Goodevening,
I'm new to using Inventor VBA, and i'm trying to make a tapered hole in a existing solid.
I've succeeeded in creating the solidbody, and i've also created the sketch with a circle on it.
I'ts no problem to "cut" the extrusion from the solid body.
The problem is that i want the cutout to be tapered at a specific angle say 45°
I cant't seem to find the code to do this.
Can someone please give me an example of how to extrude a circle with a tapered wall?
Regards, Ferry.....
Solved by HermJan.Otterman. Go to Solution.
Hello Zoef8,
here is a sample from the inventor API help.
I added the single last line for the taper
oExtrudeDef.TaperAngle = -1
mind you that the angle is in radians!!! so recalculate you degrees to radians!
(ilogic / vb.net)
I hope this will help you
Public Sub DrawBlockWithPocket()
' Create a new part document, using the default part template.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane. Since it's being created on
' one of the base workplanes we know the orientation it will be created in
' and don't need to worry about controlling it. Because of this we also
' know the origin of the sketch plane will be at (0,0,0) in model space.
Dim oSketch As PlanarSketch
oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
' Draw a 4cm x 3cm rectangle with the corner at (0,0)
Dim oRectangleLines As SketchEntitiesEnumerator
oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle(oTransGeom.CreatePoint2d(0, 0), oTransGeom.CreatePoint2d(4, 3))
' Create a profile.
Dim oProfile As Profile
oProfile = oSketch.Profiles.AddForSolid
' Create a base extrusion 1cm thick.
Dim oExtrudeDef As ExtrudeDefinition
oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(1, PartFeatureExtentDirectionEnum.kNegativeExtentDirection)
Dim oExtrude As ExtrudeFeature
oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
' Get the top face of the extrusion to use for creating the new sketch.
Dim oFrontFace As Face
oFrontFace = oExtrude.StartFaces.Item(1)
' Create a new sketch on this face, but use the method that allows you to
' control the orientation and orgin of the new sketch.
oSketch = oCompDef.Sketches.AddWithOrientation(oFrontFace, oCompDef.WorkAxes.Item(1), True, True, oCompDef.WorkPoints(1))
' Determine where in sketch space the point (0.5,0.5,0) is.
Dim oCorner As Point2d
oCorner = oSketch.ModelToSketchSpace(oTransGeom.CreatePoint(0.5, 0.5, 0))
' Create the interior 3cm x 2cm rectangle for the pocket.
oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle(oCorner, oTransGeom.CreatePoint2d(oCorner.X + 3, oCorner.Y + 2))
' Create a profile.
' Create a pocket .25 cm deep.
oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kCutOperation)
oExtrudeDef.SetDistanceExtent(0.25, PartFeatureExtentDirectionEnum.kNegativeExtentDirection)
End Sub
End Class
so for the angle add this:
Dim angleInRadians As Double = (45 * Math.PI) / 180 '45 = angle in degree
replace the -1 with -angleInRadians
Hi Hermjan,
Thnk you for the effort! unfortunately the code you gave me isn't working!
As soon as i try to run the macro, i get the error Invalid use off property!
This occurs on the line oPartdoc = thisapplication ......
Also at the end of the code the line
is painted red as to highlight a syntax error of some kind
i'll post the code that i have to create the hole (without the taper offcourse) , perhaps you can m odify it a bit
the code assumes there is already a sketch active
private sub hole()
Set oSketch = ThisApplication.ActiveEditObject
Set oTransGeom = ThisApplication.TransientGeometry
Dim oTrans As Transaction
Set oTrans = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Create hole")
'4 sets van elk drie punten t.w. centerpunt start van cirkelboog en einde van de cirkelboog als rotatie 0 graden is
'set 1 hoekpunt linksonder
ipx = 0
ipy = 5
breedte = 0.9
radius = 0.9
cp1x = (ipx - (breedte / 2) + radius)
cp1y = (ipy - (hoogte / 2) + radius)
cp1sx = (cp1x - radius)
cp1sy = cp1y
cp1ex = cp1x
cp1ey = (cp1y - radius)
'# code om Cirkel te tekenen #
Dim oCircle As SketchCircle
Set oCircle = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(ipx, ipy), radius)
oTrans.End 'einde van transactie
'# vanaf hier code om uitname te maken
Set oPartDoc = ThisApplication.ActiveDocument
Set oCompDef = oPartDoc.ComponentDefinition
Set oProfile = oSketch.Profiles.AddForSolid
cut = True
If cut = True Then
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kCutOperation)
If cut = False Then
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
cutdir = "neg"
If cutdir = "neg" Then
Call oExtrudeDef.SetDistanceExtent(0.4, kNegativeExtentDirection) ' extrusiediepte vanaf werkvlak
Else
Call oExtrudeDef.SetDistanceExtent(0.4, kPositiveExtentDirection) ' extrusiediepte vanaf werkvlak
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
oSketch.ExitEdit
End Sub
Thanks for looking at it
Regards Ferry.....
Hello Ferry,
I added one line:
oExtrudeDef.TaperAngle = -((45 * 3.xxx-xxxxxxxx) / 180)
45 is the angle, 3.1415.. = PI
if you look in the Inventor API help look for an Example: "Extrude Feature - Create Block with Pocket"
you will find the VBA code of what I send previously.
it will make the block and a new sketch
Your code with one line added
Private Sub hole()
ipx = 0
ipy = 5
breedte = 0.9
Radius = 0.9
cp1x = (ipx - (breedte / 2) + Radius)
cp1y = (ipy - (hoogte / 2) + Radius)
cp1sx = (cp1x - Radius)
cp1sy = cp1y
cp1ex = cp1x
cp1ey = (cp1y - Radius)
Set oCircle = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(ipx, ipy), Radius)
cut = True
If cut = True Then
oExtrudeDef.TaperAngle = -((45 * 3.xxx-xxxxxxxx) / 180) 'alleen deze regel toegevoegd!
If cut = False Then
cutdir = "neg"
Else
oSketch.ExitEdit
End Sub
Great!!!
This is the solution i was looking for!
Thank you very much for helping me! Works great!
Regards, Ferry..
