I was breaking links to the OLE referenced files but noticed that each time it saves it recreates the links! Looks like I need to delete any Stress Analysis simulations that are attached. Any idea how as I cant find any examples?
Solved by CadUser46. Go to Solution.
It seems like I only ask difficult questions.
Anyway, there is nothing in the API for this. The workaround is to disable the addin, restart Inventor, then delete the OLEDescriptors.
Kinda late to answer on this post, but maybe it helps somebody.
This does not delete simulations nor links, but you can keep the simulations and links are not showed under "Links", so you do not have to "Break Links". Result files are saved on the file.
