Display both dimension name and value in sketch using API
Using these code, I am able to display either dimension name or value in sketch:
TwoPointDistanceDimConstraint iDimension;
iDimesion.Parameter.Name;  // d5
iDimesion.Parameter.Value;  // 25.0mm
But How do I display both dimension name followed by dimension value (d5 = 25.0mm) in sketch using Inventor API?
Prarthana
Hello Everyone,
I solved it by myself 🙂
If anyone need it then there is the code:
Inventor.Parameters oParam = default(Inventor.Parameters);
oParam = oPartDoc.ComponentDefinition.Parameters;
oParam.DimensionDisplayType = DimensionDisplayTypeEnum.kDimensionDisplayAsExpression;
Thank you in advance.
Prarthana
Change How Dimensions Appear
  • In an active sketch, choose one of the dimension display icons in the status bar:
    • Value: Displays sketch dimensions as the calculated value.
    • Name: Displays sketch dimensions as the parameter name.
    • Expression: Displays sketch dimensions as the specified parametric expression.
    • Tolerance: Displays sketch dimensions with a specified tolerance.
    • Precise Value: Displays sketch dimensions as a value, ignoring any precision.
    Note: You can also change how sketch dimensions appear by using the Dimension Properties dialog box. Right-click a dimension in the graphics window and choose Dimension Properties. In the Dimension Properties dialog box, click the Document Settings tab and choose an option from the Modeling Dimension Display menu.
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-026FE8D3-AFBB-4834-BC18-73D9CFF78185
cencinaNB2ET
How did you add dimensions with API on that line again?
I canst seem to find a way to add a point with dimensions accessing the  Inventor API
Not interested in the display but the adding method...
thanks
Maxim-CADman77
"Expression" mode shows the real value only  for the simple cases.
I'd rather prefer the mode showing exactly what you initially asked for (i.e. both name and a real value) but i doubt there is such mode in Inventor.
Please vote for Inventor-Idea Text Search within Option Names
