inventor User Defined Properties")
Try
prop = customPropertySet.Item(propertyName)
Catch
' Assume error means not found
prop = customPropertySet.Add("", propertyName)
EndTry
prop.Value = propertyValue
End Sub
adam.nagy
Autodesk Support
Autodesk Support
I'm not sure what your real question is because you already know what function you can use to get the first 20 characters of a string, and you are already getting properties from the virtual component.
Btw, you could also do it like this: iProperties.Value(virtOcc.Name, "Project", "Part Number")
Dim shortDesc = Left(iProperties.Value(virtOcc.Name, "Project", "Description"), 20)
Cheers,
Adam Nagy
Autodesk Platform Services
