Can't get API method to work
cwhetten
Advisor Advisor
cwhetten
I am trying to use the ContentTableColumn.GetPropertyMap method, but I can't figure out how to get it to work.  Here is the 2014 API help documentation on this method:
I have successfully accessed the ContentTableColumn object (stored in oMassColumn in the examples below), determined that HasPropertyMap = True, but every time I try to call GetPropertyMap, I get a type mismatch error.  I am trying to use this in an iLogic rule.  Here is what I have tried:
Dim setid As String
Dim propid As String
oMassColumn.GetPropertyMap(setid, propid)
I even tried this:
Dim setid As Object
Dim propid As Object
Either the documentation is wrong, or there is some VB fundamental that I am not understanding here (which is entirely possible)...
Does anyone know how to successfully use this method?
Cameron Whetten
Inventor 2014
Boorda
I havent tested this on your situation but I know that in the past VBA has some weird issues with syntax.
For whatever reason, even if the code isn't highlighted red it throws errors.
Sometime just changing the syntax a bit fixes the issue. Don't know if this will work in your case but try this....
   Change this...
Dim setid As String
   To this....
Dim setid As String
oMassColumn.GetPropertyMap setid, propid
Like I said, not sure if it will work for you but hopefuly it does....
Automation is key!
cwhetten
Thanks for the suggestion @Boorda .  I tried it out and received a compile error: "Method arguments must be enclosed in parentheses."
I think your suggestion would be appropriate for VBA, but I am working in the iLogic rule editor.
But this gives me an idea.  I'll try this in a VBA macro instead of an iLogic rule, to see if that makes a difference.
Cameron Whetten
Inventor 2014
cwhetten
I rewrote my iLogic rule into a VBA routine, and it worked (using the syntax that @Boorda suggested).  I still don't know why this method doesn't work in iLogic, but I was able to complete my task using VBA so I'll mark Boorda's post as the solution.  My actual usage is given below, for reference.
Dim setid As String
Debug.Print "Has Property Map = " & oMassColumn.HasPropertyMap
If oMassColumn.HasPropertyMap Then
    Debug.Print "Property Set = " & setid & vbNewLine & "Property ID = " & propid
Cameron Whetten
Inventor 2014
