Dear community,
could you give me a hint where to find an example to develop a sidebar for Inventor?
I already developed this one, which I would like to port to Inventor and would like to continue to develop together with you as a community project opensource'd. It might be that I'm using the wrong term ("sidebar"), therefore here a screenshot of what I have.
Thanks!
- Thomas
Solved by bradeneuropeArthur. Go to Solution.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
While browsing through the internet, it seems to be it. However, I only can find anything specific to begin to develop such a browser control.
Do you or someone else know, where to find a template or a good howto?
Many thanks so far!
Try this way:
Sub DockableWindow() Dim oUserInterfaceMgr As UserInterfaceManager Set oUserInterfaceMgr = ThisApplication.UserInterfaceManager ' Create a new dockable window Dim oWindow As DockableWindow Set oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window") ' Get the hwnd of the dialog to be added as a child ' CHANGE THIS VALUE! Dim hwnd As Long hwnd = 4851096 ' Add the dialog as a child to the dockable window Call oWindow.AddChild(hwnd) ' Don't allow docking to top and bottom oWindow.DisabledDockingStates = kDockTop + kDockBottom ' Make the window visible oWindow.Visible = True End Sub
Or look in the help file of inventor programming help file:
Arthur Knoors
Thank you for the hint. I will take a look at it as soon as I have time.
When further questions occur, I will open new threads here in the forum.
Thanks!
