ilogic change size of active sheet
tkch.ndq
tkch.ndq
Hi everyone, wish you all have good day.
I am beginner with ilogic Inventor and have an issue need your help if possible.
I only use sheet size: A0, A1, A2, A3, A4
I've created 5 title blocks with name: A0-TTBL, A1-TTBL, A2-TTBL, A3-TTBL, A4-TTBL
I've created 5 dimension styles with name: A0-DST, A1-DST, A2-DST, A3-DST, A4-DST
I've created 5 Leader styles with name: A0-LD, A1-LD, A2-LD, A3-LD, A4-LD
I've created 5 View Annotation styles with name: A0-VA, A1-VA, A2-VA, A3-VA, A4-VA
I'd like to click on itrigger when I need to change size of active sheet on IDW file then with a list A0, A1, A2, A3, A4 that I can choose the sheet size.
The default template is A3 sheet size with: title block A3-TTBL with dim style A3-DST with leader style A3-LD with View annotation style A3-AV
Is there any ilogic that can help me so when I change size of active sheet to other sizes then title block + dimension style + leader style + view annotation style are changed automatically too?
Please help me.
Thanks so much in advance!
SharkDesign
Your sheet size looks pretty simple
ActiveSheet.ChangeSize("A3", moveBorderItems := True)
Not sure about changing all the active styles though
  Inventor Certified Professional
SharkDesign
By the way, the Inventor customisation forum is the best place for iLogic questions.
tkch.ndq
Thank you very much for your help but as I told before, I am beginner so I cannot make a complete code. That's why I don't know how to use the code you gave. By the way, I don't need to change boder, I'd like to change title block, dimstyle, leader and view annotation.
tkch.ndq
Thank you very much for your guide, I posted this issue on Inventor Customization forum.
