Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Check if normal IAM or Factory Layout
1 REPLY 1
mk92
180 Views, 1 Reply
is it possible to check via iLogic or VBA if I am in an Factory Layout or in an normal IAM ?
Kind regards.
1 REPLY 1
HermJan.Otterman
in reply to: mk92
I think you should look here somewhere (look at the code)
in the attributes of a Factory layout you can find some factory things
Dim oDoc As Inventor.AssemblyDocument = _inventorApplication.ActiveDocument
Dim attributeSets As AttributeSets = oDoc.ComponentDefinition.AttributeSets
If attributeSets.Count > 0 Then
For Each attributset As AttributeSet In attributeSets
If attributset.Name = "com.autodesk.inventor.NWMFactory" Then
For Each attribute As Attribute In attributset
MsgBox(attribute.Value.ToString)
Next
End If
Next
I hope this helps
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
