Drawing Note Generator
cmcconnell
cmcconnell
In the interest of giving back to the community for all that I have taken, here is a set of rules, forms and triggers I have created to build and maintain drawing notes. Also included as part of the note selection is a tool to select the tblock for the drawing. These rules contain our note text, and some of them pull info from model properties. This could easily be changed to suit your requirements.
Please keep in mind that I am not a programmer and a lot of this is likely very crude - and could be written in a much more efficient way. 🙂 I have been able to make our note creation much more efficient than it was.
Step 1:
Creates Parameters in idw
Trigger: on open, on new
Rule (Create Note Params):
oDrawDoc = ThisApplication.ActiveDocument
'oDrawDoc = ThisDoc.Document
	Dim oDrawParams As UserParameters = oDrawDoc.Parameters.UserParameters
	sText1 = "-"
	sText2 = "Apply thread locker as per 0000-45-16132."
	sText3 = "Bolt Lengths are approximate and can vary due to part tolerances and/or " + vbCrLf + "     urethane compression."
	sText4 = "Mark as shown."
	sText5 = "Etch assembly no. <Part Number> in visible location."
	sText6 = "Arrange gauging plates from rear to front, largest to smallest starting at " + vbCrLf + "     position 4, then 3, 2, 1. (EX: A 2GP will use positions 4 & 3)"
	sText7 = "Plates may be removed to create configurations of 1GP, 2GP & " + vbCrLf + "     3GP. When removing plates from their locations; leave spacers in place."
	sText8 = "Machine from: <Machine From>"
	sText9 = "<Model Comments>"
	sText10 = "Dimensions provided for reference only. Part to be machined from " + vbCrLf + "     solid model data and mold will be verified by checking dimensions of " + vbCrLf + "     the molded part."
	sText11 = "Trim all excess material from finished part & check for defects."
	sText12 = "Remove all burrs & sharp edges."
	sText13 = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText14 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText15 = "Mark Part / Weldment (in a visible location & when possible) with " + vbCrLf + "       last 5 digits of Part Number UNO."
	sText16 = "<Stock Number>"
	sText17 = "Verify OD and circumference before marking locations of mounts."
	'sText18 =
	'stext19 =
	' Create and populate note parameters
	' Check to see if each parameter exists
	Try
		'If yes, update values
		pNote1 = oDrawParams.Item("Note1")
			MultiValue.SetList("Note1", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			'If no, create and populate values
			pNote1 = oDrawParams.AddByValue("Note1" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
	Try
		pNote2 = oDrawParams.Item("Note2")
			MultiValue.SetList("Note2", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote2 = oDrawParams.AddByValue("Note2" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
	Try
		pNote3 = oDrawParams.Item("Note3")
			MultiValue.SetList("Note3", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote3 = oDrawParams.AddByValue("Note3" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
	Try
		pNote4 = oDrawParams.Item("Note4")
			MultiValue.SetList("Note4", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote4 = oDrawParams.AddByValue("Note4" , "-", UnitsTypeEnum.kTextUnits)
			"-", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
	Try
		pNote5 = oDrawParams.Item("Note5")
			MultiValue.SetList("Note5", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote5 = oDrawParams.AddByValue("Note5" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
		Try
		pNote6 = oDrawParams.Item("Note6")
			MultiValue.SetList("Note6", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote6 = oDrawParams.AddByValue("Note6" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
		Try
		pNote7 = oDrawParams.Item("Note7")
			MultiValue.SetList("Note7", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote7 = oDrawParams.AddByValue("Note7" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
		Try
		pNote8 = oDrawParams.Item("Note8")
			MultiValue.SetList("Note8", _
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		Catch
			pNote8 = oDrawParams.AddByValue("Note8" , "-", UnitsTypeEnum.kTextUnits)
			sText1, _
			sText2, _
			sText3, _
			sText4, _
			sText5, _
			sText6, _
			sText7, _
			sText8, _
			sText9, _
			sText10, _
			sText11, _
			sText12, _
			sText13, _
			sText14, _
			sText15, _
			sText16, _
			sText17)
		End Try
Step 2:
Creates Tblock Parameters in idw
Rule (Create Tblock Params):
'Acts only on active document
Dim oDrawDoc As Document = ThisApplication.ActiveDocument
If Not oDrawDoc Is ThisDoc.Document Then Exit Sub
	Try
		pTblock1 = oDrawParams.Item("Title_Block")
		Catch
			pTblock1 = oDrawParams.AddByValue("Title_Block" , "-", UnitsTypeEnum.kTextUnits)
			MultiValue.SetList("Title_Block", _
			"General Assembly", _
			"Machined", _
			"Machined (no appearance)", _
			"Welded Assembly", _
			"Urethane")
		End Try
Dim sTblock1 As String
sTblock1 = Parameter("Title_Block")
If oValue = "General Assembly" Then
	' Obtain a reference to the desired sketched symbol definition.
