Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to add prompted text at 12,3,6 and 9 o'clock to Balloons.
7 REPLIES 7
Message 1 of 8
michael_wardas
540 Views, 7 Replies
We've used Inventor professional here for a number of years and struggled with attaching qty text on all 4 quadrants of the balloon based on location of the leader. I've created a symbol with prompted text (displays as '#"X) but that doesn't help me attach it to the center of a balloon (can't be done) plus it's another step done after the balloons are placed.
Ultimately see the attached image to see what I want to be created when I attach a balloon. The qty beside the balloon is the qty for that particular area of interest, not the whole view nor the whole dwg.Placing balloons Inventor 2015.JPG
Using Inventor Professional 2015
64-Bit Edition
Thanks for your help.
BR,
Michael Wardas
7 REPLIES 7
Message 2 of 8
Hello Michael,
Can't you use the built in split balloon to do this?
see my screencast: http://autode.sk/2oN3tlR
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 8
Thanks for the response.
However I'm looking to specify a qty for a particular area of interest as opposed to the total BOM qty as per my previous attached example.
Message 4 of 8
Hi Michael,
Please find the following VBA code to draw the text across 3'0 clock and 9'o clock. Similarly, the code can be extended for 9'o clock and 12'o clock.
On running this code, it will ask to select a balloon. After selection, 2 texts are generated and positioned at 3'o clock and 9'o clock.
Sub Main()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oBalloon As Balloon
    Set oBalloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select a balloon")
    Dim oStyle As BalloonStyle
    For Each oStyle In oDrawDoc.StylesManager.BalloonStyles
    If oStyle.Name = "Balloon Qty" Then
        Set oStyle = oDrawDoc.StylesManager.BalloonStyles.Item("Balloon Qty")
    Next
    If oStyle Is Nothing Then
        Set oStyle = oDrawDoc.StylesManager.BalloonStyles.Item(1).Copy("Balloon Qty")
    oStyle.BalloonType = BalloonTypeEnum.kCircularWithOneEntryBalloonType
    oStyle.Properties = "PartsListProperty='45575'"
    oBalloon.Style = oStyle
    Dim strQty As String
    strQty = oBalloon.BalloonValueSets.Item(1).Value
    strQty = strQty & "X"
    oBalloon.Style = oDrawDoc.StylesManager.BalloonStyles.Item(1)
    oBalloon.SetBalloonType (BalloonTypeEnum.kCircularWithOneEntryBalloonType)
    Call oStyle.Delete
    Dim txtPt3o As Point2d
    Set txtPt3o = ThisApplication.TransientGeometry.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y)
    txtPt3o.X = txtPt3o.X + oBalloon.Style.BalloonDiameter / 2
    txtPt3o.Y = txtPt3o.Y + oDrawDoc.StylesManager.TextStyles.Item(1).FontSize / 2
    Dim oText3o As Inventor.GeneralNote
    Set oText3o = oDrawDoc.Sheets.Item(1).DrawingNotes.GeneralNotes.AddFitted(txtPt3o, strQty)
    Dim txtPt9o As Point2d
    Set txtPt9o = ThisApplication.TransientGeometry.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y)
    txtPt9o.X = (txtPt9o.X - (oBalloon.Style.BalloonDiameter / 2)) - (oDrawDoc.StylesManager.TextStyles.Item(1).WidthScale * 0.6)
    txtPt9o.Y = txtPt9o.Y + oDrawDoc.StylesManager.TextStyles.Item(1).FontSize / 2
    Dim oText9o As Inventor.GeneralNote
    Set oText9o = oDrawDoc.Sheets.Item(1).DrawingNotes.GeneralNotes.AddFitted(txtPt9o, strQty)
End Sub
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "Kudo"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 8
This works great!
I will try to add the 12 and 6 oclock positions.
Is there an easy way to be 'prompted' for the text when inserting so I don't have to go back and edit?
Many thanks!
Message 6 of 8
One other thing is it easy to make the text follow the balloon like a symbol?
Message 7 of 8
I just tried messing around to see if you could attach a leader to the balloon so then you could use a leader note that would follow it... but that failed.
So it looks like you would have to use assets or something to locate the balloon and catch the balloon location changes with an event and relocate the text notes in relation to the new geometry...
'This attached code is test I did with LeaderNotes that failed when trying to use it with balloons. Even in the API documentation, none of the objects listed for valid geometry intent include balloons...
 Sub Main()
	'Dim oBalloon As Balloon
	'oBalloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select a balloon")
	oBalloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select a balloon")
	Call AddGenNoteWithLeader(oBalloon)
End Sub
Sub AddGenNoteWithLeader(oBalloon As Object)
		Dim ballPt3o As Point2d
		ballPt3o = ThisApplication.TransientGeometry.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y)
		txtPt3o.X = ballPt3o.X + 5'+ oBalloon.Style.BalloonDiameter / 2
		txtPt3o.Y = ballPt3o.Y + 4'+ oDrawDoc.StylesManager.TextStyles.Item(1).FontSize / 2
		Dim oLeaderPoints As ObjectCollection
		oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
	'Where to place the text
		oLeaderPoints.Add(txtPt3o)
	'What to attach leader arrow to
		Dim oGeometryIntent As GeometryIntent
		'oGeometryIntent = ThisApplication.ActiveDocument.ActiveSheet.CreateGeometryIntent(oCurve)
		'oGeometryIntent = oDrawDoc.ActiveSheet.CreateGeometryIntent(ballPt3o, ballPt3o)
		oGeometryIntent = oDrawDoc.ActiveSheet.CreateGeometryIntent(oBalloon)
		oLeaderPoints.Add(oGeometryIntent)
		Dim oText3o As Inventor.LeaderNote
	Try
		oText3o = oDrawDoc.Sheets.Item(1).DrawingNotes.LeaderNotes.Add(oLeaderPoints, "Hey")
		oText3o.LeaderVisible = False
	Catch
		MsgBox("You is has failed")
	End Try
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 8
Hi Micheal,
Please name the symbol with example image. Let you know the possibility.
Yes, It can be achieved through a Windows application which contains textbox.
Required text can be entered in that textbox.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
