I attached my entire assembly, this way you can actually look at the code for yourself. The issue is with the code in the "EVENTTRIGGERRULE". There are two separate actions happening, the first code is triggered when either "sewn" or "formed" is selected in the form. Then It will determine which parts are active and set them either to Phantom or Normal based on whether sewn or formed was chosen. The issue is that it does not always update correctly and I have checked the code but it looked all right.
The second part of the code is triggered by the inputs of "Collar1" and "Collar2" in the form, this is a numerical input. Based of the inputs it will choose the correct clamp to use based on the input size and if it is over 12" then It will determine the quantity of clamps based on the Variable parameters. Anything under 12" uses 1 clamp. So the issue is that the BOM will not update the quantities when the clamp is over 12". I tried using event triggers but It is still having issues.
I would really appreciate some help because I have tried everything I could think of.
Thank you,
Cameron
You seem to be missing a bit of logic from the two lines:
If O_CLAMP Then
which is causing an error
Sorry, ignore that last comment.
I'm getting an error on this line of code:
ThisBOM.OverrideQuantity("Model Data","11000138", 2)
Not sure why yet, the error message isn't very helpful
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
I found that if I separate the component.active code from the this.bom code into separate IF Statements it does a better job at updating the BOM quantities.
'Clamp 48>ID<=60
ElseIf (60>=O_COLLAR2 And O_COLLAR2>48) Then
If (10>=VARIABLE_8 And VARIABLE_8>8.25) Then
Component.IsActive("11000138") = True
'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138")
'ThisBOM.OverrideQuantity("Model Data","11000138", 5)
ElseIf (12>=VARIABLE_8 And VARIABLE_8>10) Then
Component.IsActive("11000071") = True
'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071")
'ThisBOM.OverrideQuantity("Model Data","11000071", 5)
End If
End If
End If
'Clamp 48>ID<=60
End If
End If
End If
That code is working good so far, but now I'm getting this error when I save my drawing.
Post your currently code up here using the proper
this
and I can see If I can help.
'TURNING COLLAR PARTS PHANTOM WHEN BELLOWS TYPE = FORMED If O_COLLAR_SEWING_TYPE= "FORMED" Then ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Ilogic").Activate iLogicVb.UpdateWhenDone=True ' set a reference to the assembly component definintion Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition If Component.IsActive("ROUND_FLANGE1")=True Then Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE1") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("ROUND_FLANGE2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE2") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("ROUND_FLANGE3")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE3") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("ROUND_FLANGE4")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE4") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("ROUND_COLLAR1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_COLLAR1") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("ROUND_COLLAR2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_COLLAR2") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("EXPANDED_COLLAR1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("EXPANDED_COLLAR1") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("EXPANDED_COLLAR2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("EXPANDED_COLLAR2") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("CONE_END1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("CONE_END1") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If If Component.IsActive("CONE_END2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("CONE_END2") = True Then oOccurrence.Definition.BOMStructure = 51971 'Phantom End If Next End If End If If O_COLLAR_SEWING_TYPE= "SEWN" Then ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Ilogic").Activate iLogicVb.UpdateWhenDone=True ' set a reference to the assembly component definintion Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition If Component.IsActive("ROUND_FLANGE1")=True