Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
API - Create iLogic Rule & add event trigger
5 REPLIES 5
Jef_E
410 Views, 5 Replies
Is it possible to create a NEW rule via the Inventor API and add a Event trigger to it?
OR
Is it possible to suppress/unsuppress a ilogic rule?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
5 REPLIES 5
MechMachineMan
in reply to: Jef_E
Yes, Yes, And Yes.
It is all through iLogicVb.Automation.
ie;
To supress a rule:
iLogicVb.Automation.GetRule(ThisDoc.Document, "Part Info").IsActive = False
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
in reply to: MechMachineMan
And how can I use this in my vb.net program?
This snippit you gave me is accepted by iLogic but not by visual studio?
Inventor 2014 SP2
MechMachineMan
in reply to: Jef_E
Call the iLogic Add-in within the inventor app of your visual studio object.
There is also the .dll / reference for the iLogic add-in which you will need to include.
Justin K
Jef_E
Can't seem to find the .dll to add as reference.. Can only find the Autodesk.Inventor.Interop.dll
Where do i look for the iLogic.dll?
Inventor 2014 SP2
MechMachineMan
in reply to: Jef_E
I may have mislead you a bit there; I haven't actually made add-ins myself and am not too familiar with the nitty-gritty details.
BUT:
The good ol' Google-Fu looks like it can help you out more than I ever could.
http://lmgtfy.com/?q=how+to+reference+iLogic+in+an+add-in
Justin K
