Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Automatic dimensions and constraints - iLogic
4 REPLIES 4
Ladousek
960 Views, 4 Replies
do you know how to use function "Automatic dimensions and constraints" in the sketch by iLogic? I would like to add dimensions to the sketch witch is drawn by defferent iLogic Rule step by step, line by line. Create sketch is not problem, but i would like to add dimensions to the lines.
4 REPLIES 4
RodrigoEiras
in reply to: Ladousek
TobFischer94
in reply to: RodrigoEiras
i looked at the link by RodrigoEiras,
and theres a command called:
"SketchAutoDimensionCmd --> dimensions sketch geometry automatically"
you can run it by running an ilogic rule with the following code. Note that you must have created a Sketch called "Sketch1" containing geometry first:
 'Get the CommandManager object.
 Dim oCommandMgr As CommandManager
    oCommandMgr = ThisApplication.CommandManager
 ' Dim and select Sketch1
        Dim oSketches As PlanarSketches = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
    Dim oSketch As Sketch = ThisApplication.ActiveEditObject
    oSketch.ExitEdit
End If
oSketches("Sketch1").Edit ' Get control definition for the line command. Dim oControlDef As ControlDefinition oControlDef = oCommandMgr.ControlDefinitions.Item( _ "SketchAutoDimensionCmd")
' Execute the command. Call oControlDef.Execute
TobFischer94
in reply to: TobFischer94
to simulate the pressing of the "apply" button that pops up, add the following code at the end of the ilogic-rule:
'Press Apply button
Dim oKCmd As ControlDefinition
Set oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd")
Call oKCmd.Execute
Thanks for the code. I like it. I modified a little bit - but, I need help.
I appreciate id you could fix the code for me.
    oSketch.ExitEdit
End If
    oControlDef = oCommandMgr.ControlDefinitions.Item("SketchAutoDimensionCmd")
oCount_Dimensions = 1 '1 is wrong. Need to fix code
oCount_Constraints = 1	'1 is wrong. Need to fix code
oYN = MessageBox.Show("Missing dimensions: " & oCount_Dimensions _
& vbLf & "Missing constraints: " & oCount_Constraints, _
"Do you want to add dimensions automatically?", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
If oYN = vbYes Then
'Press Apply button
Call oKCmd.Execute
Else
MessageBox.Show("Message", "Title")
'Code to add dimensions
End If
oSketches("Sketch1").ExitEdit
