Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Collapse All Children in SubAssembly (ActiveEditDocument)
3 REPLIES 3
dominiek_vanwest
711 Views, 3 Replies
I have the following piece of code to collapse all children:
        Set oDoc = ThisApplication.ActiveEditDocument
        Dim oTopNode As BrowserNode
        Set oTopNode = oDoc.BrowserPanes.ActivePane.TopNode
        Dim oNode As BrowserNode
        For Each oNode In oTopNode.BrowserNodes
            'If the node is visible and expanded, collapse it
            If oNode.Visible = True And oNode.Expanded = True Then
                oNode.Expanded = False
        Next
This works for the topassembly, but not for the subassembly. See attachment for a screenshot of my browser. So, the code works if Assembly101 is active (every node is collapsed), but it does not work if Assembly100 is active.
Why does it not work and how do I need to change my code to make it work?
And why does the following code not work (for the topassembly as well as subassemblies)?:
        Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions("AppBrowserCollapseChildrenCmd")
        oCtrlDef.Execute
        Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions("AppBrowserCollapseAllCmd")
        oCtrlDef.Execute
Thanks in advance,
Dominiek
3 REPLIES 3
... It only works for the top level nodes because you dont tell it to go any deeper.
You need some sort of other recursion and looping to follow it down the levels of nodes and run the functionality from there.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
With this code:
and this code:
I have the "Sub"Node.
I even tested it with the following:
        Dim test As String
        test = oTopNode.FullPath
And I got the name of the subassembly.
So I tell to go deeper, but you say I don't. What am I missing here?
You need something like: EXCEPT you need to write it as 2 seperate functions and call recursively.
If oNode.Nodes.Count > 0
For Each oNode in oNode.Nodes
Visible off
Next
End if
If oNode.Visible = True And oNode.Expanded = True Then oNode.Expanded = False End If
Next
RECURSION like this:
Public Sub TraverseAssemblySample()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Debug.Print oAsmDoc.DisplayName
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, _
                             Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        ' Print the name of the current occurrence.
        Debug.Print Space(Level * 3) & oOcc.Name
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
    Next
End Sub
Justin K
