how to change appearance of part or assambly with Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 18
How do I change appearance  with use of Ilogic?   I need a code for both IPT file and Iam file
Replies (17)
Message 2 of 18
Sergio.D.Suárez
Hi, here I send you two codes, the first changes the appearance of each part from assembly, at the level of the part (as if you open the part and change the color)
Dim oAsset As Asset
Dim oAsset_Array As New ArrayList
For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
oAsset_Array.Add(oAsset_Array_X.DisplayName)
oAsset_Array.Sort()
Next
'present the user with the list to choose from
100:
oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
If oAsset_Array_Selected = "" Then GoTo 100 :
Dim comps As ObjectCollection
Dim comp As Object
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
	comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a component")
	' If nothing gets selected then we're done
	If IsNothing(comp) Then Exit While
	comps.Add(comp)
End While
' If there are selected components we can do something
For Each comp In comps
	Dim oDef As PartDocument
    oDef = comp.Definition.Document
    Dim oRenderStyle As RenderStyle
    oRenderStyle = oDef.RenderStyles.Item(oAsset_Array_Selected)
    oDef.ActiveRenderStyle = oRenderStyle
    iLogicVb.UpdateWhenDone = True
Next
the second changes the appearance of the part or assembly at the level of assembly (the part maintains the color of origin)
Dim oAsset As Asset
oAsset_Array.Sort()
Next
100:
Dim comp As Object
While True
comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component")  'kAssemblyOccurrenceFilter. kAssemblyLeafOccurrenceFilter
comps.Add(comp)
End While
	Component.Color(comp.name)=oAsset_Array_Selected
Next
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 18
Thanks for the code... it is not what I needed
I need a code that I can add to I if stement that I already have ...
when I force the user to select betwine Colour 1 and Colour 2 and Galz
in the if statment
If you selece Colour 1
Change appearance of this part or assambly to "Ral 7035"
If you selece Colour 2
Change appearance of this part or assambly to "Ral 7037"
If you selece Galz.
Change appearance of this part or assambly to "Galvanized"
I only want to change the top level ... not the assambly or part in the assambly
I use this in a before save ilogic code
Message 4 of 18
This is a code that just probes and works for me, it is by way of example. Need to add select an occurrence and then create a list of the two colors
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPart As ComponentOccurrence
'Pick part occurrence
oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Seleccione Pieza")
	If oPart Is Nothing Then
		Exit Sub
	Else
		Dim oValueList As New ArrayList
			oValueList.Add("Colour 1")
			oValueList.Add("Colour 2")
		Dim oValue As String
			'get user input
			oValue = InputListBox("Select colour", oValueList, "Colour 1", "Customizar Plantilla", "Selecciones Disponibles")
		If oValue = "Colour 1" Then
			Component.Color(oPart.Name)="Magenta"
		If oValue = "Colour 2" Then
			Component.Color(oPart.Name)="Negro"
end if
 ,you do not need to copy all this code, you should copy a line like this inside the "If then end if"
Component.Color("Occurrence")="chosen colour"
You must make sure that the chosen color belongs to the current appearance library, otherwise you must specify it
Mechanical Designer
Message 5 of 18
Can´t get it to work .. how can it be so hard just to change color of a part
and for the same when it goes for assembly.
both at top level...
no seletect ingen ,... no list ...
just change change the appearance on the part  or Assambl that you are saving right now .. it may need 2 illogic code .. one for part and one for assembly ... it is just 2 click with the mouse .. so it most be simple but I do not know the code for it
Message 6 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy ,
Try below iLogic code for assembly document.
        Dim oAssyDoc As AssemblyDocument
	oAssyDoc = ThisApplication.ActiveDocument
	'define the appearance library
	Dim oLib As AssetLibrary
	oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
	'make sure colors are in assembly doc
	Dim libAsset As Asset
	libAsset = oLib.AppearanceAssets.Item("Steel")
	Dim localAsset As Asset
	Try
		localAsset = oAssyDoc.Assets.Item("Steel")
	Catch
		localAsset = libAsset.CopyTo(oAssyDoc)
	End Try
oAssyDoc.ActiveAppearance = localAsset
For Part Document
Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	Try
		localAsset = oPartDoc.Assets.Item("Steel")
	Catch
		localAsset = libAsset.CopyTo(oPartDoc)
	End Try
	oPartDoc.ActiveAppearance = localAsset
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 18
I have only test the part function so far ... it is working as i want it to... have not have time to test the assambly jet
Message 8 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
if it is working for PartDocument, it should work for Assembly as well.
