Get the Sketch Name consumed by all parameters
cencinaNB2ET
cencinaNB2ET
Hi All,
Im trying to access the consumed by property of the parameter...
As The Help API describes the parameter Object with a few possible options:
Parameter.DrivenBy() as ObjectCollection
Parameter.AttributeSets As AttributeSets
Then Attributesets.Parent()...
None output a string for the name... i want to iterate through...
This is my the code (ilogic)
SyntaxEditor Code Snippet
Dim Doc As Document
Doc = ThisApplication.ActiveDocument
Dim para As Parameter
For Each para In  Doc.ComponentDefinition.Parameters
Dim Consumed_By_1 As ObjectCollection
Dim Consumed_By_2 As AttributeSets
Dim Consumed_By_3 As Boolean
Dim Consumed_By_4 As ObjectCollection
Consumed_By_1 = para.Dependents()
Consumed_By_2 = para.AttributeSets()
Consumed_By_3 = para.InUse()
Consumed_By_4 = para.DrivenBy()
' Here is want to access the The name of each parameters consumed by...
MessageBox.Show("", "")
Next
iLogicVb.UpdateWhenDone = True
Replies (11)
JaneFan
Hello @cencinaNB2ET
para.Dependents represents the Consumed by parameters. There is possibility that one parameter is consumed by multiple others, so that Parameter.Dependents returns object collection instead of one single parameter.
We can get the name of the consumed by parameter like this:
para.Dependents.Item(1).Name
Try and catch may be needed since it is also possible that some parameter is consumed by no one else.
Jane Fan
Inventor QA Engineer
cencinaNB2ET
Ok I thought it was a collection of objects. but do I find by consumed by name?
Im i declaring something wrong?
Dim Doc As Document
Dim ConsumedBy As ObjectCollection
ConsumedBy = para.Dependents()
For i = 1 To ConsumedBy.count - 1
If ConsumedBy.Item(i).Name = "Drill Sketch 1" Then
MessageBox.Show(ConsumedBy.Item(i).Name , "")
Next i
Next
JaneFan
How about changing this line,
To :
Jane Fan
cencinaNB2ET
Not Sure what is wrong...
I want to narrow my search to  a sketch name
in this case : "NF Hole Sketch 2"
Dim Doc As Document
MessageBox.Show(ConsumedBy.Item(i).Name, "")
If para.Dependents.Item(i).Name = "NF Hole Sketch 2" Then
Next i
Next
Cant seem to access the Object Collection of dependents...
dgreatice
hi,
When you use dependents, DrivenBy an inUse properties, it return to object collection but no properties "Name" in objeccollection.
and if you get objectCollection type, its return to weak object.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
dgreatice
I think we cant get Name of consumed feature/sketch method at parameters.
basnederveen
To find the parameters used by a feature you can use .createdbyfeature.parameters, i do not know if you can find the parameters consumed by a sketch:
For Each sb In oPartDoc.ComponentDefinition.SurfaceBodies
      ' this contains the collection of parameters consumed by the feature.
      sb.CreatedByFeature.Parameters
next
JaneFan
Hey @cencinaNB2ET
Sorry for the inconvenience.
There is an issue here: Dependents of user parameters can return correctly, while that of model parameter returns blank object collection even there should be something in there. It has been tracked in our issue system.
Jane Fan
cencinaNB2ET
Thats Ok
I worked around it by analysing the "d400" name sequentially, and separating them accordingly.
Its working for my purpose now.
Thank you anyway.
dgreatice
I have new info for this issue, maybe it you solution.
try this, I have example for indetify In Use in Part Document
Public Sub IdentifyParameterUseIn()
    Dim app As Application
    Set app = ThisApplication
    Dim oPD As PartDocument
    Set oPD = app.ActiveDocument
    Dim oPCD As PartComponentDefinition
    Set oPCD = oPD.ComponentDefinition
    Dim oParam As Parameters
    Set oParam = oPCD.Parameters
    Dim oMP As ModelParameter
    Dim oSkt As Sketch
    Dim ParentCompDef As PartComponentDefinition
    Dim oFeat As PartFeature
    Dim oFeatParam As Parameter
    Dim DimCon As DimensionConstraints
    Dim SktParam As DimensionConstraint
    'call Model Parameter
    For Each oMP In oParam.ModelParameters
        'call parent of model parameter
        Set ParentCompDef = oMP.Parent.ComponentDefinition
        For Each oSkt In ParentCompDef.Sketches
            Set DimCon = oSkt.DimensionConstraints
            For Each SktParam In DimCon
                If SktParam.Parameter.Name = oMP.Name Then
                    MsgBox "Parameter Name " & oMP.Name & " is Consumed By " & oSkt.Name
            Next
        Next
        For Each oFeat In ParentCompDef.Features
            For Each oFeatParam In oFeat.Parameters
                If oFeatParam.Name = oMP.Name Then
                    MsgBox "Parameter Name " & oMP.Name & " is Consumed By " & oFeat.Name
            Next
        Next
    Next
End Sub
cencinaNB2ET
Hello dgreatice,
I will try this in the next two weeks when I get some time off.
like I said I have a workaround but I foresee this problem coming up again soon for another process.
Hopefully, it works...
Thanks.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
