Add border of a path
Message 1 of 16
I have a problem with this code,
I need to change the border of a drawing with a border that I have on my desktop, but it doesn't works
I will be grateful with the help
Sub
Main() Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oBorder As Border = oSheet.Border DeleteBorders InsertBorder End Sub Sub DeleteBorders() Dim oDrawDoc1 As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet1 As Sheet = oDrawDoc1.ActiveSheet For Each oSheet1 In ThisApplication.ActiveDocument.Sheets If Not oSheet1.Border Is Nothing Then oSheet1.Border.Delete End If Next End Sub Sub InsertBorder() Dim oDrawDoc3 As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet3 As Sheet = oDrawDoc3.ActiveSheet Dim borderDef As BorderDefinition strBorderRequired = True Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument ThisDrawing.ResourceFileName = "C:\Users\Desktop\Codigos\Templates\Parts.idw" Dim SourceFile = ThisDrawing.ResourceFileName Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) For Each borderDef In strSourceIDW.BorderDefinitions If (StrComp(borderDef.Name, vbTextCompare) = 0) Then CopyFrom = borderDef.CopyTo(strDrawDoc, True) End If Next strSourceIDW.Close() Dim oNewBorderDef As BorderDefinition oNewBorderDef = oDrawDoc3.BorderDefinitions.Item(borderDef.Name) For Each oSheet3 In oDrawDoc3.Sheets oSheet3.AddBorder(oNewBorderDef) Next MessageBox.Show("The border was changed", "Title") End Sub
Replies (15)
Message 2 of 16
FINET_Laurent
Can you tell what line gives you an error ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 16
Curtis_Waguespack
Hi @Anonymous
There were a couple of issues... your string compare had only one string in it... and also, I think you needed to hand the border definition name down to the InsertBorder sub, so it could know the name of the border that was deleted.
I think this example will work for you.
I hope this helps.
Curtis
Sub Main()
	If Not oSheet.Border Is Nothing Then
		oOriginalBorderDefName = oSheet.Border.Definition.Name
		Logger.Info(oOriginalBorderDefName)
		DeleteBorders()
		InsertBorder(oOriginalBorderDefName)
End Sub
Sub DeleteBorders()
	For Each oSheet In ThisApplication.ActiveDocument.Sheets
	        oSheet.Border.Delete
	Next
End Sub
Sub InsertBorder(oOriginalBorderDefName As String)
	SourceFile = "C:\Users\Desktop\Codigos\Templates\Parts.idw"
    	strSourceIDW = ThisApplication.Documents.Open(SourceFile, True)
	Logger.Info(strSourceIDW.FullFileName)
        If (StrComp(borderDef.Name, oOriginalBorderDefName, vbTextCompare) = 0) Then
	Next
	oNewBorderDef = oDrawDoc.BorderDefinitions.Item(oOriginalBorderDefName)
	For Each oSheet In oDrawDoc.Sheets
		oSheet.AddBorder(oNewBorderDef)
	Next
End Sub
Message 4 of 16
Thank you for your help @Curtis_Waguespack  it works!
I have more question,
I tried using the same code and changing the title block, but it sends this error: Public member 'Title' on type 'Sheet' not found.
Sub Main()
Dim oTitleBlock As TitleBlock = oSheet.TitleBlock
	If Not oSheet.TitleBlock Is Nothing Then
		oOriginalTitleDefName = oSheet.Title.Definition.Name
		DeleteTitle()
		InsertTitleBlock(oOriginalTitleDefName)
End Sub
Sub DeleteTitle()
	        oSheet.TitleBlock.Delete
	Next
End Sub
Sub InsertTitleBlock(oOriginalTitleDefName As String)
	Dim TitleBlockDef As TitleBlockDefinition
	strTitleBlockRequired = True
	SourceFile = "C:\Users\rvaldivia\Desktop\Codigos\Templates\H+K Parts (mm).idw"
	For Each TitleBlockDef In strSourceIDW.TitleBlockDefinitions
        If (StrComp(TitleBlockDef.Name, oOriginalTitleDefName, vbTextCompare) = 0) Then
            CopyFrom = TitleBlockDef.CopyTo(strDrawDoc, True)
	Next
	Dim oNewTitleBlockDef As TitleBlockDefinition
	oNewTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item(oOriginalTitleDefName)
		oSheet.AddTitleBlock(oNewTitleBlockDef)
	Next
End Sub
Thank you once more for your help in this matter
Message 5 of 16
Curtis_Waguespack
Hi @Anonymous
You were very close, just change Title to TitleBlock in this one place and then it should work.
I hope this helps.
Curtis
Message 6 of 16
I made the change but it seems to me the following error
The parameter is incorrect (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Do you know were is the error?