Please let me know if it is not working.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 18
I can´t get it to work.. it seems that you have to change colour on en asammebly componemt(hope it is the right word)  not on some the hole assembly as you can with the part.. think it might have to you a while loop to go throungt all of them one by one... hope it can be not on only the toplevel.. not all the way down in the sub assembly.
You know how to do that ?
Message 10 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
It seems that appearance of assembly is not allowed to change through UI. Can you please confirm the same?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 18
Hi.
I also found it is not working. I moved steel from library to favorites. then it worked. Only for the part, anyway.
Message 12 of 18
ice_sid
Thank you so much for your work.
Message 13 of 18
_KarlH
@Sergio.D.Suárez- I can't thank you enough. I've searched far and wide to find a method to update a parts appearance from within an assembly based iLogic rule - and you've given the perfect example of how to do so.
ActiveRenderStyle
ActiveRenderStyle! Not Color, or PartColor, or Appearance, or iProperty.Color.Appearance. ... no, it was "ActiveRenderStyle" all along!!! No wonder I'm losing my hair...
Thank you kindly again!
Message 14 of 18
This is a very old tread .. but I have develope  something like I wanted  today . I will try add some of the code seens I have add a lot more to the code today .. hope you can use it ... If need more of help to use it for your project .. write here again and I will try to make a code that work for you
Sub AddsurfaceAssembly()
	Dim NameList As New ArrayList()
NameList.Add("Raw")
'NameList.Add("------------------------------------------------------------------------------")
NameList.Add("Colour 1		Basic colour for chassis, etc.")'Colour Ral 7035 OR RAL 9010
NameList.Add("Colour 2 		Basic colour for moving parts.")'Colour Ral 7037 OR RAL 5003
NameList.Add("RAL 1028	Melon yellow")
NameList.Add("RAL 5003 	Sapphire blue")
NameList.Add("RAL 9005	Jet black")
NameList.Add("RAL 9010 	Pure white")
NameList.Add("Electro galvanized	Preferable/Cheapest")'Eletro Galvanizes
NameList.Add("Hot dip galvanized 	Outdoor Use")'Hot Dip galvanized
NameList.Add("Hardened	Set specifications on Drawing")
NameList.Add("Glassblasted")
NameList.Add("Sandblasted")
'NameList.Add("Shot blasted")
'NameList.Add("Pickled")
'NameList.Add("Do not select")
Dim msg As String
	msg = ("Surface needed - Select Surface " & vbLf & "Part Numner: "+iProperties.Value("Project", "Part Number")& vbLf & "Description: "+iProperties.Value("Project", "Description")& vbLf & "Title: "+ iProperties.Value("Summary", "Title")& vbLf).ToString
	d0 = InputListBox(msg, NameList, d0, Title := "Info - Surface needed", ListName := "Surface")
	' iProperties.Value("Custom", "Surface") = d0
	'Tilføj farve
	 If d0 = "Do not select" Then
	 Else
	TextToSurface(d0)
	 'iProperties.Value("Custom", "Surface") = d0
	'find Document type
	Dim doc = ThisDoc.Document
	Dim sDocumentSubType As String = doc.SubType
	If sDocumentSubType <> "{4D29B490-49B2-11D0-93C3-7E0706000000}"  And  sDocumentSubType <>"{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then '  = "Part"
	debug("Colour Assambly")
	Try
	Dim oAsmCompDef 'As AssemblyComponentDefinition
	debug("Loading Variable Finish 0,5")
debug("Loading Variable Finish 1")
'define view rep collection
Dim oViewReps As DesignViewRepresentations
oViewReps = oAsmCompDef.RepresentationsManager.DesignViewRepresentations
debug("Loading Variable Finish 2")
'define view rep
Dim oViewRep As DesignViewRepresentation
debug("Loading Variable Finish 3")
Dim NumberOfView = oViewReps.Count
' get Manager of Representations
debug("Loading Variable Finish 4")
 Dim dViewRepMgr As RepresentationsManager
 dViewRepMgr = oAsmCompDef.RepresentationsManager
