Change font size with VB.net
CAD_CAM_MAN
CAD_CAM_MAN
I need to add a note to an active drawing (sheet 1) and change its fontsize with a VB application on button click. I have the following code...
Private Sub Button6_Click(sender As System.Object, e As System.EventArgs) Handles Button6.Click
Dim DRAW As DrawingDocument = _invApp.ActiveDocument
Dim DS1 As Sheet = DRAW.Sheets(1)
Dim TRG As Inventor.TransientGeometry = _invApp.TransientGeometry
Dim P1 As Point2d = TRG.CreatePoint2d(2, 3.5)
Dim MyNote As GeneralNote = DS1.DrawingNotes.GeneralNotes.AddFitted(P1, "TEST TEXT RESIZE")
End Sub
I cannot seem to find the correct syntax to change the text fontsize in "MyNote" without changing it in the style with
MyNote.TextStyle.FontSize = 0.5 etc..
To clarify I do not want to change the fontsize in the style. I only want to change the fontsize in "MyNote"
If you double click on a note in a drawing it brings up the "Format Text" dialog box, in which the "Size" value is accessible. This size value is what I need to change for all the text in the note.
The application I am building is running with Inventor 2015.
I have to be making this harder than it is.
Anybody got a fix or appropriate syntax?
RodrigoEiras
This works for FormattedText in a TextBox, so I guess it also works in a GeneralNote Object. This allows you to override the text format for a particular object, without affecting the style.
oTextBox.FormattedText = "<StyleOverride FontSize = '25'>" & "Some Text" & "<StyleOverride Color = '255,0,0'>" & _
"</StyleOverride>" & "</StyleOverride>"
If you just want to change the size the syntax would be something like this:
SyntaxEditor Code Snippet
oTextBox.FormattedText = "<StyleOverride FontSize = '" & dTextSize & "'>" & "TOP" & "</StyleOverride>"
I hope it helps!
CAD_CAM_MAN
Thank you. That is what I was after!