	Dim oSketchedSymbolDef As SketchedSymbolDefinition
	oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("GENERAL ASSY")
	Dim oSheet As Sheet = oDrawDoc.ActiveSheet
	'create insertion point, coordinates - in cm !
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(17.98, 1)
	' Add an instance of the sketched symbol definition to the sheet.
	' Rotate angle = 0 radians,
	' scale = 1 when adding
	' no prompt text
	Dim oSketchedSymbol As SketchedSymbol
	oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oInsertionPoint, 0, 1, Nothing)
Else If oValue = "Machined" Then
	oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("MACHINED")
	' no prompt text
Else If oValue = "Machined (no appearance)" Then
	oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("MACHINED no Appearance")
	' no prompt text
Else If oValue = "Welded Assembly" Then
	oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("WELDED ASSY")
	' no prompt text
Else If oValue = "Urethane" Then
	oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("URETHANE")
	' no prompt text
Step 3:
Runs idw startup form in idw
Trigger: on new
Rule (IDW-Startup):
'open note and tblock selection form
iLogicForm.ShowGlobal("Drawing Setup", FormMode.Modal)
'Remove existing notes
iLogicVb.RunExternalRule("Drawing Notes - Delete")
'Remove existing tblock
'iLogicVb.RunExternalRule("Title Block - Delete")
'place selected notes on idw
iLogicVb.RunExternalRule("Drawing Notes - Insert")
'place selected tblock on idw
iLogicVb.RunExternalRule("Title Block - Insert")
The IDW setup form looks like this:
The user selects the tblock from the drop down and then picks which notes to show from the dropdowns. The second tab just has more notes in cases where more notes are necessary. Clicking done, inserts the tblock and the notes onto the drawing.
Editing the notes and tblock:
User opens the IDW setup form, makes changes and hits the Apply Updates button which runs this rule (this rule is also triggered before save to ensure the notes are up to date):
'Updates drawing notes after a change to model values
Drawing Notes - Delete rule:
Dim oDrawDoc As DrawingDocument
Dim Sheet As Inventor.Sheet
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Set a reference to the GeneralNotes object
Dim oGeneralNotes As GeneralNotes
oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
Dim oRotation As Double
	oRotation = .000001
For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes
			If oGeneralNote.Rotation = oRotation
				oGeneralNote.Delete
		Next
Drawing Notes - Insert rule:
Sub Main()
Dim oSheet As Sheet
oTG = ThisApplication.TransientGeometry
'Get referenced model
Try
oModelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
sModelComments = iProperties.Value(oModelName, "Custom", "Model Comments")
sModelPartNumber = iProperties.Value(oModelName, "Project", "Part Number")
sModelStockNumber = iProperties.Value(oModelName, "Project", "Stock Number")
sModelMoldedPartNumber = iProperties.Value(oModelName, "Custom", "Molded Part Number")
sModelMachinedFrom = iProperties.Value(oModelName, "Custom", "Machined From")
'MessageBox.Show(sModelPartNumber, "Title")
Catch
End Try
' Create a set of notes that are numbered and aligned along the left.
    Dim dXCoord As Double
	dXCoord = 1.5 'cm
	Dim dYCoord As Double
    dYCoord = 41.5 'cm
	Dim dXCoord1 As Double
	dXCoord1 = dXCoord + 10 'cm
	Dim dYCoord1 As Double
    dYCoord1 = dYCoord - 1 'cm
    Dim dXOffset As Double
	Dim dYOffset As Double
	Dim oStyle As TextStyle
    'oStyle = oGeneralNotes.Item(1).TextStyle
    dXOffset = .225 'cm
	dYOffset = 1 'cm
	oRotation = .000001 'rad
	oSetWidth = 16 'cm
	ActiveSheet = ThisDrawing.Sheet("Sheet:1")
Dim sText1 As String
If Parameter("Note1") = "<Model Comments>" Then
	sText1 = sModelComments
Else If Parameter("Note1") = "<Stock Number>"
	sText1 = sModelStockNumber
Else If Parameter("Note1") = "Etch assembly no. <Part Number> in visible location."
