Hi
I currently loop through my assembly and get iProperties using the AllLeafOccurrences method. I now need to do the exact same, but using apprentice so that the file doesnt open.
Reason:
I use the apprentice method to get a collection of file names and iproperties and populate a datagrid. This is super fast. When i iterate through my assembly as a normal document, the iteration is very slow compared to the apprentice iteration.
The only thing i cannot get working is my loop using Apprentice. Can it be done? I thought that once the document was opened by apprentice, you could access everything in the same way as you would if it was opened directly.
Dim apprentice As Inventor.ApprenticeServerComponent = New ApprenticeServerComponent Dim apprenticeDoc As Inventor.ApprenticeServerDocument = apprentice.Open(AssemblyPath) Dim oasmdef As ComponentDefinition = apprenticeDoc.ComponentDefinition Dim oLeafOccs As ComponentOccurrencesEnumerator = oasmdef.Occurrences.AllLeafOccurrences For Each oCompOcc As ComponentOccurrence In oLeafOccs
'EVERYTHING FROM HERE DOES NOT WORK
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
can you explain what is not working cause from here, when I try your code, everything is fine.
Best regards,
It's hard to troubleshoot when you only give us the working part of your code..... ha!