I've been researching but I don't know what's wrong
Thank you for your help!
Message 7 of 16
Curtis_Waguespack
Hi @Anonymous
Maybe the source file can not be found or opened?  Here is an example with some error checking and logger messaging that might help you determine the issue.
See this link for more on the ilogic logger:
To Create Log Statements | Inventor 2019 | Autodesk Knowledge Network
I hope this helps.
Curtis
Sub Main()
	oOriginalTitleDefName = oSheet.TitleBlock.Definition.Name
	DeleteTitle()
Else
	Logger.Info("No title block found on the active sheet")
End Sub
Sub DeleteTitle()
	Next
End Sub
	Try
	Catch ex As Exception
		Logger.Info(ex.Message)
		MsgBox("Could not open source IDW....", , "Test message")
		Return
	End Try
	oFound = False
			Logger.Info(TitleBlockDef.Name)
			oFound = True
	Next
	If oFound = False Then
		Logger.Info(TitleBlockDef.Name & " not found in source IDW")
	Next
End Sub
Message 8 of 16
rebes_31
Hello @Curtis_Waguespack
I tried with this code and it send me the same error
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG)) ☹️
I think the code finds the file, but it does not insert into the new drawing.
Message 9 of 16
Curtis_Waguespack
Hi @rebes_31
You'll need to use the logger to see where in the code the problem originates.... see the link in my last post concerning opening and viewing the iLogic logger.
If you can determine the issue, I might be able to assist further, otherwise it is a guess.
Note that the code does work on my computer, so there must be something in your files or paths that is causing the issue.
I hope this helps.
Curtis
Message 10 of 16
rebes_31
Hello I´m back
This appears in the iLogic logger
INFO|H+K Title Block not found in source IDW
Could you please help me?
Message 11 of 16
checkcheck_master
@Curtis_Waguespack
Hi Curtis,
Can you please help me.
I get an error that I can't figure out on line 53, see picture:
'CopyFrom = borderDef.CopyTo(strDrawDoc, True)'
The existing Border is neatly deleted, after which this error message follows.
In both documents the Border has the same name: 'Default Border'.
I also see that name in the logger.info
Thanks in advance.
Sub Main()
		DeleteBorders()
		' Use DoEvents to force Inventor to wait till the code is finished...
		ThisApplication.UserInterfaceManager.DoEvents
End Sub
Sub DeleteBorders()
	Next
End Sub
		'MessageBox.Show("Here...")
	SourceFile = "C:\Workingfolder\CAD Settings\Inventor\Templates\HML Drawing.dwg"
	Next
	Next
	'MessageBox.Show("The border was changed", "Title")
End Sub
Message 12 of 16
Curtis_Waguespack
Hi @checkcheck_master,
My first guess would be that the border has prompted entry?
If that's the case, then you would need something like this example.
I hope this helps.
Curtis
    ' This border definition contains 2 prompted string inputs.  An array
    ' must be input that contains the values for the prompted strings.
    Dim sPromptStrings(1 To 2) As String
    sPromptStrings(1) = "Hello."
sPromptStrings(2) = "World." For each oSheet in oDrawDoc.Sheets
oSheet.AddBorder(oNewBorderDef, sPromptStrings)
Next
Message 13 of 16
checkcheck_master
Thank you Curtis, smart to think of that.
I've come across it before with a Title Block replaced and seen it pass by but can't get my fingers behind it.
The code still keeps stumbling at that 'CopyTo'.
See the whole code where you can see what I'm bumbling around.
Those Prompted Entries do come across well with updating the title block.
I have also tried the same kind of technique with the border, but at a certain point my knowledge falls short.
I still don't understand why it is so difficult with the border.
Btw, maybe it says something, I haven't seen that message at the end of the sub 'InsertBorder' yet, somehow it doesn't get there.
Sub Main
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
' Point to template to get title block from
ThisDrawing.ResourceFileName = "C:\Workingfolder\CAD Settings\Inventor\Templates\HML Drawing.dwg"
Dim oCurrentNumber As Sheet
oCurrentNumber = oDoc.ActiveSheet
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
' Undo Wrapper
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Do your thing...")
' Uncheck Checked Dates
iProperties.Value("Status", "Checked Date") = Nothing
iProperties.Value("Status", "Checked By") = Nothing
Dim valQTY As String = ""
Dim valFINISHING As String = ""
For Each oSheet In oDoc.Sheets
oSheet.Activate
	If Not ActiveSheet.TitleBlock = "" Then
		'Get the Prompted Entries, QTY and FINISH
		' Let op, als we zoeken op bv 'QTY' komt dat twee keer voor, onduidelijk wanneer het de waarde betreft of niet, vandaar de 'If <> "QTY" then...' enz.
