CommandManager.Pick bug with ESC key
Hi all,
I discovered a bug with the CommandManager.Pick method.
When 2 Pick command follow each other, if I press on [Esc] key, the KeyDown event cancels the first Pick command and the KeyUp event cancels the next one.
You can reproduce this behavior by inserting 2 parts in assembly and run this iLogic code (press [Esc] key instead of selecting part):
Dim message As String
For index = 1 To 10
	message = "Pick #" & index
	ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, message)
Next
The result: all the even are skipped.
Does someone had a workaround?  (I thought to catch the KeyDown event and ignore it.)
Pascal
I  work with Inventor Professional 2013 64-Bit Edition SP2 Update 4
The keyboard events are disabled when the Pick command is activated.  So, my workaround doesn't work.
_dscholtes_
I would like to have some solution for this effect as well. I want to let the user either select something or press escape to use a suggested default selection, twice in a row. Selecting something using the InteractionEvents has the same issue.
I  work with Inventor Professional 2018 64-Bit Edition release 2018.2.3
BrianEkins
Hopefully, this will help.
https://ekinssolutions.com/selecting-multiple-entities-using-pick-in-inventor/
Brian Ekins
Thanks Brian!
_dscholtes_
Thank you. And thank you also for all the other examples you posted everywhere.