	sText1 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note1") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText1 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note1") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText1 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note1") = "Machine from: <Machine From>"
	sText1 = "Machine from: " + sModelMachinedFrom
Else
	sText1 = Parameter("Note1")
Dim sText2 As String
If Parameter("Note2") = "<Model Comments>" Then
	sText2 = sModelComments
Else If Parameter("Note2") = "<Stock Number>"
	sText2 = sModelStockNumber
Else If Parameter("Note2") = "Etch assembly no. <Part Number> in visible location."
	sText2 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note2") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText2 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note2") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText2 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note2") = "Machine from: <Machine From>"
	sText2 = "Machine from: " + sModelMachinedFrom
Else
	sText2 = Parameter("Note2")
Dim sText3 As String
If Parameter("Note3") = "<Model Comments>" Then
	sText3 = sModelComments
Else If Parameter("Note3") = "<Stock Number>"
	sText3 = sModelStockNumber
Else If Parameter("Note3") = "Etch assembly no. <Part Number> in visible location."
	sText3 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note3") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText3 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note3") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText3 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note3") = "Machine from: <Machine From>"
	sText3 = "Machine from: " + sModelMachinedFrom
Else
	sText3 = Parameter("Note3")
Dim sText4 As String
If Parameter("Note4") = "<Model Comments>" Then
	sText4 = sModelComments
Else If Parameter("Note4") = "<Stock Number>"
	sText4 = sModelStockNumber
Else If Parameter("Note4") = "Etch assembly no. <Part Number> in visible location."
	sText4 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note4") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText4 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note4") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText4 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note4") = "Machine from: <Machine From>"
	sText4 = "Machine from: " + sModelMachinedFrom
Else
	sText4 = Parameter("Note4")
Dim sText5 As String
If Parameter("Note5") = "<Model Comments>" Then
	sText5 = sModelComments
Else If Parameter("Note5") = "<Stock Number>"
	sText5 = sModelStockNumber
Else If Parameter("Note5") = "Etch assembly no. <Part Number> in visible location."
	sText5 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note5") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText5 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note5") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText5 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note5") = "Machine from: <Machine From>"
	sText5 = "Machine from: " + sModelMachinedFrom
Else
	sText5 = Parameter("Note5")
Dim sText6 As String
If Parameter("Note6") = "<Model Comments>" Then
	sText6 = sModelComments
Else If Parameter("Note6") = "<Stock Number>"
	sText6 = sModelStockNumber
Else If Parameter("Note6") = "Etch assembly no. <Part Number> in visible location."
	sText6 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note6") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText6 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note6") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText6 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note6") = "Machine from: <Machine From>"
	sText6 = "Machine from: " + sModelMachinedFrom
Else
	sText6 = Parameter("Note6")
Dim sText7 As String
If Parameter("Note7") = "<Model Comments>" Then
	sText7 = sModelComments
Else If Parameter("Note7") = "<Stock Number>"
	sText7 = sModelStockNumber
Else If Parameter("Note7") = "Etch assembly no. <Part Number> in visible location."
	sText7 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note7") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText7 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note7") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText7 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note7") = "Machine from: <Machine From>"
	sText7 = "Machine from: " + sModelMachinedFrom
Else
	sText7 = Parameter("Note7")
Dim sText8 As String
If Parameter("Note8") = "<Model Comments>" Then
	sText8 = sModelComments
Else If Parameter("Note8") = "<Stock Number>"
	sText8 = sModelStockNumber
Else If Parameter("Note8") = "Etch assembly no. <Part Number> in visible location."
	sText8 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note8") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText8 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note8") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText8 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note8") = "Machine from: <Machine From>"
	sText8 = "Machine from: " + sModelMachinedFrom
Else
	sText8 = Parameter("Note8")
Dim sText9 As String
If Parameter("Note9") = "<Model Comments>" Then
	sText9 = sModelComments
Else If Parameter("Note9") = "<Stock Number>"
	sText9 = sModelStockNumber
Else If Parameter("Note9") = "Etch assembly no. <Part Number> in visible location."
