Adding sheetmetal rule to foldername
JoshuaNAM
JoshuaNAM
Hi Guys,
I've got a code running to export dxf files to a certain DXF-folder and that's working great.
The guys of the production department would like to have the dxf's sorted in different folders with the material and thickness as foldername.
The current foldername is as follows:
oFolder = oPath & "\" & oAsmName & "-Rev_" & oRevNum & "-PF" & "\" & oAsmName & "-Rev_" & oRevNum & "-DXF"
I would like to get ActiveSheetMetalStyle.Name from the different sheetmetal parts in an assembly and use that to create a new folder for that type of material and thickness.
Thus adding an aditional folder like "\"Steel 3mm or AISI 304 5mm  etc...
Could somebody help me out as I haven't got the required knowledge to get the information from the sheetmetal part.
SyntaxEditor Code Snippet
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
oRevNum = iProperties.Value("Project", "Revision Number")
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'Get user Input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the assembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & "Only sheet metal parts with their BOM-structure set to normal will be exported" _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly sheet metal components?" _
& vbLf & " " _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
'check if the document is a sheet metal part
If oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
'check if the BOM-structure is set to normal
If oRefDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kNormalBOMStructure Then Continue For
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that the model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)- 3)
On Error Resume Next
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
oDataMedium.FileName = oFolder & "\" & oFileName & "dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
'sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE"
'sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerColor=255;0;0&BendUpLayerColor=255;0;0&BendDownLayerLineType=37641&BendUpLayerLineType=37639IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES"
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerColor=255;0;0&BendUpLayerColor=0;128;255&BendDownLayerLineType=37633&BendUpLayerLineType=37641;IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILESLayer=engrave;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_FEATURE_PROFILES_DOWN"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
oCompDef.FlatPattern.ExitEdit
oDrawDoc.Close
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
JoshuaNAM
Solved it myself:
oStyle=oRefDoc.ComponentDefinition.ActiveSheetMetalStyle.Name
Foldername becomes:
oFolder = oPath & "\" & oAsmName & "-Rev_" & oRevNum & "-PF" & "\" & oAsmName & "-Rev_" & oRevNum & "-DXF" & "\" & oStyle
Could you post your updated code into the forum because I'm brand new to macros and think I'm pasting the revisions into the wrong places.  I also want to clarify that this is a VBA code to use as a  macro and not an Ilogic rule because I know there is a difference but not enough to tell which is which.  Thanks for your help.