'		Dim valQTY As String = ""
'		Dim valFINISHING As String = ""
		Dim oPromptEntry
		Dim actSheet As Sheet = ThisApplication.ActiveDocument.ActiveSheet
		'For Each oSheet In oDoc.Sheets
		    ActiveSheet=ThisDrawing.Sheet(oSheet.Name)
		    If oSheet.TitleBlock Is Nothing Then Exit Sub
		    oTitleBlock=oSheet.TitleBlock
		    oTextBoxes=oTitleBlock.Definition.Sketch.TextBoxes
		    For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
				'On Error Resume Next
				If oTextBox.Text <>"" Then
					Select oTextBox.Text
					    Case "QTY":
							'oPromptEntry = ThisPurposeForIssue
							If oTitleBlock.GetResultText(oTextBox) <> "QTY" Then
								'MessageBox.Show(oTitleBlock.GetResultText(oTextBox), "QTY")
								valQTY = oTitleBlock.GetResultText(oTextBox)
						Case "FINISHING":
							If oTitleBlock.GetResultText(oTextBox) <> "FINISHING" Then
								'MessageBox.Show(oTitleBlock.GetResultText(oTextBox), "FINISHING")
								valFINISHING = oTitleBlock.GetResultText(oTextBox)
					End Select
		    Next
		'Next
		' Rename TitleBlock so it can be replaced completely, later unused TitleBlocks are removed
		For Each oTitleBlock In oDoc.TitleBlockDefinitions
			If oTitleBlock.Name = "HML" Then
				oTitleBlock.Name = "HML_Old"
		Next
		' Place 'New' Titleblock
		' There Is a different Call For title blocks which contain prompted entries
		'ActiveSheet.SetTitleBlock("HML", valQTY, "Kijk maar! Doe maar wat!")
		ActiveSheet.SetTitleBlock("HML", valQTY, valFINISHING)
		'ActiveSheet.SetTitleBlock("HML", "-", "See Paint Specification List") ' "QTY" "FINISHING"
		'ActiveSheet.SetTitleBlock("HML", "promptedEntry1", "promptedEntry2")
		'ActiveSheet.TitleBlock = "HML"
'		' Try to set the Border
'		'On Error Resume Next
'		oBorder=oSheet.Border
'		For Each oBorder In oDoc.BorderDefinitions
'			If oBorder.Name = "Default Border" Or oBorder.Name = "HML Border" Then
'				oBorder.Name = "HML_Border_Old"
'			End If
'		Next
'		Try
'			oSheet.Border.Delete
'		Catch
'		End Try
'		Try
'			ActiveSheet.SetBorder("HML_Border", "", "")
'		Catch
'		End Try
Next
' Delete unused title block(s) from Drawing Recources
'On Error Resume Next '(The used Title Block can not be deleted)
	Try
		oTitleBlock.delete()
	Catch
	End Try
Next
''Delete unused Borders from Drawing Recources
''On Error Resume Next '(The used Border can not be deleted)
'Dim oBorder As Border
'For Each oBorder In oDoc.BorderDefinitions
'	Try
'		MessageBox.Show("oborder.name: " & oBorder.Name)
'		oBorder.Delete()
'	Catch
'	End Try
'Next
'Dim oObj As ObjectCollection(Of String)
'oObj.Add(valQTY.ToString)
'oObj.Add(valFINISHING.ToString)
'Dim sPromptStrings(2) As String
'    sPromptStrings(1) = valQTY
'    sPromptStrings(2) = valFINISHING
'oSheet.AddBorder("Default Border",sPromptStrings)
'	Dim oNewBorderDef As BorderDefinition
'	oNewBorderDef = oDoc.BorderDefinitions.Item(oOriginalBorderDefName)
'	For Each oSheet In ThisApplication.ActiveDocument.Sheets
'		If Not oSheet.Border Is Nothing Then
'	    End If
'	Next
'			oOriginalBorderDefName = oSheet.Border.Definition.Name
'			Logger.Info(oOriginalBorderDefName)
'	End If
'	For Each oSheet In oDoc.Sheets
'		oSheet.AddBorder(oNewBorderDef)
'	Next
		DeleteBorders()
' Set Date and Author
	'oTime = Now.ToShortDateString
	'iProperties.Value("Project", "Creation Date") = oTime
	'iProperties.Value("Summary", "Author") = "CNo"
iLogicVb.UpdateWhenDone = True
'Back to current/active sheet
oCurrentNumber.Activate
' Undo Wrapper
trans.End()
' Copy Sketch Symbols from Drawing Template into this Drawing
Dim SourceFile As String = ThisDrawing.ResourceFileName '"D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw"
Dim strStampList As New List( Of String)
Dim symbolDef As SketchedSymbolDefinition
' Remove unused Sketch Symbols
For Each symbolDef In strDrawDoc.SketchedSymbolDefinitions
	Try
		symbolDef.Delete
	Catch
		'MessageBox.Show("Error deleting Sketched Symbol: " & symbolDef.Name, "InventorPLUS", MessageBoxButtons.OK, MessageBoxIcon.Information)
	End Try
Next
' Add Symbols to the List
