Installation & Licensing
Post 1 of 16
Windows Error Code C0000094 installing Alias Concept 2017
89 Views, 15 Replies
03-16-2017 03:15 PM
I'm trying to install Alias Concept 2017 and I get the Window error code C0000094 during the Autodesk Self-Extract phase (Autodesk Download Manager).
The Window DB information is shown below.
Autodesk Download Manager has stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: Autodesk_ALSCPT_2017_Enu_64bit_dlm_001_002.sfx.exe
Application Version: 4.0.19.0
Application Timestamp: 560ccae3
Fault Module Name: Autodesk_ALSCPT_2017_Enu_64bit_dlm_001_002.sfx.exe
Fault Module Version: 4.0.19.0
Fault Module Timestamp: 560ccae3
Exception Code: c0000094
Exception Offset: 00059554
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
any help would be appreciated.
John Morrison
Hi Mark.
Here was the solution (as silly as it sounds).
I had the downloaded files on a network drive.  I copied them to a local D: drive and uncompressed from there.  It worked correctly.
so the solution was to install locally.  There must have been file path length issues.
John Morrison
Post 2 of 16
RE: Windows Error Code C0000094 installing Alias Concept 2017
03-16-2017 03:15 PM in reply to: jbmorrisonjr
Hello jbmorrisonjr and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Post 3 of 16
Re: RE: Windows Error Code C0000094 installing Alias Concept 2017
03-16-2017 03:23 PM in reply to: Otto
Hi.
I’ve downloaded the product twice, tried “run as administrator” and I’ve even tried running the “2 of 2” in addition to the “1 of 2”.
There is over 90G of free disk space. This is Windows 7 and this is a new product for us so it has never been installed on any machine.
Also, the network is air-gapped (no internet access).
John Morrison
Disclaimer The information in this email and any attachments may contain proprietary and confidential information that is intended for the addressee(s) only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, retention or use of the contents of this information is prohibited. When addressed to our clients or vendors, any information contained in this e-mail or any attachments is subject to the terms and conditions in any governing contract. If you have received this e-mail in error, please immediately contact the sender and delete the e-mail.
Post 4 of 16
03-16-2017 03:37 PM in reply to: jbmorrisonjr
@jbmorrisonjr
Just a heads up.. Nothing major..  Smiley Very Happy  You shouldn't reply to a forum posting using your email system.  Granted you don't have a in-depth email signature but all that info gets applied in your posting..  Just come back to the forum and reply there..
Next thing..  I assume you used your Autodesk Account to download the software since Alias Concept 2017 is not on the Autodesk Virtual Agent.  What method did you use, Install Now, Browser Download or Download Now?
 Mark Lancaster
  , Certified Professional in Autodesk Inventor 2014/2015/Exam & AutoCAD 2014 and not an Autodesk Employee
 Installation | Autodesk Virtual Agent | Autodesk Register Once | Activation/Chat | Microsoft FixitDesktop Sub-Grant User Access | Error 1603 | Autodesk Med Resolu LibrayInventor Reset | Screencast
 Kudos is much appreciated if the information I have shared is helpful to you and/or others
Post 5 of 16
03-16-2017 03:42 PM in reply to: jbmorrisonjr
Hello @jbmorrisonjr,
It seems like you maybe using the browser download via the Autodesk Virtual Agent already. If not try the download from there.
Have you prepared the system first.
  • Log in as an Administrator
  • Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Start Menu and hit Enter
  • Temporarily disable your Antivirus software & Firewall
  • Temporarily disable UAC:  Windows 7 , Windows 10
  • Download all of the parts Autodesk Virtual Agent
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
Please attach a install log if you run into an issue.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha Laureiro
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall
Post 6 of 16
03-16-2017 03:48 PM in reply to: Mark.Lancaster
Hi Mark.
Thanks for the "reply" tip.
I use the only download mode available, Browser download.  I was not able to change to any other type.
jbm
Post 7 of 16
03-17-2017 08:55 AM in reply to: jbmorrisonjr
Hi.
Just so you know.  I've tried installing on another machine and got the same error.
BTW,  The error is while trying to extract the files to install from the downloaded packages.  I'm not even getting to the installation portion.  The two part downloaded files are damaged.  I've downloaded them twice and have gotten the the same error while trying to run them. either one.
John Morrison
Post 8 of 16
03-17-2017 02:08 PM in reply to: jbmorrisonjr
I understand you believe this is a download link issue but this error is a Windows error.
