it's okay as long as you are student? thanks
you try to edit your autodesk account and make it right?
@Anonymous ,
Consider the suggestions on this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Hi @Anonymous,
You need to contact educational support who can change this in the back end. https://knowledge.autodesk.com/contact-support
@ennujozlagam School does matter now as it's what SheerID compares your evidence to.
I can't find a way to get into proper contact with educational support, I just found guides to troubleshoot the problem, but whenever I find a link to get in contact I just get sent back to https://www.autodesk.com/education/support
@oscar_smep6, Follow these steps..!!
1. Click on the Question mark on the bottom of the page.
2. You will see a screen like this.
3. Type in your query and follow the lead. Like you can type Create a support case, etc.
Later on you will see 2 options to contact support. (Chat and creating a support case. Choose as per your convivence)