For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions
    strStampList.Add(symbolDef.Name)
Next
' Sort List with Sketch Symbols
strStampList.Sort
'strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps")
'    'If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then
        CopyFrom = symbolDef.CopyTo(strDrawDoc, True)
'        'If MsgBox("Would you like to place the stamp on the drawing?", MsgBoxStyle.YesNo, "Insert Stamp") = MsgBoxResult.Yes Then
'        '    'Insert stamp if required
'        '    InsertSymbol(symbolDef.Name)
'        'End If
'	'End If
Next
' Sort the Sketch Symbols
ThisApplication.ActiveDocument.BrowserPanes("Model").TopNode.BrowserNodes.Item("Drawing Resources").BrowserNodes.Item(4).DoSelect
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
Dim oControlDef1 As ControlDefinition
oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingResourceSort")
oControlDef1.Execute
End Sub
Sub DeleteBorders()
	Next
End Sub
	Next
'	For Each oSheet In oDrawDoc.Sheets
'	Next
    Dim sPromptStrings(0 To 1) As String
    sPromptStrings(0) = "Hello."
    sPromptStrings(1) = "World."
    Next
End Sub
Message 14 of 16
Curtis_Waguespack
Hi @checkcheck_master ,
My apologies for the confusion, I replied in a hurry this morning as I was getting ready to go to a meeting. But in looking at this now, I see that the issue is the Copy line, not the Add line... so my suggestion about prompted entry would likely not have helped even if prompts were involved.
I just set up a simple example with this as the only change from your first example:
SourceFile = "C:\Temp\HML Drawing.dwg"
...and it runs without issues.
The only thing that came to mind that would create an error at the Copy line, might be is the destination drawing has a Sheet Format that is using the border. In that case it might hang onto the old border definition and not allow it to copy... however I did a simple test with a sheet format, and didn't see the error then either.
I hope this helps.
Curtis
Message 15 of 16
checkcheck_master
Thank you again Curtis.
I just lost him a little.
I have changed the location of the source but it keeps giving me an error on that CopyTo line.
I don't really understand why he couldn't get to that earlier location.
What am I doing wrong?
Can I see your complete code please?
Message 16 of 16
checkcheck_master
@Curtis_Waguespack
I tackled him in a different way Curtis, see code.
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=Sheet_AddDefaultBorder
			' Check to see if the sheet already has a border and delete it if it does.
		    ' Define the values to use as input for the border creation.
		    Dim HorizontalZoneCount As Double
		    HorizontalZoneCount = 0
		    Dim HorizontalZoneLabelMode As BorderLabelModeEnum
		    HorizontalZoneLabelMode = BorderLabelModeEnum.kBorderLabelModeNone
		    Dim VerticalZoneCount As Double
		    VerticalZoneCount = 0
		    Dim VerticalZoneLabelMode As BorderLabelModeEnum
		    VerticalZoneLabelMode = BorderLabelModeEnum.kBorderLabelModeNone
		    Dim LabelFromBottomRight As Boolean
		    LabelFromBottomRight = False
		    Dim DelimitByLines As Boolean
		    DelimitByLines = False
		    Dim CenterMarks As Boolean
		    CenterMarks = False
		    Dim TopMargin As Double
		    TopMargin = .5
		    Dim BottomMargin As Double
		    BottomMargin = .5
		    Dim LeftMargin As Double
		    LeftMargin = .5
		    Dim RightMargin As Double
		    RightMargin = .5
			Dim TextStyle As Object
			Dim TextLayer As Object
			Dim LineLayer As Object
			' Add the border to the sheet
		    Dim oBorder As DefaultBorder
			oBorder = oSheet.AddDefaultBorder(	HorizontalZoneCount, _
												HorizontalZoneLabelMode, _
												VerticalZoneCount, _
												VerticalZoneLabelMode, _
												LabelFromBottomRight, _
												DelimitByLines, _
												CenterMarks, TopMargin, _
												BottomMargin, LeftMargin, _
												RightMargin, _
												TextStyle, _
												TextLayer, _
												LineLayer)
