Add custom check in Design checker
sripandian
sripandian
Hi all,
 Can anyone guide me how to create ilogic for custom design checker.one more thing, I have a few DLL files which are  developed in c# for checking some custom check rules. How to add those checks in Design checker? If possible pls share some sample code...
YuhanZhang
In the documentation there is a sample to demonstrate how to add a custom check for Design Checker, hope it helps:
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
sripandian
Hi ,
Thanks for your reply. I am facing issue on take the report from DLL to cusrom ilogic rule ..
YuhanZhang
Can you describe more details about the issue? Can you generate the report? Or the result report only has the custom(iLogic ) checks results missing?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
sripandian