Please try reviewing the following information for common troubleshooting:
Subscription Licensing Errors
Natasha Laureiro
Post 9 of 16
03-17-2017 02:30 PM in reply to: natashal84
Please Natasha.
With respect, I'm not that stupid.  I didn't say it was a problem with the download link.  It is a problem with uncompressing the downloaded packages!
the problem is either with the embedded program uncompressing the data or with the data itself and the program can't handle it.  The DLM fails as soon as it shows a message that it is uncompressing the data.
I have downloaded many of your products many times and have not had this problem.
I'm running as administrator.  The anti-virus software is turned off.
Are there any command line options that I can use to turn on debugging to help narrow down where the problem is?
jbm
Post 10 of 16
03-17-2017 03:15 PM in reply to: jbmorrisonjr
Let me add this one additional piece of information.
I think it has to do with having multiple files.  I just installed mudbox 2017 which uses the same autodesk self-extract version 4.0.19.0 with no problems.  It is in a single file.  Where Alias is in two files.
thanks
jbm
Post 11 of 16
03-17-2017 03:40 PM in reply to: jbmorrisonjr
@jbmorrisonjr
I've been looking more at the 94 error..   I've seen a lot of hits across many different applications but nothing really sticks out as what's causing it to occur.   As a side note many Autodesk applications come in multiple parts and I've never seen this error before when it extracts all those parts.  In addition we usually direct people to use the Autodesk Virtual Agent to resolve multiple installation issues.  However this Alias version is not listed there which means the method you are using is the only way..
My concern is, I've seen issues when the parts being download do not matching the correct file size and odd things start happening with the extraction process.  I'm just wondering if that's what your problem is..  Meaning Part 2 is not at the correct file size but I don't have any info related to Alias Concept so I can't compare file sizes with you.  Also it may have nothing to do with the file sizes either and something else is going on.
Did you purchase through the Autodesk On-line store or through a reseller?  If it was through a reseller have you contacted them.
I might suggest that you log a support case through your Autodesk Account or use some of the methods >>here<< to see if tech support can assist you.  Also maybe the actual users have come across this and they can point you to a solution.
I don't want to sound like I'm given up but too me (and at this point), you are just spinning your wheels and getting nowhere.  You need to seek other avenues to get you up and running and quite frankly I don't think there's anybody here that supports this forum can resolve this issue (meaning I have run out of ideas) or even perhaps uses this product.
Good luck and if you do find a solution please come back here and provide the information so others can benefit from it.
 Mark Lancaster
Post 12 of 16
03-17-2017 04:33 PM in reply to: Mark.Lancaster
Thanks Mark.
I just opened a ticket.  We'll see what happens.  Thanks for the link also.  Its a little hard to find things on the autodesk site.
You are right, browser download was the only option.  also, the software is being installed on a machine with no regular internet access.  The network is air-gapped.  So this has to be a stand alone install.  Once I get the software uncompressed, I can get it installed on the workstations that need it.
We work through a reseller and they have been made aware of the issues.
John Morrison
Post 13 of 16
03-20-2017 10:21 AM in reply to: jbmorrisonjr
Hi Mark.
John Morrison
Post 14 of 16
03-20-2017 10:24 AM in reply to: jbmorrisonjr
@jbmorrisonjr
I guess I should've asked that in the beginning  Smiley Very Happy  But I had assume you had them locally...  Yes the download files/parts should always be located on a local drive/partition.
Well its good to hear that you are heading in the right direction..   My suggestion..  Accept you last reply as the solution so others can benefit from it.
 Mark Lancaster
Post 15 of 16
03-20-2017 11:04 AM in reply to: jbmorrisonjr
I finally found a download for Alias Concept 2017 Windows 64bit, but it is still a Browser Download, that is the only method available. I have tested the links, extraction process and initial installation it worked fine. Please let us know if they worked for you. Fingers crossed. Smiley Wink
http://efulfillment.autodesk.com/NET17SWDLD/2017/ALSCPT/DLM/Autodesk_ALSCPT_2017_Enu_64bit_dlm_001_0...
http://efulfillment.autodesk.com/NET17SWDLD/2017/ALSCPT/DLM/Autodesk_ALSCPT_2017_Enu_64bit_dlm_002_0...
Thank you.
Natasha Laureiro
Highlighted
Post 16 of 16
03-20-2017 11:06 AM in reply to: jbmorrisonjr
Ahhh I see. Thank you for returning to the community with the feedback. Smiley Happy
Natasha Laureiro