Then Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE1") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("ROUND_FLANGE2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE2") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("ROUND_FLANGE3")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE3") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("ROUND_FLANGE4")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_FLANGE4") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("ROUND_COLLAR1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_COLLAR1") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("ROUND_COLLAR2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("ROUND_COLLAR2") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("EXPANDED_COLLAR1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("EXPANDED_COLLAR1") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("EXPANDED_COLLAR2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("EXPANDED_COLLAR2") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("CONE_END1")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("CONE_END1") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If If Component.IsActive("CONE_END2")=True Then For Each oOccurrence In oAsmCompDef.Occurrences If oOccurrence.Name.Contains("CONE_END2") = True Then oOccurrence.Definition.BOMStructure = 51970 'NORMAL End If Next End If End If '------------------------------------------------------------------------------------------------------------------------------------------------------------------ 'VARIABLE SWITCH COLLAR1 If (24>=O_COLLAR1 And O_COLLAR1>12) Then VARIABLE_1 = O_COLLAR1/2 Else VARIABLE_1=0 End If If (36>=O_COLLAR1 And O_COLLAR1>24) Then VARIABLE_3 = O_COLLAR1/3 Else VARIABLE_3 = 0 End If If (48>=O_COLLAR1 And O_COLLAR1>36) Then VARIABLE_5 = O_COLLAR1/4 Else VARIABLE_5 = 0 End If If (60>=O_COLLAR1 And O_COLLAR1>48) Then VARIABLE_7 = O_COLLAR1/5 Else VARIABLE_7= 0 End If 'VARIABLE SWITCH COLLAR2 If (24>=O_COLLAR2 And O_COLLAR2>12) Then VARIABLE_2 = O_COLLAR2/2 Else VARIABLE_2=0 End If If (36>=O_COLLAR2 And O_COLLAR2>24) Then VARIABLE_4 = O_COLLAR2/3 Else VARIABLE_4 = 0 End If If (48>=O_COLLAR2 And O_COLLAR2>36) Then VARIABLE_6 = O_COLLAR2/4 Else VARIABLE_6 = 0 End If If (60>=O_COLLAR2 And O_COLLAR2>48) Then VARIABLE_8 = O_COLLAR2/5 Else VARIABLE_8 = 0 End If 'CLAMP SELECTION SEWN O_COLLAR1 CODE Component.IsActive("11000063") = False Component.IsActive("11000064") = False Component.IsActive("11000065") = False Component.IsActive("11000066") = False Component.IsActive("11000067") = False Component.IsActive("11000068") = False Component.IsActive("11000069") = False Component.IsActive("11000070") = False Component.IsActive("11000071") = False Component.IsActive("11000138") = False If O_CLAMP Then If (O_COLLAR1<= 1.25) And O_COLLAR1> 0 Then'Or (O_COLLAR2<=1.25) Then Component.IsActive("11000063") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000063") ElseIf (1.75>=O_COLLAR1 And O_COLLAR1>1.25) Then'Or (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then Component.IsActive("11000064") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000064") ElseIf (2.25>=O_COLLAR1 And O_COLLAR1>1.75)Then' Or (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then Component.IsActive("11000065") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000065") ElseIf (2.75>=O_COLLAR1 And O_COLLAR1>2.25)Then' Or (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then Component.IsActive("11000066") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000066") ElseIf (4>=O_COLLAR1 And O_COLLAR1>2.75)Then' Or (4>=O_COLLAR2 And O_COLLAR2>2.75) Then Component.IsActive("11000067") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000067") ElseIf (6>=O_COLLAR1 And O_COLLAR1>4) Then'Or (6>=O_COLLAR2 And O_COLLAR2>4) Then Component.IsActive("11000068") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000068") ElseIf (7>=O_COLLAR1 And O_COLLAR1>6) Then'Or (7>=O_COLLAR2 And O_COLLAR2>6) Then Component.IsActive("11000069") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") ElseIf (8.25>=O_COLLAR1 And O_COLLAR1>7) Then'Or (8.25>=O_COLLAR2 And O_COLLAR2>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") ElseIf (10>=O_COLLAR1 And O_COLLAR1>8.25)Then' Or (10>=O_COLLAR2 And O_COLLAR2>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") ElseIf (12>=O_COLLAR1 And O_COLLAR1>10)Then' Or (12>=O_COLLAR2 And