 debug("Loading Variable Finish 5")
 'Get active Representation View
 Dim dViewRep As DesignViewRepresentation
 dViewRep = dViewRepMgr.ActiveDesignViewRepresentation
 debug("Loading Variable Finish 6")
 debug("Loading Variable Finish")
 Try
For i = 1 To NumberOfView
	If iProperties.Value("Custom", "Surface") = "Raw" Or iProperties.Value("Custom", "Surface") = "Galv." Or iProperties.Value("Custom", "Surface") = "Colour 1" Or iProperties.Value("Custom", "Surface") = "Colour 2" Or iProperties.Value("Custom", "Surface") = "RAL 5003" Or iProperties.Value("Custom", "Surface") = "RAL 9010" Or iProperties.Value("Custom", "Surface") = "RAL 1028" Or iProperties.Value("Custom", "Surface") = "RAL 9005"  Or iProperties.Value("Custom", "Surface") = "EG-Galv" Or iProperties.Value("Custom", "Surface") = "HDG-Galv"  Then
debug("chance view")
oViewReps.Item(i).Activate
End if
iLogicVb.RunExternalRule("SurfaceColour")
Next
If iProperties.Value("Custom", "Surface") = "RAL 9010"
If iProperties.Value("Custom", "Surface") = "RAL 5003"
Catch
	debug("Run Error Code 7")
	dViewRepMgr.DesignViewRepresentations.Item(1).Activate
	End Try
	Try
dViewRep.Activate
'Home View
ThisApplication.CommandManager.ControlDefinitions.Item _
("AppViewCubeHomeCmd").Execute
'Home View
Catch
	debug("Run Error Code 8")
End Try
Catch
	debug("Run Error Code 9")
	debug("Add Colour to Assambly")
End Try
	'iLogicVb.RunExternalRule("SurfaceColour")
If sDocumentSubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Or sDocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then '  = "Part"
	debug("Colour Part")
	If d0 = "Colour 1		Basic colour for chassis, etc." Then
		debug("Colour 1 ")
ChangeView
If d0 = "Colour 2 		Basic colour for moving parts." Then
	ChangeView
If d0 = "Galv." Or d0 = "Electro galvanized	Preferable/Cheapest" Or d0 = "Hot dip galvanized 	Outdoor Use" Then
ChangeView
If d0 = "RAL 1028	Melon yellow" Or d0 = "RAL 9005	Jet black" Or d0 = "RAL 9010 	Pure white"  Or d0 = "RAL 5003 	Sapphire blue" Then
ChangeView
If d0 = "RAL 5003 Sapphire blue" Then
ChangeView
'gør intet
End Sub
Sub Colour1
	debug("Loading Colour 1")
	Try
	Catch
	oPartDoc =	ThisDoc.Document
	End Try
	oLib = ThisApplication.AssetLibraries("KallesoeMaterialLibrary")
	'libAsset = oLib.AppearanceAssets.Item("RAL 9010 Pure white")
	libAsset = oLib.AppearanceAssets.Item("RAL 7035 Light grey")
	Try
		localAsset = oPartDoc.Assets.Item("RAL 7035 Light grey")
	Catch
		debug("Run Error Code 10")
	End Try
	Debug("Loading Colour 1 END")
	End Sub
Surfacecolour(ilogic code)
Farvelægge samlinger
Sub Main()
	Debug("Starting Surfacecolour")
If iProperties.Value("Custom", "Surface")="Colour 1" Then
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
	Component.Color(oOccurrence.name)="RAL 7035 Light grey"
Next
If iProperties.Value("Custom", "Surface")="Colour 2" Then
	Component.Color(oOccurrence.name)="RAL 7037 Dusty grey"
Next
If iProperties.Value("Custom", "Surface")="HDG-Galv"  Then
	Component.Color(oOccurrence.name)="Galvanized (texture)"
Next
If iProperties.Value("Custom", "Surface")="Galv." Or iProperties.Value("Custom", "Surface")="EG-Galv"   Then
	Component.Color(oOccurrence.name)="Galvanized"
Next
If iProperties.Value("Custom", "Surface")="RAL 1028" Then
	Component.Color(oOccurrence.name)="RAL 1028 Melon yellow"
Next
If iProperties.Value("Custom", "Surface")="RAL 9005" Then
debug("Colour 1")
	Component.Color(oOccurrence.name)="RAL 9005 Jet black"
Next
If iProperties.Value("Custom", "Surface")="RAL 9010" Then
	Component.Color(oOccurrence.name)="RAL 9010 Pure white"
Next
If iProperties.Value("Custom", "Surface")="RAL 5003" Then
	Component.Color(oOccurrence.name)="RAL 5003 Sapphire blue"
Next
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : Colour" & txt)
End Sub
Message 15 of 18
gordon.bowe
Thank you everyone for the examples in this post.
