How to get the intersection Point between a curve and a curve
spascual
spascual
Hi Sirs,
I have been looking for a method to get intersection between two curves, but I have not found in API.
Any idea wellcome ¡¡¡¡
wayne.brill
I am not sure if I fully understand what you need to do.
Does TransientGeometry.CurveCurveIntersection() help?
Here is a VBA example that is an update to one of the examples in the Programming help.
Public Sub DrawSketchLine()
    ' Check to make sure a sketch is open.
    If Not TypeOf ThisApplication.activeEditObject Is PlanarSketch Then
      MsgBox "A sketch must be active."
      Exit Sub
    ' Set a reference to the active sketch.
    Dim oSketch As PlanarSketch
    Set oSketch = ThisApplication.activeEditObject
    ' Set a reference to the transient geometry collection.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    ' Create a new transaction to wrap the construction of the three lines
    ' into a single undo.
    Dim oTrans As Transaction
    Set oTrans = ThisApplication.TransactionManager.StartTransaction( _
    ThisApplication.ActiveDocument, _
    "Create Triangle Sample")
     Dim oLines(1 To 3) As SketchLine
    Set oLines(1) = oSketch.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(0, 0), _
    oTransGeom.CreatePoint2d(4, 0))
    Set oLines(2) = oSketch.SketchLines.AddByTwoPoints(oLines(1).EndSketchPoint, _
    oTransGeom.CreatePoint2d(2, 3))
     Set oLines(3) = oSketch.SketchLines.AddByTwoPoints(oLines(2).EndSketchPoint, _
    oTransGeom.CreatePoint2d(2, -2))
    ' End the transaction for the triangle.
    oTrans.End
    Dim olineSeg_1 As LineSegment
    Set olineSeg_1 = oLines(1).Geometry3d
    Dim olineSeg_2 As LineSegment
    Set olineSeg_2 = oLines(3).Geometry3d
    Dim objsEnum As ObjectsEnumerator
    Set objsEnum = oTransGeom.CurveCurveIntersection(olineSeg_1, olineSeg_2)
End Sub
When I run that code the ObjectsEnumerator finds one point. (Screnshot below of the VBA Watch window.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