O_COLLAR2>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'O_CLAMP >12ID<=24 ElseIf (24>=O_COLLAR1 And O_COLLAR1>12) Then'Or (24>=O_COLLAR2 And O_COLLAR2>12) Then If (7>=VARIABLE_1 And VARIABLE_1>6)Then' Or (7>=VARIABLE_2 And VARIABLE_2>6) Then Component.IsActive("11000069") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") 'ThisBOM.OverrideQuantity("Model Data","11000069", 2) ElseIf (8.25>=VARIABLE_1 And VARIABLE_1>7) Then'Or (8.25>=VARIABLE_2 And VARIABLE_2>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") 'ThisBOM.OverrideQuantity("Model Data","11000070",2) ElseIf (10>=VARIABLE_1 And VARIABLE_1>8.25)Then' Or (10>=VARIABLE_2 And VARIABLE_2>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 2) ElseIf (12>=VARIABLE_1 And VARIABLE_1>10) Then'Or (12>=VARIABLE_2 And VARIABLE_2>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 2) End If 'Clamp 24>ID<=36 ElseIf (36>=O_COLLAR1 And O_COLLAR1>24) Then'Or (36>=O_COLLAR2 And O_COLLAR2>24) Then If (8.25>=VARIABLE_3 And VARIABLE_3>7) Then'Or (8.25>=VARIABLE_4 And VARIABLE_4>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") 'ThisBOM.OverrideQuantity("Model Data","11000070", 3) ElseIf (10>=VARIABLE_3 And VARIABLE_3>8.25)Then' Or (10>=VARIABLE_4 And VARIABLE_4>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 3) ElseIf (12>=VARIABLE_3 And VARIABLE_3>10)Then' Or (12>=VARIABLE_4 And VARIABLE_4>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 3) End If 'Clamp 36>ID<=48 ElseIf (48>=O_COLLAR1 And O_COLLAR1>36) Then'Or (48>=O_COLLAR2 And O_COLLAR2>36) Then If (10>=VARIABLE_5 And VARIABLE_5>8.25) Then'Or (10>=VARIABLE_6 And VARIABLE_6>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 4) ElseIf (12>=VARIABLE_5 And VARIABLE_5>10) Then'Or (12>=VARIABLE_6 And VARIABLE_6>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 4) End If 'Clamp 48>ID<=60 ElseIf (60>=O_COLLAR1 And O_COLLAR1>48) Then'Or (60>=O_COLLAR2 And O_COLLAR2>48) Then If (10>=VARIABLE_7 And VARIABLE_7>8.25) Then'Or (10>=VARIABLE_8 And VARIABLE_8>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 5) ElseIf (12>=VARIABLE_7 And VARIABLE_7>10) Then'Or (12>=VARIABLE_8 And VARIABLE_8>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 5) End If End If End If 'COLLAR 2 If O_CLAMP Then If (O_COLLAR2<=1.25) And O_COLLAR2> 0 Then Component.IsActive("11000063") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000063") ElseIf (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then Component.IsActive("11000064") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000064") ElseIf (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then Component.IsActive("11000065") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000065") ElseIf (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then Component.IsActive("11000066") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000066") ElseIf (4>=O_COLLAR2 And O_COLLAR2>2.75) Then Component.IsActive("11000067") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000067") ElseIf (6>=O_COLLAR2 And O_COLLAR2>4) Then Component.IsActive("11000068") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000068") ElseIf (7>=O_COLLAR2 And O_COLLAR2>6) Then Component.IsActive("11000069") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") ElseIf (8.25>=O_COLLAR2 And O_COLLAR2>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") ElseIf (10>=O_COLLAR2 And O_COLLAR2>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") ElseIf (12>=O_COLLAR2 And O_COLLAR2>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'O_CLAMP >12ID<=24 ElseIf (24>=O_COLLAR2 And O_COLLAR2>12) Then If (7>=VARIABLE_2 And VARIABLE_2>6) Then Component.IsActive("11000069") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") 'ThisBOM.OverrideQuantity("Model Data",11000069, 2) ElseIf (8.25>=VARIABLE_2 And VARIABLE_2>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") 'ThisBOM.OverrideQuantity("Model Data",11000070,2) ElseIf (10>=VARIABLE_2 And VARIABLE_2>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 2) ElseIf (12>=VARIABLE_2 And VARIABLE_2>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071",2) End If 'Clamp 24>ID<=36 ElseIf (36>=O_COLLAR2 And O_COLLAR2>24) Then If (8.25>=VARIABLE_4 And VARIABLE_4>7) Then Component.IsActive("11000070") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") 'ThisBOM.OverrideQuantity("Model Data","11000070", 3) ElseIf (10>=VARIABLE_4 And VARIABLE_4>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 3) ElseIf (12>=VARIABLE_4 And VARIABLE_4>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 3) End If 'Clamp 36>ID<=48 ElseIf (48>=O_COLLAR2 And O_COLLAR2>36) Then If (10>=VARIABLE_6 And VARIABLE_6>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 4) ElseIf (12>=VARIABLE_6 And VARIABLE_6>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 4) End If 'Clamp 48>ID<=60 ElseIf (60>=O_COLLAR2 And O_COLLAR2>48) Then If (10>=VARIABLE_8 And VARIABLE_8>8.25) Then Component.IsActive("11000138") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") 'ThisBOM.OverrideQuantity("Model Data","11000138", 5) ElseIf (12>=VARIABLE_8 And VARIABLE_8>10) Then Component.IsActive("11000071") = True 'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") 'ThisBOM.OverrideQuantity("Model Data","11000071", 5) End If End If End If '---------------------------------------------------------------------------------------------------------------------------------------------- 'O_CLAMP >12ID<=24 If O_CLAMP Then If (O_COLLAR1<= 1.25) And O_COLLAR1> 0 Then'Or (O_COLLAR2<=1.25) Then 'Component.IsActive("11000063") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000063") ElseIf (1.75>=O_COLLAR1 And O_COLLAR1>1.25) Then'Or (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then 'Component.IsActive("11000064") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000064") ElseIf (2.25>=O_COLLAR1 And O_COLLAR1>1.75)Then' Or (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then 'Component.IsActive("11000065") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000065") ElseIf (2.75>=O_COLLAR1 And O_COLLAR1>2.25)Then' Or (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then 'Component.IsActive("11000066") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000066") ElseIf (4>=O_COLLAR1 And O_COLLAR1>2.75)Then' Or (4>=O_COLLAR2 And O_COLLAR2>2.75) Then 'Component.IsActive("11000067") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000067") ElseIf (6>=O_COLLAR1 And O_COLLAR1>4) Then'Or (6>=O_COLLAR2 And O_COLLAR2>4) Then 'Component.IsActive("11000068") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000068") ElseIf (7>=O_COLLAR1 And O_COLLAR1>6) Then'Or (7>=O_COLLAR2 And O_COLLAR2>6) Then 'Component.IsActive("11000069") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") ElseIf (8.25>=O_COLLAR1 And O_COLLAR1>7) Then'Or (8.25>=O_COLLAR2 And O_COLLAR2>7) Then 'Component.IsActive("11000070") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") ElseIf (10>=O_COLLAR1 And O_COLLAR1>8.25)Then' Or (10>=O_COLLAR2 And O_COLLAR2>8.25) Then 'Component.IsActive("11000138") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") ElseIf (12>=O_COLLAR1 And O_COLLAR1>10)Then' Or (12>=O_COLLAR2 And O_COLLAR2>10) Then 'Component.IsActive("11000071") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") ElseIf (24>=O_COLLAR1 And O_COLLAR1>12) Then'Or (24>=O_COLLAR2 And O_COLLAR2>12) Then If (7>=VARIABLE_1 And VARIABLE_1>6)Then' Or (7>=VARIABLE_2 And VARIABLE_2>6) Then ThisBOM.OverrideQuantity("Model Data","11000069", 2) ElseIf (8.25>=VARIABLE_1 And VARIABLE_1>7) Then'Or (8.25>=VARIABLE_2 And VARIABLE_2>7) Then ThisBOM.OverrideQuantity("Model Data","11000070",2) ElseIf (10>=VARIABLE_1 And VARIABLE_1>8.25)Then' Or (10>=VARIABLE_2 And VARIABLE_2>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 2) ElseIf (12>=VARIABLE_1 And VARIABLE_1>10) Then'Or (12>=VARIABLE_2 And VARIABLE_2>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 2) End If 'Clamp 24>ID<=36 ElseIf (36>=O_COLLAR1 And O_COLLAR1>24) Then'Or (36>=O_COLLAR2 And O_COLLAR2>24) Then If (8.25>=VARIABLE_3 And VARIABLE_3>7) Then'Or (8.25>=VARIABLE_4 And VARIABLE_4>7) Then ThisBOM.OverrideQuantity("Model Data","11000070", 3) ElseIf (10>=VARIABLE_3 And VARIABLE_3>8.25)Then' Or (10>=VARIABLE_4 And VARIABLE_4>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 3) ElseIf (12>=VARIABLE_3 And VARIABLE_3>10)Then' Or (12>=VARIABLE_4 And VARIABLE_4>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 3) End If 'Clamp 36>ID<=48 ElseIf (48>=O_COLLAR1 And O_COLLAR1>36) Then'Or (48>=O_COLLAR2 And O_COLLAR2>36) Then If (10>=VARIABLE_5 And VARIABLE_5>8.25) Then'Or (10>=VARIABLE_6 And VARIABLE_6>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 4) ElseIf (12>=VARIABLE_5 And VARIABLE_5>10) Then'Or (12>=VARIABLE_6 And VARIABLE_6>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 4) End If 'Clamp 48>ID<=60 ElseIf (60>=O_COLLAR1 And O_COLLAR1>48) Then'Or (60>=O_COLLAR2 And O_COLLAR2>48) Then If (10>=VARIABLE_7 And VARIABLE_7>8.25) Then'Or (10>=VARIABLE_8 And VARIABLE_8>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 5) ElseIf (12>=VARIABLE_7 And VARIABLE_7>10) Then'Or (12>=VARIABLE_8 And VARIABLE_8>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 5) End If End If End If 'COLLAR 2 If O_CLAMP Then 'O_CLAMP >12ID<=24 If (O_COLLAR2<=1.25)And O_COLLAR2> 0 Then 'Component.IsActive("11000063") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000063") ElseIf (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then 'Component.IsActive("11000064") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000064") ElseIf (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then 'Component.IsActive("11000065") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000065") ElseIf (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then 'Component.IsActive("11000066") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000066") ElseIf (4>=O_COLLAR2 And O_COLLAR2>2.75) Then 'Component.IsActive("11000067") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000067") ElseIf (6>=O_COLLAR2 And O_COLLAR2>4) Then 'Component.IsActive("11000068") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000068") ElseIf (7>=O_COLLAR2 And O_COLLAR2>6) Then 'Component.IsActive("11000069") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000069") ElseIf (8.25>=O_COLLAR2 And O_COLLAR2>7) Then 'Component.IsActive("11000070") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000070") ElseIf (10>=O_COLLAR2 And O_COLLAR2>8.25) Then 'Component.IsActive("11000138") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000138") ElseIf (12>=O_COLLAR2 And O_COLLAR2>10) Then 'Component.IsActive("11000071") = True quantity = ThisBOM.CalculateQuantity("Model Data", "11000071") ElseIf (24>=O_COLLAR2 And O_COLLAR2>12) Then If (7>=VARIABLE_2 And VARIABLE_2>6) Then ThisBOM.OverrideQuantity("Model Data","11000069", 2) ElseIf (8.25>=VARIABLE_2 And VARIABLE_2>7) Then ThisBOM.OverrideQuantity("Model Data","11000070",2) ElseIf (10>=VARIABLE_2 And VARIABLE_2>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 2) ElseIf (12>=VARIABLE_2 And VARIABLE_2>10) Then ThisBOM.OverrideQuantity("Model Data","11000071",2) End If 'Clamp 24>ID<=36 ElseIf (36>=O_COLLAR2 And O_COLLAR2>24) Then If (8.25>=VARIABLE_4 And VARIABLE_4>7) Then ThisBOM.OverrideQuantity("Model Data","11000070", 3) ElseIf (10>=VARIABLE_4 And VARIABLE_4>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 3) ElseIf (12>=VARIABLE_4 And VARIABLE_4>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 3) End If 'Clamp 36>ID<=48 ElseIf (48>=O_COLLAR2 And O_COLLAR2>36) Then If (10>=VARIABLE_6 And VARIABLE_6>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 4) ElseIf (12>=VARIABLE_6 And VARIABLE_6>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 4) End If 'Clamp 48>ID<=60 ElseIf (60>=O_COLLAR2 And O_COLLAR2>48) Then If (10>=VARIABLE_8 And VARIABLE_8>8.25) Then ThisBOM.OverrideQuantity("Model Data","11000138", 5) ElseIf (12>=VARIABLE_8 And VARIABLE_8>10) Then ThisBOM.OverrideQuantity("Model Data","11000071", 5) End If End If End If
If you are using this with iTriggers it is HIGHLY, HIGHLY recommended you go back through the code and replace
with
ThisDoc.Document
Using the latter ensures that the rule grabs the document that the rule was triggered in, not the document that is at the forefront of the screen.
Also, add this at the very start:
If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject Then MsgBox("Rule only for assemblies; was triggered to run for: " & vblf & vblf & _ ThisDoc.Document.FullFileName & vblf & vblf & _ "... Aborting Rule!") Exit Sub End if
Nah, AFAIK event triggers are fine. Same deal required with switching to ThisDoc vs ActiveDoc though.
I'm getting this error when I save my drawing now. I get it around 20 times, I have to keep clicking ok till it stops.
Debug and find out what is making it error.
In iLogic, you can do this by placing
MsgBox("Made it to here 1")
or something similar within the code to see the last line that runs before it fails.
Also, if it is run on am assembly file that hasn't been saved yet, it will give an error.