	sText9 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note9") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText9 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note9") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText9 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note9") = "Machine from: <Machine From>"
	sText9 = "Machine from: " + sModelMachinedFrom
Else
	sText9 = Parameter("Note9")
Dim sText10 As String
If Parameter("Note10") = "<Model Comments>" Then
	sText10 = sModelComments
Else If Parameter("Note10") = "<Stock Number>"
	sText10 = sModelStockNumber
Else If Parameter("Note10") = "Etch assembly no. <Part Number> in visible location."
	sText10 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note10") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText10 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note10") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText10 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note10") = "Machine from: <Machine From>"
	sText10 = "Machine from: " + sModelMachinedFrom
Else
	sText10 = Parameter("Note10")
Dim sText11 As String
If Parameter("Note11") = "<Model Comments>" Then
	sText11 = sModelComments
Else If Parameter("Note11") = "<Stock Number>"
	sText11 = sModelStockNumber
Else If Parameter("Note11") = "Etch assembly no. <Part Number> in visible location."
	sText11 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note11") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText11 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note11") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText11 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note11") = "Machine from: <Machine From>"
	sText11 = "Machine from: " + sModelMachinedFrom
Else
	sText11 = Parameter("Note11")
Dim sText12 As String
If Parameter("Note12") = "<Model Comments>" Then
	sText12 = sModelComments
Else If Parameter("Note12") = "<Stock Number>"
	sText12 = sModelStockNumber
Else If Parameter("Note12") = "Etch assembly no. <Part Number> in visible location."
	sText12 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note12") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText12 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note12") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText12 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note12") = "Machine from: <Machine From>"
	sText12 = "Machine from: " + sModelMachinedFrom
Else
	sText12 = Parameter("Note12")
Dim sText13 As String
If Parameter("Note13") = "<Model Comments>" Then
	sText13 = sModelComments
Else If Parameter("Note13") = "<Stock Number>"
	sText13 = sModelStockNumber
Else If Parameter("Note13") = "Etch assembly no. <Part Number> in visible location."
	sText13 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note13") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText13 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note13") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText13 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note13") = "Machine from: <Machine From>"
	sText13 = "Machine from: " + sModelMachinedFrom
Else
	sText13 = Parameter("Note13")
Dim sText14 As String
If Parameter("Note14") = "<Model Comments>" Then
	sText14 = sModelComments
Else If Parameter("Note14") = "<Stock Number>"
	sText14 = sModelStockNumber
Else If Parameter("Note14") = "Etch assembly no. <Part Number> in visible location."
	sText14 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note14") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText14 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note14") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText14 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note14") = "Machine from: <Machine From>"
	sText14 = "Machine from: " + sModelMachinedFrom
Else
	sText14 = Parameter("Note14")
Dim sText15 As String
If Parameter("Note15") = "<Model Comments>" Then
	sText15 = sModelComments
Else If Parameter("Note15") = "<Stock Number>"
	sText15 = sModelStockNumber
Else If Parameter("Note15") = "Etch assembly no. <Part Number> in visible location."
	sText15 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note15") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText15 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note15") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText15 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note15") = "Machine from: <Machine From>"
	sText15 = "Machine from: " + sModelMachinedFrom
Else
	sText15 = Parameter("Note15")
Dim sText16 As String
If Parameter("Note16") = "<Model Comments>" Then
	sText16 = sModelComments
Else If Parameter("Note16") = "<Stock Number>"
	sText16 = sModelStockNumber
Else If Parameter("Note16") = "Etch assembly no. <Part Number> in visible location."
	sText16 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note16") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText16 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note16") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText16 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note16") = "Machine from: <Machine From>"
	sText16 = "Machine from: " + sModelMachinedFrom
Else
	sText16 = Parameter("Note16")
Dim sText17 As String
If Parameter("Note17") = "<Model Comments>" Then
	sText17 = sModelComments
Else If Parameter("Note17") = "<Stock Number>"
	sText17 = sModelStockNumber
Else If Parameter("Note17") = "Etch assembly no. <Part Number> in visible location."
	sText17 = "Etch assembly no. " + sModelPartNumber + " in visible location."
