Flipping component pattern in assemblies with iLogic
Message 1 of 13
I have an assembly with a component pattern that I want to flip the direction with iLogic (or other rule type) by reading a multivalue parameter which reads either "LEFT" or "RIGHT". Can this be done?
Replies (12)
Message 2 of 13
Hello and welcome to the community.
Is the pattern you are changing a rectangular pattern? and if so is it just the the column direction you want to change?
Message 3 of 13
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
Dim oOccPat As OccurrencePattern
oOccPat = oAsmCompDef.OccurrencePatterns.Item(1)
If parameter = "LEFT" Then
oOccPat.ColumnEntityNaturalDirection = False
Else
oOccPat.ColumnEntityNaturalDirection = True
If you have more than one pattern, you may want to define the pattern by its name rather than item number. In that instance you would use:
oOccPat = oAsmCompDef.OccurrencePatterns.Item("Component Pattern Name")
Message 4 of 13
frederic.vandenplas
(This must be posted exactly at the same moment as someone else)
in 2015 i could not use a multivalue parameter, so i used a True/False paramer, this may be altered if needed.
Sub FlipPattern()
Dim oIamDoc As AssemblyDocument
Set oIamDoc = ThisApplication.ActiveDocument
Dim oIamDocDef As AssemblyComponentDefinition
oIamDocDef = oIamDoc.ComponentDefinition
Dim oRecPattern As RectangularOccurrencePattern
oRecPattern = oIamDocDef.OccurrencePatterns("Component Pattern 1:1")  'Change as needed
Dim oUserParamDirection As UserParameter
oUserParamDirection = oIamDocDef.Parameters.UserParameters.Item("Direction")
If oUserParamDirection.Value = "True" Then 'Change as needed
    oRecPattern.ColumnEntityNaturalDirection = True
Else
    oRecPattern.ColumnEntityNaturalDirection = False
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 5 of 13
This worked beautifully...thank you
Message 6 of 13
I received an error using this one, but I probably overlooked or mistakenly edited the code improperly to fit my situation. Since the code posted above worked, I didn't chase down the error. I still want to thank you for your help though...
Message 7 of 13
Removing the word Set  from this line would probably fix the error.
Message 8 of 13
josephcooley
I'm having trouble with this I have a circular pattern that is not working for me.
SyntaxEditor Code Snippet
oOccPat = oAsmCompDef.OccurrencePatterns.Item("NubSupportPattern")
If OrientationNumeric = 1 Then
Else
ERROR MESSAGE:
Error in rule: Orientation, in document: Tray Stack, Top_HC3.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
INFO:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OccurrencePatterns.get_Item(Object Index)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 9 of 13
josephcooley
I am trying to do flip a circular pattern does that make a difference?
Message 10 of 13
Not able to test it myself, but I think if you change ColumnEntityNaturalDirection to AxisEntityNaturalDirection it will work.
I found that via the API help:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-1C7846A1-15A4-4C97-9C0B-B2F852A927D3
Message 11 of 13
josephcooley
Perfect that worked exactly as intended thank you!
Message 12 of 13
josephcooley
This worked for one assembly but I have a circular pattern nested within a linear pattern in another assembly and its not working correctly. its giving me this message below:
Error Message:
Error in rule: Orientation, in document: Tray Stack, Bottom_HC3.iam
More Info
I have attached a screenshot of the model tree structure.  The "rotational pattern" is the one I want to switch within the "Linear Pattern"
Here is the code:
trigger = OrientationNumeric
Dim oDoc = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oPattern As CircularOccurrencePattern
oPattern = oDef.OccurrencePatterns.Item("Rotational Pattern")
If OrientationNumeric = 0 Then
	oPattern.AxisEntityNaturalDirection = False
Else
	oPattern.AxisEntityNaturalDirection = True
Message 13 of 13
jfenter
I am working on something similar, except I would like to reverse the direction of a feature pattern within a part.   How do I define the features within the part?
