i got a question about the change of iproperties in a assembly. My assembly contains sub-assemblys on different levels and i want to change every .ipt part number to a part of the filename.
The first Rule i got:
iProperties.Value("Project", "Part Number") = Split(ThisDoc.FileName(False),"-")(+1)
and the idea to get it in all .ipt´s:
'Define the open document Dim openDoc As Document openDoc = ThisDoc.Document Dim docFile As Document 'kAssemblyDocumentObject = 12291 If openDoc.DocumentType = 12291 Then 'Iterate though the part files in the assembly For Each docFile In openDoc.AllReferencedDocuments 'kPartDocumentObject = 12290 If docFile.DocumentType = 12290 Then 'set part number to file name (without extension) If docFile.FileName(False) = "*-*-*" Then docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = Split(ThisDoc.FileName(False),"-")(+1) End If End If Next Else MessageBox.Show("Use Assembly") End If
All i get is "system.missingmemberexception no default member found for file name". It would be great if somebody here could help me with this problem.
Solved by MechMachineMan. Go to Solution.
Try:
System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) instead of oDoc.FileName
Also,
add a try/catch around the fetching of the filename in case the file has not been saved yet.
Good luck.