Else If Parameter("Note17") = "Urethane dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText17 = "Urethane dept. to stamp molded part no. " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note17") = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "<Molded Part Number> in visible location."
	sText17 = "Electrical Engineering dept. to stamp molded part no. " + vbCrLf + "     " + sModelMoldedPartNumber + " in visible location."
Else If Parameter("Note17") = "Machine from: <Machine From>"
	sText17 = "Machine from: " + sModelMachinedFrom
Else
	sText17 = Parameter("Note17")
Dim sNote1 As String
Dim sNote2 As String
Dim sNote3 As String
Dim sNote4 As String
Dim sNote5 As String
Dim sNote6 As String
Dim sNote7 As String
Dim sNote8 As String
Dim sNote9 As String
Dim sNote10 As String
Dim sNote11 As String
Dim sNote12 As String
Dim sNote13 As String
Dim sNote14 As String
Dim sNote15 As String
Dim sNote16 As String
Dim sNote17 As String
If sText1 <> "-" Then
	'Dim sNote1 As String
	sNote1 = "1.  " + sText1
If sText2 <> "-" Then
	'Dim sNote2 As String
	sNote2 = "2.  " + sText2
If sText3 <> "-" Then
	'Dim sNote3 As String
	sNote3 = "3.  " + sText3
If sText4 <> "-" Then
	'Dim sNote4 As String
	sNote4 = "4.  " + sText4
If sText5 <> "-" Then
	'Dim sNote5 As String
	sNote5 = "5.  " + sText5
If sText6 <> "-" Then
	'Dim sNote6 As String
	sNote6 = "6.  " + sText6
If sText7 <> "-" Then
	'Dim sNote7 As String
	sNote7 = "7.  " + sText7
If sText8 <> "-" Then
	'Dim sNote8 As String
	sNote8 = "8.  " + sText8
If sText9 <> "-" Then
	'Dim sNote9 As String
	sNote9 = "9.  " + sText9
If sText10 <> "-" Then
	'Dim sNote10 As String
	sNote10 = "10.  " + sText10
If sText11 <> "-" Then
	'Dim sNote11 As String
	sNote11 = "11.  " + sText11
If sText12 <> "-" Then
	'Dim sNote12 As String
	sNote12 = "12.  " + sText12
If sText13 <> "-" Then
	'Dim sNote13 As String
	sNote13 = "13.  " + sText13
If sText14 <> "-" Then
	'Dim sNote14 As String
	sNote14 = "14.  " + sText14
If sText15 <> "-" Then
	'Dim sNote15 As String
	sNote15 = "15.  " + sText15
If sText16 <> "-" Then
	'Dim sNote16 As String
	sNote16 = "16.  " + sText16
If sText17 <> "-" Then
	'Dim sNote17 As String
	sNote17 = "17.  " + sText17
' Build the Note
Dim sNoteAll As String = ""
AddNote(sNoteAll, sNote1)
AddNote(sNoteAll, sNote2)
AddNote(sNoteAll, sNote3)
AddNote(sNoteAll, sNote4)
AddNote(sNoteAll, sNote5)
AddNote(sNoteAll, sNote6)
AddNote(sNoteAll, sNote7)
AddNote(sNoteAll, sNote8)
AddNote(sNoteAll, sNote9)
AddNote(sNoteAll, sNote10)
AddNote(sNoteAll, sNote11)
AddNote(sNoteAll, sNote12)
AddNote(sNoteAll, sNote13)
AddNote(sNoteAll, sNote14)
AddNote(sNoteAll, sNote15)
AddNote(sNoteAll, sNote16)
AddNote(sNoteAll, sNote17)
'MessageBox.Show(sNoteAll, "Title")
'Place the note
Dim oNoteAll As GeneralNote
oNoteAll = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), sNoteAll)
oNoteAll.Rotation = oRotation
oNoteAll.Width = oSetWidth
End Sub
Sub AddNote(ByRef sNoteAll As String, sNote As String)
	If (Not String.IsNullOrEmpty(sNote)) Then
		If (Not String.IsNullOrEmpty(sNoteAll)) Then
			sNoteAll = sNoteAll + vbCrLf
		sNoteAll = sNoteAll + sNote
End Sub
It seems very complicated when I lay it out like this.
Mechanix Design Solutions inc.
chandra.shekar.g
Autodesk Support
Autodesk Support
@cmcconnell,
Thanks for sharing your experience in iLogic.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
