Hello, I have written some code to export a IDW sheet to a DXF to a specific location on our company network. Only problem is that not all users have rights to modify or delete the file (only the admin and the user who did the export have full rights)
You can see my iLogic rule here:
Imports System Imports System.IO Imports System.Security.AccessControl '********************************************Zet DXF instellingen****************************************** Dim DXFAddin As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism 'Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\dxfout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If '********************************************Creëer path****************************************** 'Dim sMaterial As String = ThisDoc.Document.ComponentDefinition.Material.Name 'Dim sThickness As String = Parameter("Thickness") Dim sStockNr As String = iProperties.Value("Project", "Stock Number") Dim sStockNrLinks As String 'trace.Writeline("Thickness: " & sThickness) If sStockNr = "" Then 'vbLf = carriage return sStockNr= InputBox("Stocknummer niet ingevuld !" & vbLf & "Geef stocknummer in:", "Onvolledig" , "") End If 'Controleer of stocknummer 5 tekens bevat If Len(sStockNr) <> 5 Then i = MessageBox.Show("Ongeldig stocknummer ingegeven !", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) Return End If sStockNrLinks = Left(sStockNr,2)+"000" 'Voorlopig niet boven 100.000 trace.Writeline(sStockNr.ToString() & Chr(13) & sStockNrLinks.ToString() ) Dim sPATH As String sPATH = "L:\ASCI\PRODUCTEN\" & sStockNrLinks & "\" & sStockNr Dim sFilePath As String sFilePath = sPATH & "\" & sStockNr & "_" & ThisDoc.FileName(False) & ".dxf" 'Dim UserAccount As String = "BASCULESROBBE\Users" Dim UserAccount As String = "Everyone" Dim FileInfo As IO.FileInfo = New IO.FileInfo(sFilePath) Dim FileAcl As New FileSecurity trace.Writeline("FileACL aangemaakt") 'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.ContainerInherit Or InheritanceFlags.ObjectInherit, PropagationFlags.None, AccessControlType.Allow)) 'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.None, PropagationFlags.None, AccessControlType.Allow)) FileAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, AccessControlType.Deny)) trace.Writeline("Add accessrule ok") FileInfo.SetAccessControl(FileAcl) trace.Writeline("SetAccessControl ok") 'Kijk of path bestaat en creer indien het niet bestaat If Not System.IO.Directory.Exists(sPATH) Then System.IO.Directory.CreateDirectory(sPATH) End If 'Set the destination file name 'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & sheetname & ".dxf" 'same folder, or uncomment: oDataMedium.FileName= sFilePath 'oDataMedium.FileName = "L:\ASCI\PRODUCTEN\14000\14001\14001_0150001.dxf\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the DXF file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
The code executes till the FileAcl.AddAccessRule
I get the following error:
Error in rule: Rule4, in document: 0150092.idw
Some or all identity references could not be translated.
System.Security.Principal.IdentityNotMappedException: Some or all identity references could not be translated.
at System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess)
at System.Security.Principal.NTAccount.Translate(Type targetType)
at System.Security.AccessControl.CommonObjectSecurity.ModifyAccess(AccessControlModification modification, AccessRule rule, Boolean& modified)
at System.Security.AccessControl.CommonObjectSecurity.AddAccessRule(AccessRule rule)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Anyone got an idea what the problem might be ?
Thanks in advance,
Greetings
Cedric
Thry this one
oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document Dim oSheet As Sheet Dim lPos As Long Dim rPos As Long Dim sLen As Long Dim sSheetName As String Dim sSheetNumber As Integer 'step through each drawing sheet Dim Response As MsgboxResult For Each oSheet In oDrawing.Sheets Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question") If Response = MsgBoxResult.Yes Then 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos - 1) 'find the sheet numbe sSheetNumber = Right(oSheet.Name, sLen - lPos) End If ActiveSheet = ThisDrawing.Sheet(oSheet.Name) If Response = MsgBoxResult.Yes Then 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos - 1) 'find the sheet numbe sSheetNumber = Right(oSheet.Name, sLen - lPos) 'get DXF target folder path oFolder = "c:\INVENTOR DXF FILES" 'Set the DXF target file name oDataMedium.FileName = oFolder & "\" & sSheetName & sSheetNumber & ".dxf" MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK) 'Publish document oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If Next
