iLogic - Create Text in Flat Pattern
I have a rule that creates text and then converts it to geometry. It creates a point in the center of the outer edge loop, and then writes the coordinates of that point to the definition of the point where the textbox is to be created(CreatePoint2d). The problem is that this is not always the same, in some cases the text box is inserted completely outside the flat pattern, even though the point in the center is created correctly.
The only difference between the components is that they have a different basic sketch. See attached pictures.
What am I doing wrong?
iLogic Rule:
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oFlatPattern As FlatPattern
oFlatPattern = ThisApplication.ActiveEditObject
Dim oFace As Face
oFace = oFlatPattern.TopFace
Dim oTG As TransientGeometry
Dim oSketch As PlanarSketch
Dim sText As String
Dim oTextBox As TextBox
oPath = Left(oPartDoc.FullDocumentName, InStrRev(oPartDoc.FullDocumentName, "\") -1)
oNazev = Mid(oPartDoc.FullDocumentName, Len(oPath) + 2, Len(oPartDoc.FullDocumentName) -Len(oPath) -5)
If Not oFace Is Nothing Then
Try
Dim oEdgeLoops As EdgeLoops
oEdgeLoops = oFace.EdgeLoops
Dim outerLoop As EdgeLoop
For Each outerLoop In oEdgeLoops
If outerLoop.IsOuterEdgeLoop Then
Exit For
Next
Dim oWorkPoint As WorkPoint
oWorkPoint = oFlatPattern.WorkPoints.AddAtCentroid(outerLoop, False)
oWorkPoint.Name = "Bod smyčky"
oSketch = oFlatPattern.Sketches.Add(oFace, False)
oSketch.AddByProjectingEntity(oWorkPoint)
oSketch.Name = "Vygravírovaný text"
oTG = ThisApplication.TransientGeometry
oBod = oTG.CreatePoint2d(oWorkPoint.Point.X, oWorkPoint.Point.Y)
sText = oNazev
oTextBox = oSketch.TextBoxes.AddFitted(oBod, sText)
oSketch.TextBoxes.Item(1).Style.Font = "ISOCP"
oSketch.TextBoxes.Item(1).Style.FontSize = 0.2
With oTextBox
.VerticalJustification = kAlignTextMiddle
.HorizontalJustification = kAlignTextLeft
End With
Catch
Dim oPoint As Point
oPoint = oFlatPattern.MassProperties.CenterOfMass
sText = oNazev
oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oPoint.X, oPoint.Y), sText)
With oTextBox
End With
End Try
oTextBox.ConvertToGeometry("isocp")
End Sub
This is how it should be: Sketch in the center
But on the other sheet - there is y coordinate wrong
And another - there is X coordinate wrong
I also attached the sheets.
Thanks for any suggestion.
Inventor Professional 2021
