ilogic部件中选个 零件或者部件,然后运行改名 ,同步更改工程图名称
858456055
858456055
'Programming by DWJ China Tianchang city QQ二次发开交流群:951736200/48805368 Thanks for Autodesk Rocky giving me help!'鼠标先选择零件 再运行
imports File = System.IO.File
Imports Path = System.IO.Path
Sub main()
If ThisDoc.Document.DocumentType = kPartDocumentObject Then
MsgBox("仅在部件环境中使用!", , "DWJ")
return
End If
On Error Resume Next
Dim oOcc As ComponentOccurrence
oOcc = ThisApplication.ActiveDocument.SelectSet.Item(1)
If Err.Number <> 0 Then
MsgBox("你必须选择一个零件!", , "DWJ")
Exit Sub
End If
On Error GoTo 0
Dim oDoc = oOcc.Definition.Document
Err.Clear
filepath = oDoc.fullfilename '获得全路径名称
Dim oFileName = IO.Path.GetFileNameWithoutExtension(filepath) '获取无扩展名的名称 ( returns: 1234)
FName = InputBox("零件名称是:", "请输入...", oFileName)
If FName = "" Then
FName = oldname
MsgBox("名称不能为空!", , "温馨提示DWJ:")
Return
End If
If FName = oFileName Then
MsgBox("名称不能为之前名称!或者相同", , "DWJ:")
Return
End If
PP = IO.Path.GetDirectoryName(filepath) '得到的路径 (returns: C:\Temp\Test)
Dim oExt = IO.Path.GetExtension(filepath) '得到扩展 ( returns: .ipt)
Dim pathstr = PP + "\" + FName + oExt
If File.Exists(pathstr) Then
MsgBox("已存在同名文件!", , "DWJ")
Else
Err.Clear
oDoc.SaveAs(pathstr, False)
oOcc.Replace(pathstr, True)
My.Computer.FileSystem.DeleteFile(filepath, FileIO.UIOption.OnlyErrorDialogs, FileIO.RecycleOption.SendToRecycleBin, FileIO.UICancelOption.DoNothing)
Call idwdrawingnamechangefx(filepath, pathstr)'调用idw工程图修改子函数
Call dwgdrawingnamechangefx(filepath, pathstr)'调用dwg工程图修改子函数
Err.Clear
End If
End Sub
Sub idwdrawingnamechangefx(ByRef oldModelPath, ByRef NewModelPath)
Dim oldDrawingPath As String
Dim NewDrawingPath As String
oldDrawingPath = Strings.Left(oldModelPath, Strings.Len(oldModelPath) -3) + "idw" '老工程图路径
NewDrawingPath = Strings.Left(NewModelPath, Strings.Len(NewModelPath) -3) + "idw" '新工程图路径
IO.File.Copy(oldDrawingPath, NewDrawingPath)'复制工程图新的到指定路径
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.Documents.Open(NewDrawingPath, True)'打开复制后新工程图(打开窗口不显示)
Dim oFD As FileDescriptor
oFD = oDrawDoc.File.ReferencedFileDescriptors(1)
oFD.ReplaceReference(NewModelPath)' 替换引用文档为改名后的模型文档
My.Computer.FileSystem.DeleteFile(oldDrawingPath, FileIO.UIOption.OnlyErrorDialogs, FileIO.RecycleOption.SendToRecycleBin, FileIO.UICancelOption.DoNothing)'删除旧工程图
oDrawDoc.Close(False)' 保存修改并关闭工程图
End Sub
Sub dwgdrawingnamechangefx(ByRef oldModelPath, ByRef NewModelPath)
oldDrawingPath = Strings.Left(oldModelPath, Strings.Len(oldModelPath) -3) + "dwg" '老工程图路径
NewDrawingPath = Strings.Left(NewModelPath, Strings.Len(NewModelPath) -3) + "dwg" '新工程图路径
End Sub
设计之上!
回复
3,657 次查看
9 条回复
回复 (9)
858456055
DWJ祝大家新年快乐!!
设计之上!
0 个赞
599142655
你这个可以增加个功能吗,就是重命名后同步一下零件代号 。你这个零件名改了,但是代号还是旧的。
0 个赞
858456055
好的回头弄个!
设计之上!
0 个赞
599142655
谢谢分享,这个功能很好用。封装个按钮吧,零部件右键加个按钮就完美了。
0 个赞
858456055
你好我想起来了 ,我还有一个根据零件代号批量改名称,这个是为了一个bug :不同零件状态 存在不同零件代号改名bug,新的 根据零件代号批量改名称 已经增加检测了(不同零件状态 存在不同零件代号)跳过,如果你想要改名同步改名称建议使用根据零件代号改名,这个主要针对 不同零件状态 存在不同零件代号改名bug。根据零件代号批量改名称也发到了论坛里面!
设计之上!
599142655
我看到那个帖子了,好像是要先改代号的。不过这浏览器显示的名字和代号好像不是自动一致的。最好还是浏览器里改了,其他的自动跟着修改更方便。
0 个赞
858456055
浏览器有刷新功能,你可以试试,回头加个刷新!
设计之上!
0 个赞
yuzeaa
在Inventor应用商店搜索“Button Constructor"插件,为外部规则创建按钮。
858456055
回头看一下
设计之上!
0 个赞