I would like to do something slightly different than I have seen elsewhere, but I figure there is a good start in this thread, so I decided to post it here.
Occasionally we will append "REF" or "MOCK" or some other descriptors to the file name of a part.  The part number will not have this, only the file name.
I would like to have some code that runs prior to save via a trigger where if the file name ends in REF or MOCK (also Ref, ref, Mock, mock, maybe create a list of "triggers" and if the filename contains a trigger then set a bool to true?), it will prompt the user with a message ("it seems like you have a "REF" or "MOCK" part, would you like to override the color?") and if the user selects "Yes", then the color will be set to "Pink".
Catch:  This rule should work for parts, sheetmetal parts, assemblies, weldments, etc.
Thank you in advance.
Message 16 of 18
D.Motshagen
Hi @chandra.shekar.g,
Do you also have a part of code for clearing the override on the appearance?
Clear Override cannot be chosen as name
thanks.
Message 17 of 18
I have this code.. that will remove all Color(will clear override the color) . on all View in the file.. I have try to remove some code that are unit to where i use it .. so I hope i did it right so I did not break the code 😀
For assembly
'define view rep
Dim objColl As ObjectCollection
objColl = ThisApplication.TransientObjects.CreateObjectCollection
	Call objColl.Add(oOccurrence)
Next
oAsmCompDef.ClearAppearanceOverrides(objColl)
Next
For Part
Sub Main
	doc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
	If sDocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Or sDocumentSubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then  	' = "Sheet Metal and Part"
	ChangeView
	End Sub
	Trace.WriteLine("NTI : " & txt)
End Sub
	Sub ChangeView
	'''New Code Begun
	''' Here
	debug("Start Run Function Change View")
	Dim doc As PartDocument
 debug("Load This Document Variabel")
 ' get AssemblyComponentDefinition
 Dim partDef As PartComponentDefinition
 partDef = doc.ComponentDefinition
 debug("Loaded Variabel 2")
  dViewRepMgr = partDef.RepresentationsManager
debug("Loaded Variabel 3")
 debug("Loaded Variabel 4")
Dim oName As String
oName = dViewRep.Name
debug("Loaded Variabel 5")
' get the first Representation view
  dViewRep = dViewRepMgr.DesignViewRepresentations.Item(oName)
	'New code Ende
'set a reference to the part component definintion.
'Dim oPartCompDef As PartComponentDefinition
'oPartCompDef = ThisDoc.Document.ComponentDefinition
debug("Loaded Variabel 6")
oViewReps = partDef.RepresentationsManager.DesignViewRepresentations'oPartCompDef.RepresentationsManager.DesignViewRepresentations
debug("Loaded Variabel 7")
debug("Loading Variable Change view")
Try
debug("Run For LOOP")
debug("Run For LOOP2")
ClearOverride
Next
Catch
debug("Run Error Code 13")
End Try
Try
dViewRep.Activate
Catch
	debug("Run Error Code 14")
End Try
End Sub
Sub ClearOverride
	End Sub
Message 18 of 18
D.Motshagen
Hi @Darkforce_the_ilogic_guy,
Thanks for your reply.
I found the solution to my problem:
'clear override material appearence
'Found at: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/clear-all-appearance-overrides-in-part-with-ilogic/m-p/8226065/highlight/true#M88140
Dim oDoc As PartDocument
 	oDoc = ThisApplication.ActiveDocument
oDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
This will do the trick.
